Question about Sport & Outdoor - Others
A steady alarm goes off after running motor for a little while.Alarm is located underneath steering wheel.1 wire is going to trim gauges on dash,above steering wheel.The other wire seems 2 be going 2 motor.Not oil-injected,water is shooting out of "tell-tale"hole,&trim oil is fine.What's the 1st. thing 2check?
  • 2,926 Answers
What is the year,make,HP and model of this engine?
Posted on Aug 28, 2010
Disable car alarm
Instructions
Turn off your car engine and take the keys out of the ignition.
Set a flashlight pointing up, under the steering wheel. You need to be able to see the wiring above the brakes and gas pedal.
Locate the alarm box in the steering cavity. The box is usually a small, rectangular box with the brand of your alarm printed on it.
Feel around the box for the wires connecting it to your car's circuitry. Gently pull the wires loose to disconnect the alarm from the car.
Pull the alarm box out of the car and push the wires back into the steering cavity. If the box does not come out easily, check and make sure all of the wires are disconnected.
Jul 22, 2012 | 2005 Saturn VUE
I WOULD LIKE TO DEACTIVATE MY STEERING COLUMN ( RX 330)
in order to accomplish this you have to take the programmed steering position out of the loop. in order to do this y7ou have to install a relay that only activates the when the vehicle is in bypass.when you use the auto start it sends a signal to the alarm to bypass however the steering also gets a pulse you have to seperate the steering circuit from the bypass loop. pulling a fuse won't do the trick . you need a multimeter a relay, piggy back connecters and some wire. you are going to have to use different color wire perferably black white orange and purple so you can clearly identify your circuits. tryinging to keep the steering in one position is not feasiable because it's memory orientated and there for has a link in the ecm and can't be tampered with due to safety issues
May 13, 2009 | 2004 Lexus RX 330
Tip
How to bypass a cars alarm!
first things first... locate the alarms main module. you may have to remove the kick panel under the steering wheel to find it. next remove the cover to the ignition switch, find out which wire(s) are coming from the ignition switch and going into the alarm system, they will be spliced into the box using usually a quick connector or wire nut. take note of the wires colors coming directly from the ignition switch, remove the wire(s) from the alarm box and set aside... Next locate the wires going FROM the alarm box to wires that correspond to the colors of the ones you disconnected, and connect them together back how it was originally. here is a picture i drew on paint to help understand:825be12.jpg
on Mar 20, 2010 | Toyota Corolla Cars & Trucks
How can I reset alarm?
The black reset is to reinitialize the TPMS system.
It sounds like you may have an aftermarket alarm since you described a red reset button under the dash that is not factory?
What I would suggest is to grab a flashlight and look under the dash on the drivers side. You may need to remove a trim pannel to gain access. You should see a black box with a bunch of wires randomly going all over the place (stock wiring is nice and neat comparatively speaking). This will be the aftermarket alarm. There should be a model number on it. Google search that model number and you should be able to find all kinds of info on that system.
Jan 31, 2012 | 2006 Toyota Tundra
Hi, picked up a 1992 dodge steath RT and the seller removed a custom stereo and alarm. The turn signals are not working . all fuses , lamps and haz lamps andtailights etc working.. The denso reg okay...
Yup, the alarm module is usually located under the steering wheel in the dash (it splices into the ignition and wires in the steering wheel) thats where they would have removed the alarm module. Check for broken or unconnected wires under the drivers side dash under the steering wheel. loose broken wires should be able to see. make sure to feel for wires "tucked up in there." You can also try getting a new/used combination switch from parts department or junk yard (turn signal switch and/or hazard switch ) and seeing if replacing that works.
May 04, 2011 | 1992 Dodge Stealth
I have a 1996 Miata where the alarm system goes off no matter what I do to the secuirty switch on the steering column. It can be in the off position or on and open a door and the alarm contiues to go off....
Check wires connections in ALARM WIRING DIAGRAM
Also, its possible that this info helpfull:
- Power Lock - TO DRIVERS DOOR ONLY, See DIAGRAM
- Power Unlock - TO DRIVERS DOOR ONLY, See DIAGRAM
Keepo us updated and send comments.
Oct 17, 2010 | 1996 Mazda MX-5 Miata
Steering wheel covers
I hope this helps....these are the steps to removing and replacing the cylinder:
  1. Remove the knee bolster.
  2. Remove the steering column trim covers from the steering column.
  3. Disconnect the steering column electrical connectors.
  4. Remove the wire harness assembly from the steering column and the wire harness strap.
  5. Slide the 2 connectors of the turn signal and multifunction switch assembly out of the bulkhead connector.
  6. Remove the key alarm connector from the lock module assembly in the following way:
  7. Rotate the key alarm connector 90 degrees.
  8. Pull the key alarm connector out of the lock module assembly.
  9. Remove the passkey connector from the lock module assembly.
  10. Remove the connector from the electric park lock, for vehicles equipped with floor shifters.
  11. Remove the ignition switch from the lock module using tool J42759 or equivalent.
To install:
  1. Install the ignition switch to the lock module
  2. Install the key alarm connector into the lock module assembly.
  3. Push the key alarm connector into the lock module assembly.
  4. Rotate the key alarm connector 90 degrees so that the key alarm connector locks into place.
  5. Install the passkey connector into the lock module assembly.
  6. Install the connector to the electric park lock, for vehicles equipped with floor shifters.
  7. Slide the 2 connectors of the turn signal and multifunction switch into the bulkhead connector.
  8. Attach the wire harness assembly to the steering column wire harness strap.
  9. Connect the steering column electrical connectors to the vehicle.
  10. Install the trim covers to the column.
  11. Install the knee bolster.
  12. Enable the SIR system.
  13. It may be necessary to reprogram the theft deterrent system if the module was replaced.
Mar 06, 2010 | 2001 Chevrolet Suburban
Got a 2000 chevy 3500 express van how do i get the old ignition switch out to replace it
remove the steering wheel , need a puller and locking ring tool, disconnect batt, turn the key to tho on position, and remove bolt that holds the tumbler in,
Nov 13, 2009 | 2000 Chevrolet 3500
Disarm car alarm
Simply disconnect the power leads to the alarm...........sodeep
May 11, 2009 | Vehicle Parts & Accessories
Sport & Outdoor - Others Logo
56 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
