I have an epsom 1400 using bulk feed subli print ink I have just recharged all the inks, however the printer does not identify that ink is present. red ink light on along with the green light.
  • 1 more comment
  • garymacmchal Aug 28, 2010
    I have re seated the casrtridges and pressed the reset chip, but the problem still exists.
    I have re-seated the cartridges and pressed the rest chip, same results?
    I have re-seated the cartridges and pressed the reset chip, same result?
  • 1,879 Answers
Try re-seating the cartridges.
Posted on Aug 28, 2010
  • 2 more comments
  • monk3ybidzness
    monk3ybidzness Aug 28, 2010
    to add:
    the problem here is the printer isn't getting the signal from your customized cartridge for sublimation use.
    here's what you can do:
    1. disconnect the printer from the computer first.
    2. re-seat the cartridges and while you're at it, clean the contacts on both printer and cartridge.
  • monk3ybidzness
    done re-seating and cleaning contacts, still same issue, we need to identify which is failing, the cart or the printer, if you can test the carts on another printer that will be good.
  • monk3ybidzness
    if it's the printer, try this software or look for other software that serves the same function. at this point service is the best option.
    Still the same.
Epsom print EX-200 wont print after l changed the ink cartridge
Did you pull the tape off the top of the ink cartridge?
Oct 17, 2015 | Office Equipment & Supplies
How can I stop ink spots on photos and documents?
Ink leakage can occur if the bulk ink reservoirs are at a level above the printer. Let the two in the same level.
This can also occur because of quality of paper or ink.
Apr 11, 2012 | Epson Stylus 1400 InkJet Photo Printer
Paper jam light and out of ink light both flashing on epsom 1400
check that there is no paperjam, make off all printer and computer,, then restart,, check.. the catridge level for inks are good..
Sep 27, 2009 | Epson Stylus 1400 InkJet Photo Printer
Epson 1400 won't print blacks
Hi
Many problems regarding Ink with Epson relate to using cheap ink consumables. I recommend you buy original Epson black ink catridge. I know its more expensive but you should see the black ink clear.
Be sure to run head alignment and clean printer option first with the current black ink then replace with the new original Epson ink catridge
Thanks
Andy
Jun 14, 2009 | Epson Stylus 1400 InkJet Photo Printer
Red cast on all prints
Sounds crazy, but have you got the LM (light magenta) and M (magenta) tanks or inks mixed up?
Also - check the profiles, if you've got a colour profile set up, you may have applied it twice, which would make a magenta cast...
Dec 04, 2008 | Epson Stylus 1400 InkJet Photo Printer
Power and ink light on steady
I removed the bulk cartridges and installed the original cartridges, then powered up the printer. Reinstalled the bulk cartridges.
Sep 29, 2008 | Epson Stylus 1400 InkJet Photo Printer
No true colours in Epson Stylus Photo 1400
Given that you are using a dye-sublimation ink I have to ask if you're basing the colours you're getting on the results on your substrate or on the finished product (after you've done the heat transfer).
Beyond that you should probably ask the supplier if they have a colour profile for their inks. If not you can look for one of the services available. I can't make any recommendations but communication with this company has been quite positive
Sep 01, 2008 | Epson Stylus Photo 1400 Printer
Epson Photo RX620
I use a bulk ink system which is not Epson so printer did not recognise the ink supply.
I 1) Turned printer off
2) Removerd bulk ink suppy tanks
3) Fitted Epson ink tanks [ dont matter empty or full ]
4) Turn on printer and let it go through it's start up prcedure
5) Do not turn printer off but do ink change procedure and refit bulk ink tanks
6) Do Nozle Check/Clean/Realignment
Bingo sorted
Jul 20, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Epson Stylus Photo R265 icc problems
Do you mean you are using OEM lookalike cartriges or are bulk refilling cartridges with non-Epson ink?
Thats your answer!!!
Feb 12, 2008 | Epson Stylus R265 InkJet Photo Printer
27 people viewed this question
jasbo
jasbo
