Question about Pentair Minimax NT Heater
I have a Pentair 400M LP gas pool heater. I can get the pilot light to ignite, but when I turn the switch the "pool" setting & adjust the thermostat (as high as it will go), the valve will not respond to ignite the burners. Where should I begin to solve the problem?
    Top Expert:
  • Pentair Master
  • 8,163 Answers
Check safety circuit
Posted on Nov 23, 2017
3 Suggested Answers
  • 10 Answers
SOURCE: Pentair 250 CH LP will not ignite. Pilot works
to test the presure sensor jump the wires that plug in to the sensor if it turns on the presure sensor is bad and the the thermostat do you mean thermo sensor the one that checks the water tep follow the wires to were they plug in turn power off get your finger wet and put it were it plugs in on the 2 prong and turn it on the heater will light up if the sensor is bad
Posted on May 19, 2009
  • 246 Answers
SOURCE: Pentair Minimax 250M
how many times it blink will tell you what is wrong check at the codes. unplug thermostat check fo homs 10 k around is fine at 80 degrees pressure switch require a by pass but DO NOT RUN THE HEATER WITH A BY PASS ANY CONTROL!!!!
Posted on Sep 19, 2009
250 lp heater stops and starts
standing pilot heater or electronic ignition???? could be a result of many diff things......gas valve coils could be shorting out....an electrical short somewhere.....safety is opening/closing
Nov 25, 2013 | Pentair Pool & Spa
I have a Pentair Minimax CH 250M pool heater. When I opened my pool, the heater started up fine and heated the pool initially. However, since the initial heater it has not come back on, and the pool is...
Do you have 24V at the brown wire of the gas valve? If you do then it is probably a bad gas valve.
If you don't have 24V on the brown wire it is probably the ignitor.
Jun 04, 2011 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Pentair Minimax CH Propane Millivolt Ignition Heaters error E05 what is it?
If you are firing, and then going off and getting an E05, your igniter is to blame. It may be glowing but it's getting weak. The diagnostic goes further but that is usually the fix.. With inactivity, the igniter is always to blame. You really need to fire it off weekly to make it reliable and make sure that your heater is serviced at least one time a year to keep all the internal components operating as designed.
  • PILOT ASSY LP MV CH150 IID
  • Manufacturer: PENTAIR WATER POOL AND SPA INC
  • Manufacturer Part #: 471291
  • Description: Propane pilot assembly for heaters with millivolt ignition.
  • Retail Cost: Approximately $65.00
Dec 08, 2010 | Pentair Minimax Ch 200,000 Btu Propane...
I have a Pentair Mastertemp 250 pool heater with an error message E05. What does this mean?
This is an ignition flame falure code. Could be you don't have gas getting to the pilot, no spark to ignite the pilot or your ignition is not reading the flame. Sorry to say but it's probally time to get the pool guy out to look at it. Good luck.
Apr 15, 2010 | Pentair Mastertemp Heater
Do not know how to start pilot light
There should be instructions on the inside of the heater access door. Make sure you are comfortable working with gas heaters. Make sure the shutoff valve supplying gas to the heater is on. Turn the gas valve to "pilot", press and hold it while attempting to light the pilot. Once the pilot is lit, continue holding the gas valve knob down for about 30 seconds. The pilot should stay lit once you release the knob. If the pilot stay lit, turn the gas valve to "on". Replace the heater access door and make sure you have proper water flow and attempt to light the heater. If it will not light, or the pilot will not stay on, you will probably have to replace the pilot generator. It provides voltage to run the heater and after time it wears out and produces less and less voltage. A millivolt heater runs on less than one volt so any power loss can be a problem. If you are able, test the pilot generator with a multimeter to see if you are getting at least 500mv when the pilot is on. If not, you should replace the pilot generator or even the entire pilot assembly. Hope this helps...
Sep 27, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
New ignitor..still won't light
Clean out the pilot assemby or replace it. It is probably blocked by rust and/or spiders and is not letting enough gas (if any) through.
Jun 18, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Jun 17, 2009 | Pentair 250k Minimax Ch Ng Mv Heater
I have a Mini Max 100 pool heater. The pilot
check pressure switch for proper adjustment and make sure filter is clean so system pressure is normal
Jun 07, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Jun 05, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
May 11, 2009 | Pentair 250k Minimax Ch Lp Mv Heater
Pentair Minimax NT Heater Logo
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
