Question about Sony Playstation 3 (PS3) Console
Can you explain the error codes: 80022D86 and 80022D05 please?
  • p_a_daniels Aug 29, 2010
    Will a system restore correct whatever this fault may be?
  • 1,711 Answers
You could try either...
1. deleting the game data (NOT SAVE DATA) and then restart the game.
2. rebuilding database...
1) have the system off
2) press and hold the power button until the system shuts itself off again
3) press and hold the power button until you hear 2 rapid beeps (if it doesn't work so step 2 twice)
4) connect the controller with USB and turn it on
5) go down to option 3 (rebuild database)
6) press X, it will reboot and it will tell you "the hard drive is corrupt" or something like that, proceed
7) fingers crossed it's then ok.
Posted on Aug 29, 2010
    Genius:
  • 1,416 Answers
these codes has to do with game forth meaning that the game memory is forth
However, what these codes 80022D86 and 80022D05indicating is that the hard drive of the game (that is) PS3 is corrupt or Ps3 will not read game disc, only bluray movies.
what you are to do to fix up this problem is to unscrew the system then trace the lens clean it carefully with a spirit together with a cotton wood then also couple it back to is position but if this fail the you will have to replace the lens with a better one .
thank you and thanks for using fixya.
Posted on Aug 28, 2010
  • Oloyede Monsuru Aug 29, 2010
    hello,
    the answer is Yes.
    only if you can apply to the instruction giving to you
    thank you.
Error code & solution
HI there
can you please inform us what's model of control box? there is no error named E815 !!!! please we need more explain to help you.
thanks and best regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Jan 02, 2014 | Juki DDL-8700
Please explain why you think this is an error
Why does who think what is an error? Has FixYa ever told you something was an error? If so, what?
Oct 19, 2013 | Facebook Social Network
Jul 31, 2013 | Facebook Social Network
Vw fault codes 01284 01314 13265 can you explain please
we have a vw amarok 11 plate and the po 02299 fault code has come on. what should we check.
Jul 18, 2013 | Cars & Trucks
LG washing machine loud and error code LE
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Jul 02, 2011 | LG WM2301HW Front Load Washer
Please explain error code 000000
how the error code E000000-0000 is solved...give the solution
Apr 05, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
What does L 21 error message mean on my whirlpool frontload washing machine
There is no "L21" error code on a Whirlpool Duet model washer. There IS an "F21", however. This is a Long Drain error code which is usually an indication that you may have an obstruction somewhere in the drainage system. Most commonly, there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: A "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If the error I've explained does not match the symptoms of what your washer is doing, please elaborate a bit more, so I can provide you with better assistance.
Mar 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
There is an error code f70 and there was an error code f71.
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
Sony Playstation 3 (PS3) Console Logo
905 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
