Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
The freezer is warming, ice maker is not working. Food is thawing slowly.
  • Kenmore Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Turned ice maker off prior to a ten day vacation. Upon return, it would make thin shelled ice cubes and finally stopped altogether. Could the water line be frozen How does one de-ice?
Fastest way is to remove the ice maker tray so that you have an open area where the ice maker filling tube is, then cover your food with a towel or something to help prevent it from thawing while you let refrigerator defrost for about 20 to 30 minutes with a hair drier on warm or a small fan blowing directly on ice maker where the water fill tube or opening is. I does not need to be right next to the ice maker just an unrestricted open area to let it warm sufficiently to thaw it out without thawing out your food in the freezer. A small piece of ice can stop the valve from opening and this can happen if it is not used regularly.
Oct 08, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
Kenmore 253.56953601 freezer isnt working properly. food is slowly thawing and ice maker stopped working
I think you have a defrost problem. Look at the inside lower back panel of your freezer. If I'm correct, you will see ice built up. You can take the panel out, defrost with a blow dryer. (After defrosting you can check your heaters. I'm sure you have a bad heater) You can put panel back in and turn the unit back on. It will run ok for around 3 days, This will give you time to repair or get repaired without loosing you food.
Please rate solution
Oct 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
We have a Kenmore Model#363.9552410 that is a side by side with ice maker inside. We noticed the back wall of the freezer was completely frosted over and no ice was being made. We turned off the whole...
Most likely your defrost timer is defective. Located inside the fresh food section and inside a metal box behind the control panel. Turn the timer slowly clockwise until compressor stops. Wait 30 minutes or until compressor restarts If the compressor does not restart turn again until it starts during this time the freezer should be in defrost and sounds of crackling or sizzling is normal. Let me know what you find. The part number for your defrost timer WR9X489
http://servicepartstec.blogspot.com/
Thanks, Sea Breeze
Jun 28, 2009 | Kenmore 50522 / 50524 Side by Side...
My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
May 23, 2009 | GE GSH22JFR Side by Side Refrigerator
Ice maker hasn't worked in years. A couple of days ago food below the ice maker was thawed. Today I felt that the ice maker was hot to the touch. Is there anyway to disengage the power to the ice make
Yes you will need to take the screws that mount the Ice maker to the side of the freezer and unplug the cable plug that is hidden behind the back of ice maker. The only time that element is needed to become hot is the moments before the ice maker drops ice. Thanks, Sea Breeze
May 15, 2009 | Kenmore Refrigerators
The freezer is warming up
If you found something lodged in the door that may have kept it open for a while, i suspect frost formed on the coils behind the panel. Frost will not let air pass through the coils to the refrigerator side. This is one of the most common problems there is. If you look through the louvers on the rear panel that is for sure your problem. It most likely just needs thawed out. After it is thawed out, your normal defrosting routine will take over again and hopefully you will be trouble free again.
May 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Thaw's. Turn-off for period of time it would freeze as normal
Make sure nothing is inhibiting air flow. I don't think it is advisable to store food in an ice machine however that is not likely the problem unless the food itself is inhibiting air flow. Most ice machine manufacturers recommend against storing any food in an ice machine. If there is a freezer component in you model the check to see if the evaporator coils are frosting up and the frost is blocking airflow causing the ice storage chamber to get warm. High humidity can cause frosting. Leaving a door to the ice maker open too long can cause frosting. A low refrigerant charge can do this although it seems logically like it should not. With a very slightly low charge one end of the evaporator gets super cold and the other end is not cold enough. Frosts starts collecting on the super cold end and accumulates across the evaporator coil to the other end eventually blocking all air flow. With too much humidity from open doors frost accumulates over the entire evaporator evenly but still blocks. You shut the unit down. It thaws out and works OK on restart until frost again builds up. If its not a frosting problem but it just stops making ice then the ice may not be releasing. Check the water supply and change any filters to insure good water flow. A good water supply is required for proper release and harvest of the ice in many ice machines. If the ice doesn't release it takes a shut down and thaw to clear the suspended ice out. Check for these things and write back if you need further assistance and can provide me with more details.
Jan 19, 2009 | Hoshizaki Freezer Commercial Ice Machines...
GE side by side not working
Defrost cycle not functioning. Could be defrost timer, timer motor, or defrost heater. I detailed this for someone else. see other solutions.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
309 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
