Question about Panasonic PT-47WXC43 47" Rear Projection Television
I have a panasonic PT-47WX34J television. I'm trying to replace the convergence chips..anyway..there are 2 red wires going into big black thing lol. How do I remove those to pull the board out? They don't have any clips or anything to remove.
  • 201 Answers
You may not need to remove the red wires, normally there is enough slack to be able to turn the board over just enough to be able to remove the chips. See where the wires are running and losen any clips/ties holding them in place. If you still think you need to remove the red wires normally pushing down into the black thing and twisting 1/4 turn then pulling it out slowly will work on most of them.Some red wires have a metal clip on the end with tabs on them which requires twisting it to get the tabs lined up properly. others have no tabs at all and just require pulling out. I would error on the safe side and try the first method. good luck
Posted on Aug 28, 2010
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
PT-53wx42f won't come back on. Red light blinks several times, checked cords, all are ok. Is there a reset button to press?
Please replace 2 chips in tv, these are marked (location number) as IC7001 and IC7002 on circuit board and number written on both big black chips is same that is STK392-110
Click PartStore.com to buy 2 chips and get it replaced in tv to solve the issue.
Thanks.
Jul 30, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Colors overlap each other and looks 3d
This is symptom of bad convergence that happens due to failure of convergence output chips in tv, there are two big black chips attached with big aluminum heat sink that will be replaced to solve tv issue.
If you are not familiar with electronics stuff repair then call local tv repairman to replace above said chips to fix the problem.
Hope this will help.
Thanks.
Apr 05, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic projection tv pt-53wx52c no picture red light flashing 3 times have sound
3 times red light flashing is an error code that indicates problem in convergence output section, please check and replace convergence output chips and pico fuse nearby. Chips replacement in circuit board requires soldering work and local tv repair shop will help you if you are not familiar with soldering.
Thanks.
Mar 28, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
Thanks.
May 02, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Tv wont turn on
There are two big black ICs that will be replaced. Number would be written as STK392-110 and available with Part Store.
Click above link to see an image of that IC for better idea and price info.
Thanks.
Mar 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
I have a Panasonic PT-56WX51E that started showing double images with a green & red tint, above the original image. I have attempted to connect straight to the box, using DVD & VCR to see if the...
This is really a very simple thing to diagnose---go into the customer menu and select convergence--if red or blue is skewed there and will not adjust in some direction--you have a convergence circuit problem.
These sets use two convergence IC chips--if convergence will not adjust you need to replace both chips along with any of the resistors around them that protect the set and are bad.
Parts are cheap for this ----less than 30 dollars for everything you will need.
Based on the Pt56wx51e model number this set uses two of the STK-392-110 chips--they are black and side by side on metal heat sinks with fins and will have the full STK number printed on them in white letters.
Most shops get 300 or more for this kind of repair. If you or someone you know can do it you can save a lot of money.
The repair really only involves two things: getting at the chips and parts and being able to unsolder and replace them.
I HAVE START TO FINISH STEP BY STEP INSTRUCTIONS FOR THIS REPAIR ON THIS MODEL. They will tell you everything you need to do the repair and how to do it--I have fixed hundreds of these sets with convergence problems.
If you think you can do it let me know and I will post the full instructions here for you.
Once the problem is fixed the set will not have the same trouble for 5-8 years--lifespan of the parts.
If this has helped you rate this solution as I do this here for free.
SD TECH
Dec 06, 2009 | Panasonic PT-56WX51 56" Rear Projection...
Replace IC Convergance chip in Panasonic PT-56HX41PF
Enter the tip of a pointed knife between the left side edges of the connector (circled in black in the attached pic) and gently tilt the knife away from the connector. Do the same on the right side. The connector should pop up.
Jan 21, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Convergence Problems with red to left of screen.
Replace Both STKs convergence ICs number of part will be on them STK392-110 if this is the number use 180s To order Parts Go To www.electronix.com or Call 1-900-223-3205 These ICs are big black chips.
Dec 14, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Open Questions:
Panasonic PT-47WXC43 47" Rear Projection Television Logo
149 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
