Question about Canon PowerShot SX100 IS Digital Camera
Battery and card door slide is stuck closed
The battery door of my SX100 is stuck closed and I cannot use the camera at all.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey marmof,
I would have it looked at by an authorized service center in your local area, and of course you can always bring it to a Geek Squad® precinct in a Best Buy™ store and have them look at it. I would not try forcing it open as this could cause additional damage to the camera.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 07, 2008
Canon sx100 display card locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 27, 2014 | Canon PowerShot SX100 IS Digital Camera
The battery door switch to open the door,would not slide open.I got the door open, but when I took the 3 screws out to get to the slide the spring came off.Now i'm trying to put it back together, but can't...
This is all I can do for you. Just sending a picture of the battery door spring from my PowerShot G9. I think Canon uses the same principle more than once. I hope this can help. 0544a321-ab53-4e6c-8c99-9fab3dd0040d.jpg
Jan 19, 2014 | Canon PowerShot SX100 IS Digital Camera
Hi, this is a frustioning question. How do you open the battery door. I have an instrucation guide, for I can't figutre it out. Beverly
Hold the camera upside down lens to the right. Slide the battery door release button to the right and at the same time slide the battery door away from you.
Aug 29, 2010 | Canon PowerShot SX100 IS Digital Camera
Camera will not turn on. Changed batteries, sd
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
If you've tried all of the above and still no luck, the problem is then likely to be internal to the camera. One example would be that if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you!
Jul 31, 2010 | Canon PowerShot SX100 IS Digital Camera
Thank you!
Jun 11, 2010 | Canon PowerShot SX100 IS Digital Camera
My Canon Powershot SX100 IS is not switching on, dont know for what reasons. I changed new batteries, still not working. Pls help!
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
May 12, 2010 | Canon PowerShot SX100 IS Digital Camera
Problem started with battery door
The door has an interlock on it. You probably broke the door. The door on some of these cameras can be replaced from the outside. You must make sure the interlock switch is not broken as well. The tabs on the housing of the camera can get bent or snapped off if enough force is used.
A broken door will be $75 there abouts, installed.
A broken detect switch, adds about $45 (A board).
A broken case may set you back an additional $75
Apr 16, 2010 | Canon PowerShot SX100 IS Digital Camera
Powershot sx100 battery slot cannot be opened
Just keep the lock open and slide the lid a bit harder, if your fingers are slipping, use some cloth to assist, it will come open.
Feb 14, 2010 | Canon Cameras
Stuck battery/ScanDisk card
Unfortunately, you have to force the battery door (very carefully) to open it, and find what is wrong with it.
It is more likely that when closed the battery door, it was forced and it slided out of one guide channels.
You need to practice a little bit before to try it with force (genlty but with firm force), but the only way to do it is slide the button to open it, and at the same time slide to the side and pull the battery door, everything at the same time. Try it until you are able to open it.
Using any kind of tool (such a plastic pry tool, a small screwdriver, etc) to force will leave marks in the housing, and it's very possible that the plastic locking tabs will break, causing that you will open it, but unable to close properly again.
Best regards,
Mar 10, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Stuck battery door on dsc p93a
There is usually a lock on the inside of the door. Sometimes you can move that while the door is open, else play with the release switch. Once you get it in the open position it should close
Jun 06, 2008 | Canon PowerShot SX100 IS Digital Camera
Canon PowerShot SX100 IS Digital Camera Logo
462 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
