My fan on my Goodman GSH130241AC quit today. - Heating & Cooling
  • 3,361 Answers
Shannon, this unit is under a 10 year parts warranty from Goodman and the installer.
The problem will be a bad fan motor OR a bad capacitor OR a bad fan relay switch OR a bad wire.
If the compressor is running OK,it is probably a bad motor.
Posted on Aug 28, 2010
Wiring schematic goodman ph036a serial # 9610058720
Is condenser running? Verify amps to be sure both fan and compressor are operating. Should have 2 wires to compressor and 1 to fan on top of contactor. Then on the capactor (herm) terminal is the remaining compressor wire. On fan and c would be the 2 remaining wires for the outdoor fan motor. Then 1 more wire on c that jumps to the top of the contactor on the other side to which the first fan wire connects. GOOD LUCK.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 19, 2017 | Goodman Heating & Cooling
What can I replace my goodman CK36-1B with to be compatible
you need a 5/45 x 370 volt mfd capacitor. I just installed one in the same type of AC today. 5 mfd is for the fan moter and 45 mfd is for the compressor, the 370 is the voltage.
Jul 29, 2012 | Goodman Heating & Cooling
Goodman gas pack unit indoor fan stays on all the time
Problem may be with the high limit switch located above the burner assembly with two wires to flat rectangular looking plate. Jumper the two wires and see if the fan quit's running. If so replace high limit switch.
Aug 22, 2011 | Goodman CKL36AR36 Air Conditioner
How many ton is a gsh130241ac
Hello Cthacker352,
The heat pump that your are refering to is a 2 ton 13 seer unit.
Thank you for choosing FixYa.com
Justin
May 10, 2011 | Goodman Heating & Cooling
I have a goodman furnace/air condition. The fan
start winding going bad or capisitor, either can cause high amp draw and over heat the motor
Jun 13, 2010 | Goodman CLQ36AR49 Air Conditioner
AC fan running backwards
Check to see if it has some wires for reversing the direction. Some have four wires you can switch around to change the direction. If not make sure the capacitor is connected to the start connection and not the run connection. The wires for reversing the direction should be orange and yellow or purple and yellow and will be shorter than the rest. Hope this helps. Let me know what you find.
May 20, 2010 | Goodman GPC1342H21A Air Conditioner
Blower will not shut off
That has to be in the board OR you might have the thermostat set to manual instead of auto. If you suspect the board remove the red wire from the motor to the board and see if the fan quits.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 09, 2010 | Goodman GMS90703BXA Heater
Goodman AC fan working but not cool air.
0204 built the second week of 2004 sound like you have a loose or burnt wire in the a-c and arcing when the unit comes on. turn the breaker off next time you fix an outlet
Aug 02, 2009 | Goodman CKL24AR24 Air Conditioner
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
Heating & Cooling Logo
214 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
