Question about Palm Treo 750 Smartphone
Resetting data I am selling my treo 750 and need to erase all the information and settings. Can someone help me with this. Thank you
  • kzl1 May 09, 2008
    Thank you very much, It worked and I appreciate it.
  • Anonymous Jan 13, 2009
    Trying to do a hard reset...the yes button is not responding.
A Hard Reset wipes the internal memory and returns the Treo to its factory specs, in effect returning the Treo 750 to the state it was in when you purchased it. All data entered, preferences set or software installed on the Treo after purchase will be lost after a hard reset and will have to transferred or reinstalled via ActiveSync / Windows Mobile Device Center.
resetting data - power_button.jpg The Palm Treo 750 can be hard reset by pressing and holding the power button (seen left) while at the same time pressing and holding reset button beneath the miniSD memory card door. Press and hold the two buttons until the screen completely fades. When the screen returns, you'll be given the option to "Erase all data." Select Yes to complete the hard reset.
The Treo will now be as it was when it left the factory and you can start fresh. You may have to perform a soft reset after the hard reset to get the unit to power on.
Posted on May 09, 2008
How to wipe iPhone cleanly
"Erase all content" means all of YOUR content, including all applications you have downloaded and all the data for those applications and all the data for Apple applications (i.e. Mail, Photos, Calendar, Safari, etc.) will not be completely removed from the device, they still remain on your iPhone and can be easily recovered by some iPhone data recovery.
I highly recommend you to try Safewiper iPhone data eraser app to complete your iPhone data, it will be the best choice when you need to sell your old iPhone or iPad.
How to Permanently Erase Contacts from iPhone Before Selling
Dec 16, 2015 | Apple iPhone Cell Phones
Palm Treo 700W Smartphone is stuck on speaker phone
Soft Reset
A Soft Reset stops all active (or open) programs and "reboots" the handheld. When the Treo powers back up, you'll start with all programs closed and the unit will be ready to use. The soft reset is intended to reset the Treo if it is malfunctioning or has become bogged down.
The Palm Treo 750 can be soft reset by quickly pressing and releasing the tiny red button beneath the miniSD memory card door:
diagram.jpg Hard Reset
power_button.jpg The Palm Treo 750 can be hard reset by pressing and holding the power button (seen left) while at the same time pressing and holding reset button beneath the miniSD memory card door. Press and hold the two buttons until the screen completely fades. When the screen returns, you'll be given the option to "Erase all data." Select Yes to complete the hard reset. The Treo will now be as it was when it left the factory and you can start fresh. You may have to perform a soft reset after the hard reset to get the unit to power on.
May 11, 2008 | Palm Treo 700w Smartphone
I have a Palm Treo Pro. Unwittingly (stupidly), I unaligned the screen to such an extent that I cannot access the start button. the hard button has the same result as going to the position of the soft...
The following steps will erase all the information from your phone, if possibly try to sync your phone first.
1. Take the back panel off to expose the reset hole.
2. Press Power to turn on the screen.
3. While pressing and holding End, use the tip of the stylus or a small paper clip to press and release the Reset button.
4. Continue pressing and holding End until the Erase all data? prompt appears.
5. Press Up.
6. Wait for the progress bar on to fill up, then you can use the device again.
Jun 30, 2010 | Palm Treo Pro Smartphone
Palm Treo 750 "no service"
my favourite (treo 750) i own 1 but not sure i have had that problem yet depending on if you install a program it could be causing that problem maybe a call blocker! u could check to see if ur network is on automatic
start-setting-personal-phone-network-netselection automatic
try backing up your phone data then master reset back to factory setting
N.B you would loose everything that cannot be backed up but this solved my bluetooth problem 1 time holding down the reset button then press power. when prompted to reset say yes
Feb 01, 2010 | Palm Treo 750 Smartphone
Palm treo 755p tried removing battery and still only says treo across the screen and reset button dont work
in order to perform a hard reset, you take out the battery. hold the power button and insert the battery.
release the power button when you got palm/access powered. it should prompt you to erase all data. press up to erase and finish setting the device. no need to reinstall the palm desktop software.
Nov 09, 2009 | Palm Treo 755p Smartphone
How do i reset my palm treo 750
Soft reset = push button behind the SD card door with stylus.
Hard Reset (WILL ERASE ALL DATA) = push same button after holding down the red phone button.
Oct 09, 2009 | Palm Treo 750 Smartphone
How do I reset my pal tro 750 to factory settings
These steps will erase all data from the device. You may want to synchronize if possible before trying these steps.
  5. Press Up.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 21, 2009 | Palm Treo 750 Smartphone
Hello i have a palm treo 750 and i for got my pass code and cant get back in it how can i do a reset r a hard reset either one
You can hard reset a Treo 750 by pressing and holding the power button while pressing and holding reset button beneath the miniSD memory card door at the same time. Press and hold the two buttons until the screen goes black. When the screen returns, and you see the option to "Erase all data" select Yes and your device will be hard reset.
Jan 31, 2009 | Samsung SGH-e315
Palm Treo 750 Data Transfer
If you need further help just message me.
Sep 25, 2008 | Palm Treo 750 Smartphone
Palm treo reset
You want to perform what is called a "Hard Reset"
It's pretty easy. You hold the power button while you push the reset button on the back. The treo will ask you if you want to erase all the data.
  • Unscrew the tip from your stylus
  • Locate the "RESET" hole on the back of your Treo 600
  • Press and hold the power button on the top of your Treo and then press the reset button with the stylus pin
  • Remove the pin from the reset hole FIRST, hold both for a few seconds, and then release the power button.
  • The screen will say "erase all data?", tap the up arrow to answer yes
  • Here is a explaining what I just said above:
    http://mytreo.net/archives/2004/05/hard-reset-the-treo-600.html
    Sep 22, 2007 | Palm Treo 600 Handheld
    Palm Treo 750 Smartphone Logo
    220 people viewed this question
    Top Palm Computers & Internet Experts
    MUSTAFA BULENT...
    MUSTAFA BULENT...
    David Payne
    David Payne
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
