Question about Kitchen Ranges
My husband is trying to wire a new pressure switch for our well. It is located under our home. Can you explain how to rewire it. There are 2 black wires and 2 white wires. We need to know which is the load and which is the line.
  • Kitchen Ranges Master
  • 3,361 Answers
The pressure switch is marked for LINE and LOAD.
Line wires come from your power supply to the switch.
Load wires come from the switch to the well pump.
Most likely the black AND WHITE wire from the power supply go to the 2 center terminals on the switch.
The black AND WHITE wire from the well go to the 2 outside terminals on the switch.
Posted on Aug 28, 2010
Need help rewiring two single celing fan and kitchen lights wall switches.
Two single switches operating a ceiling fan and a ceiling light?
Aug 06, 2017 | Electrical Supplies
Drilled well - no pressure, no water - what,s wrong?
1) Click the breaker all the way off as far as it will go, and then click back on. Check if well is pumping.
2) Turn power off. Go to pressure switch and remove cover.
Following link shows pressure switch.
http://www.northerntool.com/images/product/images/16151_lg.jpg
Remove cover on pressure switch. Power if OFF!!!
Check if all the wires are firmly screwed down under each screw terminal.
Next, see if contact points are stuck together. There are 4 sets of points.
Push contact points apart if they are stuck.
Inset nail file between points. Push points together and hold firmly and draw out nail file to file off the carbon deposits.
Repeat 2-3 times to each set of points.
Turn breaker ON and check for sound of pump.
3) Move wires to another same size circuit breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) call local well service company
5) Make sure husband does physical therapy exercises to improve function of hip. Hope you're doing better soon.
Jul 29, 2012 | Electrical Supplies
REWIRE THE POWER CORD THE POWER CORD WAS RIPPED OFF BY MY SWOON TO BE EX HUSBAND BY HIM RIPPING IT OUT OF THE WINDOW. THERE IS A GREEN, WHITE AND BLACK WIRE. WHERE DO THE BLACK AND WHITE WIRES GO?
Its easy to do but difficult to explain here. I think it best to have someone with a bit of electrical skill to do this for you . Sorry i cannot help you as much as i would like. Good luck. jon
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
I have a new fan motor for a ge for a ac unit for outside home and the old is a 4 wire and new is a 3 wire has black,yellow,brown the old 1 has black,brown,red,blue or purple wire how do i rewire thie...
this soounnds as though it for a 2 spped fan motor look at the old motor and see the RPM and then look at the new motor plate it shuld show ou which wire is for the speed required. Hope this helps ..Jon
Jul 25, 2011 | Heating & Cooling
2 switch system. 2 black wires and 1 red wire in the switch. I have hooked up black wire from the switch to the red wire in the box. green wire from switch to black wire from the box and red wire from the...
You posted under ST01C and are wiring timer to replace 3-way switch.
Open following link for specific illustrations:
http://waterheatertimer.org/ST01C-program.html#ST01C
http://waterheatertimer.org/pdf/ST01C-explanation.rtf
1) The timer replaces one of the 3-way switches. The other 3-way switch remains, but must be rewired.
2) The timer must replace the 3-way switch that receives power from breaker box. It cannot replace the other 3-way switch. This is because the timer Black wire must always receive power.
3) The timer blue wire must connect to Load (light)
4) The ST01C red wire is only used when wiring for 3-way.
5) When the red wire and blue wire are connected together, they reverse the timer program. When timer red and blue are disconnected, the timer resumes programming. Connecting and disconnecting the red and blue wires is how the timer mimics 3-way operation.
6) The remaining 3-way switch must be wired so it will connect and disconnect the red and blue timer wires. So the remaining 3-way switch has to be rewired to meet specific timer wiring.
Jul 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Yes, my husband has been trying to get our well up and running again, so he bought a new pressure switch (which consist of the red, green, & black wires) and every time he thinks he has it wired...
Here is a picture of a Square D Pressure switch wiring
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 03, 2011 | Plumbing
A CH pressure sprayer PW175000AV Ser# 00842 was electrically taken apart without noting how wires were to be reattached. There are 4 male spade connectors on rocker switch which works fine. Power has...
Hello Woodnflies,
I understand that you need to rewire your pressure washer. I understand that you already have the switch wired and the motor wired as they are working. You need to power the pump that has a white (common) male and a black (hot) female. You what spade connections do you have open to connect too.
You should have a black and a white that have nothing attached to them this is where the pump wires are going to attache in the circuit.
Thank you for choosing FIxYa.com
Justin
May 05, 2011 | Campbell Hausfeld PW1750 Electric Pressure...
My husband has just fitted a new fan to my white night dryer wk447 had to take motor out to put it in but my have rewired it wrong there are 2 brown and 2 yellow wires that clip in we can hear motor...
Orange goes to connector then Black to Motor
Brown goes to Capacitor then Brown on to Motor
Yellow goes to Capacitor then Brown on to Motor
hope this helped Tim
Feb 19, 2011 | Whirlpool Dryers
How do you change a 2 wire ballast to a ballast with a black and white wire,2 reds and two blues.I have a 2 tube 18 inch fluorescent lamp with 2 ballasts in it.Each ballast has 2 wires coming out of...
Dear sir
first do not confuse by the colour of ballast wire, now see black and white wire who is coming from the ballast and find out after that you have to remove it from the joint . and other new ballast replace here and it's wire connect here with that point where you has remove wire black and white wire first from here. and try to fix fluorescent light here and after that try to switch on electric supply for testing. i hope after that it will work.
thank you
hope answer the question
please vote!
Dec 14, 2010 | Cooper Industries Cooper Wiring 2504W...
Have no voltage to fuel pump. have checked fuse, relay, and replaced fuel oil pressure switch. still nothing
You are checking on the gray wire at the pump.
This wire will ONLY have power for 2 to 3 seconds after key is turned to run position after key has been OFF for 10 seconds.
.....or when there is oil pressure.
If you do not have power under these conditions.....run a new FUSED power wire to the pump/pump wiring that has only power when the key is on.
The other way to fix this is usually a rewire of the relay center/fuse box to supply power to the fuel pump relay when the key is on.
Aug 23, 2009 | 1998 Chevrolet S-10 Pickup
Kitchen Ranges Logo
132 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
