Question about Exceed-RC Dynamite Sava Red 1/10 Off Road Electric Truck
The esc button is nowhere to be found how how can i reset it it keeps blinking and the car wont respond my car is a 1/10 exeed rally truck but thr esc is probably the same style there is an opening on top but there is no reset button
Vxl 3s turns on when i plug in battery, green light comes on, than red, than blinks through the racing and training modes, wont respond with button push
It sounds like it might just be a case of the button being stuck. The ESC shouldn't turn on just from you plugging in the battery, you're supposed to have to press the button once the battery's connected to power up the ESC.
Programming Your Traxxas Electronic Speed Control
Oct 17, 2012 | Traxxas Velineon VXL-3m Speed Control
I turn the netbook on and the blue power button is on, but the screen is still remaining black
sounds like the common BIOS flash fix.
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Nov 29, 2010 | Acer Aspire One AOD150-1920 Netbook
My screen is black what shall I do?
Nov 28, 2010 | Acer Aspire One PC Notebook
Power button is on yet no monitor display? need help
this is a common problem with aspire one netbooks. You need to flash the BIOS
Mar 17, 2010 | Acer Aspire One PC Notebook
Cant enter bios menu
The AA1 has a built-in BIOS recovery routine, which makes it possible to flash the The AA1 has a built-in BIOS recovery routine, which makes it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies, that's why it's also known as crisis disk mode. Use at your own risk.
First format an USB flash drive with FAT.
Download the latest BIOS, extract all files from the zip file, put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the drive. The files must not be in a folder. Rename the BIOS file toZG5IA32.FD, that's important.
Turn the AA1 off, with the USB drive still connected, and make sure both battery and AC adapter are also connected.
Press Fn+Esc, keep it pressed and press the power button. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
If it doesn't reboot by itself, but the power button still blinks, wait a few minutes before turning it off, and try again. BIOSeven if the system doesn't boot anymore. It's only meant for emergencies, that's why it's also known as crisis disk mode. Use at your own risk.
if that doesn't work the link below sells help http://www.badflash.com/
Mar 13, 2010 | Computers & Internet
My aspire one screen is dead. helpdesk told me how to download driver, but did not tell me how to install it
Jan 18, 2010 | Acer Aspire One PC Notebook
Will not boot(I am sure acer had a fix for this problem but I can,t found any reference to this
The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
Nov 23, 2009 | Acer Aspire One PC Notebook
Will not bootup....got a black screen
"Download the latest BIOS, and put bothFLASHIT.EXE and the BIOS file in the root directory of the stick.Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove theUSB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected.Press Fn+Esc, keep it pressed and press the power button to turn theAA1 on. Release Fn+Esc after a few seconds, the power button will beblinking. Press the power button once. The AA1 will now initiate theBIOS flash, do not interrupt it under any circumstances. After a whilethe power button will stop blinking, and the AA1 will reboot shortlyafter. Wait patiently.
The Bios can be found from the Acer site. Source(s): http://macles.blogspot.com/2008/08/acer-aspire-one-bios-recovery.html
Aug 26, 2009 | Acer Aspire One PC Notebook
Turn it on and it wont boot
You need to re-flash bios. I had the same problem and this fixed it!
(Bios can be downloaded from: http://bit.ly/gUf2a)
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS. Source: http://bit.ly/MbbHP
Jul 10, 2009 | Acer Aspire One A150-1006 Notebook
MY COMPUTER WONT START UP!
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Jan 13, 2009 | Acer Aspire One PC Notebook
Exceed-RC Dynamite Sava Red 1/10 Off Road Electric Truck Logo
Top Exceed-RC Toys Experts
jasiel murphy
Tejodhar Atreya...
Tejodhar Atreya...
Tom Chichester
Are you an Exceed-RC Toy Expert? Answer questions, earn points and help others
