Question about Acer TravelMate 4101WLMi Notebook
ACER 5720 T520 DVD Drive
My above laptop will not pick up any dvd's or cd's that are inserted into the drive... The drive has only every work the once, that was yesterday, but today it will not pick anything up that is inserted.
What could be causing this problem?
i bought a lens cleaner from best buy but that didn't help. i don't think i need any upgrade for my dvd drive because i only use the dvd drive for general purpose only. i look at device manager and its there and nothing is wrong with it according from the device manager. i don't know what else to do.
  • chetter1977 May 07, 2008
    i can't use my dvd/cd rom anymore so how else can i reinstall my dvd/cd rom
    take what cover off?
    expose what lens?
    i have a laptop, are u talking about a desk top?
  • 563 Answers
Hi chetter1977
Try reinstalling the drivers for your DVD/CD Rom , should by all means do the trick.
Also remember to reboot the PC once you've done this.
Good luck and thanks for using Fixya !
Posted on May 07, 2008
  • Marnus Jacobs
    Marnus Jacobs May 08, 2008
    Ok , if this drive is totally dead then I would rather replace it with a new one if I were you.
    But you could take the brand and model and search for the driver I spoke about on the net , then you wouldn't need the rom at all.
    If this doesn't work , check if your unit is still under warranty - in wich case they will repair or replace it free of charge.
    If not , then replace it yourself - a CD/DVD rom really isn't expensive.
    Genius:
  • 3,422 Answers
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck..
Please don't forget to rate the solution.
  • Priya darshan May 07, 2008
    My solution no. is 1 so if you want to rate or accept the solution,then please rate sol. no 1
    Hi again,
    You
    I mean this will require you to completely remove your cd/dvd drive from the laptop.But if you cannot do that then you will have to get it repaired and that'd the only solution.
    If you have anymore doubt's please feel free to ask me.
The problem is that the computer is not detecting the cd driver.
You probably need a new CD or DVD drive. Search eBay for your model # and DVD drive. They are fairly cheap and easy to replace. Almost any drive will work from other laptops, you may just have to transfer the bracket and connector from your old one (you just need a small screwdriver). Good luck!
May 05, 2011 | Acer Aspire 5720-4984 Notebook
I have a Acer TravelMate 5720 Notebook and I need to remove the CD/DVD rom . How do I do that ?
there should be just one screw directly behind the dvd drive in the centre of it. you might have to remove the cover for the memory/cpu to get to it. remove that screw, start the laptop, eject the dvd, turn the laptop off and then gently pull the whole drive and it will slide out.
Jan 28, 2011 | Acer TravelMate 5720 T9300 Notebook
My dvd and cd rom does not pick up dvd but only cd's
Is it really a DVD drive? DVD drives can pick both with ease but a CD drive cannot pick DVD's.
Nov 29, 2009 | Acer TravelMate 512DX Notebook
I have acer laptop 5720. My CD/DVD drive failed,
well the only disadvantage there would be moving them together..whereas if u have one fitted in it will reduce that.
Nov 07, 2009 | Computers & Internet
Need to replace cd/dvd rom
Is the laptop still under manufacturer's warranty?
Was it purchased on a credit-card that offers an "extended" warranty?
If not, then purchase an external CD/DVD unit, because that will be less expensive than buying a replacement from the manufacturer, and paying a qualified computer-technician to disassemble your laptop, remove the "dead" drive, and connect the "new" drive.
Jul 22, 2009 | Acer Aspire 5720-6661 Notebook PC
MAY U PLZ ASSIST ME WITH MY ACER LAPTOP ASPIRE 4330 THE DRIVE IS UNABLE TO WRITE ALL THE DVDS BUT IT IS ABLE TO READ DVDS THE ONLY PROBLEM IS BURNING DVDS. HOW CAN I ENHENCE MY DVD/CD-RW COMBO TO WRITE THE...
No Sir, Acer Aspire 4330 comes with different Optical Media Loadings, ( You can see a pdf file here )
Like;
  • DVD/CD-RW combo drive
  • 8X DVD-Super Multi double-layer drive.
But you have the first one, The Combo drive not the super so you can READ both CD's DVD's but can write only CD's.
Hope this removes your dilemma.
If helpful, kindly do Rate!
Jul 18, 2009 | Acer Aspire 5720-6661 Notebook PC
Purchase a laptop
Acer AS2930Z-343G32Mn
Intel Pentium Dual Core T3400 Processor,
Intel GL40 Express Chipset,
3GB DDR2 Memory,
320GB Hard Drive,
Intel GMA 4500M Graphics, 12.1" Acer "CrystalBrite" LCD,
Super Multi DVD Dual Layer Drive,
2.1kgs.,
Windows Vista Home Basic,
Modem,
Gigabit LAN,
Wi-Fi,
Bluetooth,
Card Reader,
Acer Crystal Eye Webcam
Mar 21, 2009 | Acer Aspire 5720 6497 Laptop
Forgotten password
Hello:
If you want to restore your laptop to factory setting: You should insert your "recovery disk to the CD/DVD ROM. and then shutdown the laptop.
Now; boot your laptop using the recovery disk(boot the laptop from CD/DVD rom) This will no need to input the password: its either you have to restore the system without deleting the existing files or you have to partition and format the hard drive. formatting hard drive you will end up with fresh copy of system files. same as first day when you purchase the laptop.
be sure to install the driver if there's any.
However; if you tend to do by supplying the password. iguess all factory installation has no password. you have to strike the enter without supplying any password.
may this help,
melnavz
Sep 11, 2008 | Acer Aspire 5720-6661 Notebook PC
Maybe the lens is dirty so i suggest you CAREFULLY clean the lens with a white clean CLOTH.
please get back to me and tell me the results..
Good luck
Jan 13, 2008 | Acer Aspire 5610-4648 Notebook
Acer Laptop 2413 cd/dvd problem
Yes, this is probably due to a CD/DVD drive that has gone bad. You can purchase a replacement drive from the manufacturer - ACER or you might also want to try looking on Ebay.
Nov 04, 2007 | Acer Aspire 5002WLMi Notebook
Acer TravelMate 4101WLMi Notebook Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
