Question about Whirlpool Duet GHW9150P Front Load Washer
F06 message - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F06 in your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
What does this error message mean?
Dear BreeAnn,
I would reboot the machine. That means. Turn it off pull the plug and restart or cold Boot Strap. Further open your manual and look for a factory reset. Remove the disc if it came with one and reinstall it.
Save all your creations to file if special programs are developed before the new startup. Manually assist the machine through a hand cycle. Moreover, check to see if all the e-stops are satisfied. That means switches stuck open or closed.
Blow out dust from working areas. It appears from a remote view. Having worked fine. It is a matter of oversight. I hope you get back into creating soon.
The rest of the links are search sites. If you become stumped.
Here is the most direct answer I can find for you. Become a member and place you direct information into the link after reading the reflection.
What is F06 Np Sensor Break on Baby Lock Sewing Machine Yahoo Answers
Here is an E HOW site others are drawn too for answers on that subject as well to expand an accomplishable solution.
Troubleshooting Brother Sewing Machine eHow
Here is another member offering contact sources and a direction on procedure on our network.
F06 np sensor break on brother se400
They are general links. I recommend tech support directly with a talk through. The information should reside in the manual. Fare. Well.
Jun 25, 2014 | Brother SE400 Computerized Embroidery and...
Fagor oven has error code F06
I cleaned the smoke filter, took of the top cover, in front of electronics is the brown smoke sensor. I took of one wire off the sensor, started the oven (beware of not shortcutting anything) the f06 error message had disappeared. I put back the wire, mounted the top cover and the oven functions like new.
Nov 28, 2012 | Fagor 5HA-196 X Single Oven
Flashes error code F06
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its a faulty CCU that needs to be replaced. Here is the part.
Oct 19, 2012 | Sears Kenmore Elite 4.2 cu. ft. Front-Load...
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
F06 error message with flashing remaining minutes
Here is what the manufacture says about F06 - my comments will follow these.
DRIVE MOTOR TACHOMETER ERROR
The control is unable to properly detect motor speed and
the machine will shut down. If a failure occurs during
high-speed spin, the door will be unlocked after three
minutes.
Possible Causes / Procedure
1. Verify the shipping system including shipping bolts,
spacers and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive
motor and the Motor Control Unit (MCU), and between
the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive
motor.
6. Check the drive motor for powered rotations.
Phil's comments--->
If you just set the machine up be sure the shipping bolts have been removed, this is the most common reason for F06.
Other than that there is some type of communication error between the three main components (motor, Motor Control Unit and Central Control Unit) or the wire connectors between the three.
If you have had the unit a while and it is not related to the shipping bolts I would recommend calling Whirlpool
Apr 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine is giving me an error message F06, what does that mean?
F06 is Drive Motor Tachometer Error.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU) .
• Check the Drive Motor .
• Check the MCU .
• Check the Wire Harness .
Please read the below link it is an article about this error from one of the senior and best expert here
http://www.fixya.com/support/t2946429-kenmore_elite_he3t_giving_code_f_06
COURTESY:JSROCK
Mar 21, 2010 | Whirlpool Washing Machines
F06 error
Unplugging it sometimes corrects the problem. However, it must be unplugged for SEVERAL minutes.then start it again i think it ll set it ok becuase sometimes it all sets it right.
or
If all checks ok, then its like a faulty CCU, check your owners manual, some are covered under warranty for up to 5 yrs.
now check the CCU,MCU and Motor any one of these must be faulty that will only lead to F06 error.
Jun 19, 2009 | Kenmore 45087 Front Load Washer
Error code f06
hello fo6 means drive motor techometer error check wire harness connections between the drive good luck
shaun
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I'm getting a F06 error message.
f06 is a fault in the motor controller assy, located on the bottom left corner behingd the lower acess panel. check the wiring prior to rplacing the board though
Apr 20, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
107 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
