Question about Sharp AF-S120MX Air Conditioner
I have a Sharp window unit that keeps shutting off it flashes E-1. what does that mean. How can I make it work?
  • Sharp Master
  • 43,501 Answers
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Posted on Aug 30, 2010
The air conditioner runs for a little while then shuts down and flashes the number 31. I cleaned the unit and the filters, but it still does it. What could this mean?
This may help
1) Disconnect power
2) Hold down on/off while plugging cord back in, til you hear a beep
3)unplug again
4) plug in
5) start a/c
Hope this helped Tim if not then I would call the 1-800-237-4277
Aug 29, 2010 | Sharp ENERGY STAR AF-S60FX...
It keeps flashing E1 on the unit , why ?
heatman101
Aug 26, 2010 | Sharp AF-S85FX Wall/Window Air Conditioner
My unit shut off now displays E1.
Sharp updated the procedure for resetting the E1 code.
1. unplug unit
2. hold the Power button while plugging the unit back in
3. keep holding the Power button until the unit beeps
4. unplug unit again
5. plug it back in and it should be good
Here is the updated user manual
http://www.sharpusa.com/downloads/archives/product_manuals/air_man_AFS100FX_S120FX_S125FX_R100FX_R120FX.pdf
Jun 05, 2010 | Sharp AF-S120FX Air Conditioner
I have a sharp al-1642cs that will not work it just keep flashing L1 can you help
www.cyberscholar.com/sharp/resources/cop_man_soho_AL1642CS.pdf
http://www.service-docs.com/store/catalogue.php?cat=281&exp=0&resultpage=10 L1 00 Feeding is not completed L1 00 Feeding is not completed
within the specified time
after starting feeding.
(The scan head locking
switch is locked)
1.unlock Scanner unit
2. chang connecter
Scanner unit
May 09, 2010 | Sharp AL-1642CS Copier
Ei flashing display unit power cutoff
E1 MEANS FILTER CLEAN AND THEN CHECK IF STILL ON THIS IS ASOFTWARE PROB CAN BE DONE ONLY BY THE SEALER SUPPORT.
Aug 31, 2009 | Sharp AF-S85FX Wall/Window Air Conditioner
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
Error code 13 what does this meen ?
I believe it Means to "Clean Filter"
If that doesn't work Call Sharp Toll Free 1-800-237-4277.
When prompted push for Air Conditioners.
They will help you free of charge.
Hope that helped
Please Rate Me
Thanks
George
Apr 27, 2009 | Sharp Heating & Cooling
Copier flashing between L and 1.
Hello sir;the trouble code display, means the scan unit have problem, check the scan unit does it move forward and backward is ok? or mirror motor not working final check out the scan cable is come off ?
Mar 19, 2009 | Sharp AL-1641CS Copier
Tray 1 is full on my Sharp AL-1642CS but when it ties to print to tray 1 the 'P' keeps flashing!
pull both trays out.....have a look in tray 2, is there a switch sensor actuator hanging down yes........is there a similar one in tray one?
No? They get knocked off and lost very easily
Jun 11, 2008 | Sharp AL-1642CS Copier
Sharp AF-S120MX Air Conditioner Logo
66 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
