Question about Goodman Heating & Cooling
Where is the filter located? - Goodman Heating & Cooling
  • steve
    steve Aug 28, 2010
    We must have a model number to help you.
    President:
  • 1,515 Answers
Hi, if this is a central system that is split up with the condenser outdoors and the air handler indoors it can be in the indoor unit it self or also it may be in the ceiling or wall near the unit behind a grill for the return air to flow back. Walk around and look for this grill. It is either up high near the air handler close to it, or low on a wall near it. If not out in the home, you will find it in the indoor unit only, nothing outdoors. If you remove a panel you should find it. Please keep me posted and please don't forget to rate me as I no you will be kind. I will check in on you a little later to see if you have found it.
Shastalaker7
A/C, Heating Contractor
Posted on Aug 29, 2010
Where I can locate the filter on the yukon denali 2004
Depends on what filter you are after. The fuel filter should be located on the drivers side frame rail under the front door area. The air filter is located in the air box under the hood, and the oil filter is located under the engine.
Jun 13, 2015 | GMC Yukon Denali Cars & Trucks
Where on the 1997 Jaguar XK8 convertible is the cabin air filter located?
It is located under the panel in front of windscreen
Jun 25, 2014 | 1997 Jaguar XK8
Where do I locate the filter on clothes dryer - simpson ezi set 350
The filter is located inside the dryer at the back of the drum. There are two holes that you can pull on to release the filter.
Here is a YouTube video that shows where the filter is located.
https://www.youtube.com/watch?v=E3r7J5j_I14
Nov 27, 2013 | Washing Machines
Locate fuel filter on 2005 ford focus tdti
Ford Focus 2000-05
Removal & Installation
Print
  1. Before servicing the vehicle, refer to the Precautions Section.
    NOTE The fuel filter is located underneath the vehicle in the area of the rear suspension.
  2. Relieve the fuel system pressure.
  3. Raise the vehicle.
    NOTE To remove the lines, press the quick-release tabs on the connectors.
  4. Remove or disconnect the following:
    Evaporative Emissions (EVAP) vapor line Fuel filter lines Fuel filter and bracket assembly Fuel filter
    Fig. Location of fuel filter and lines.
To install:
  1. Install or connect the following:
    Fuel filter Fuel filter and bracket assembly Fuel filter lines EVAP vapor line
  2. Start the engine and check for leaks.
  4. Remove the fuel filter bolt and remove it from the bracket.
To install:
  1. Position the fuel filter into the bracket. Ensure the fuel flow direction is properly aligned.
  2. Install and tighten the fuel pump bracket bolt.
  3. Lubricate the fuel tube fittings with clean engine oil. Align the fuel tube fittings and press together until a click is heard and then pull on the fittings to make sure they are fully engaged.
  4. Start the engine and check for leaks
May 09, 2012 | 2005 Ford Focus
2000 ford focus in line fuel filter where is it located
Hi, it's back by the fuel tank.
NOTE: The fuel filter is located underneath the vehicle in the area of the rear suspension.
  1. Relieve the fuel system pressure by removing the fuel pump fuse from the battery junction box, starting the engine, and allowing the engine to idle until it stalls.
  2. Raise the vehicle.
  3. Remove or disconnect the following:
  5. Fig. Location of fuel filter and lines.
To install:
Mar 31, 2011 | 2000 Ford Focus
Where is the fuel filter for Mazda MPV V6 3LT petrol filter located
The fuel filter for your vehicle is located on the Fuel Pump Unit, which is located in the vehicle fuel tank. The Fuel Pump Unit must be removed from the top of the fuel tank in order to replace the Fuel Filter.
Feb 27, 2011 | 2004 Mazda MPV
Oil filter location for KIA Borrego 3.8 for filter
This is for a 96' , 3.8L but it's all I could find, but will check again if no help. Let me know.
Nov 11, 2009 | 2009 Kia Borrego
LOCATION OF FUEL FILTER 2005 TOYOTA TACOMA 2.7 4 CYL
Fuel filter is in the fuel pump
module assy. in the fuel tank for both V6 and I-4 models with no recommended service interval.
Jul 26, 2009 | 2005 Toyota Tacoma
Can't find location of fuel filter/
the fuel filter is located just in front of the gas tank
Apr 28, 2009 | Mercedes-Benz 300-Class Cars & Trucks
Engine Air Filter
The engine air filter is located in the box behind the battery. This box should have 4 metal clips that pop off and you and pick up the top of the box and underneath is the filter.
Feb 25, 2009 | 2008 Toyota RAV4
Heating & Cooling Logo
41 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
