Question about Philips 19PFL5522D/05 widescreen HD ready LCD TV
Question is for a: Philips 19pfl5522d/05 TV Set......every time is turned off and then back on, the setup screen will come up and asks for the channels to be scanned. If we don't do this we can't watch it!
  • 201 Answers
When you run the scan does it indicate that the scan is complete? Some tvs if you don't go through all the steps it wants it will do that. If you have completed it then the mother board (main board) of the TV is the most likely suspect. You might try going on Phillips website to see if there is a software update for that issue. Otherwise replacing the mother board would be the only other option and it would most likely be cheaper to replace the tv at that point.
Posted on Aug 28, 2010
  • ndefernandes Aug 28, 2010
    OMG not liking the mother board stuff sounds nasty :( yeah we complete the scan every time to 100% it is a fairly new set. I'll check on the website thank you for your answer!!! :)
I have a philips 19PFL5522D/05 and can't seem to get the stand off (we want to wall mount it). Any suggestions?
To know more about this, you have to download the repair manual to this set. Its disassemble section has all details. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Jan 08, 2015 | Philips Televison & Video
How do i fix a black screen?
It will be best to contact the authorized service center. Especially to Philips Brand devices.
The problem is with its back-light.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jul 30, 2014 | Philips 19PFL5522D/05 widescreen HD ready...
Why does my tv go into setup mode every time i switch it on
There is a power issue. Are you using a power bar to turn it on and off? If so, don't.
Jun 06, 2014 | Philips Televison & Video
Can I get the user handbook for model no 19PFL5522D/05 e mailed to me free of charge?
sure, click this link to download
http://www.nodevice.com/user_manual/philips/tv1/19pfl5522d05.html
enter the image verification to the buttom, click download select a server and download your manual.
Apr 04, 2011 | Philips 19PFL5522D/05 widescreen HD ready...
I have a` Phillips 19PFL5522D/05. Won't switch on and the power indicator is flashing green, intermittent. Customer Service told me this is a mode to prevent damage to TV. Can't be rectified by user and...
Had the same problem with this model.
1) Open up the TV by undoing all the screws - they are what I think are torx screws, but any decent screwdriver set should have the correct attachment.
2) The smaller brown board where the power supply comes into had 4 1000 pf 'popped' eletrolytic capcitors - the tops were bulging, a sure sign that they have blown, although it's not always the case - I would suggest replacing bulged ones first and test the others if this doesn't do the trick.
3) I replaced the capcitors - delsoldered and resoldered new ones in place. I got a set of capacitors from Maplins for £9.99 but you could probably get them cheaper elsewhere. I didn't have an exact match for the voltage but I replaced 16v ones with 25v and it seems quite happy.
Hope this helps. Be aware there are high voltages present in capicitors even when you've unplugged the mains. You should always discharge them using a shunt resistor.
Jan 18, 2011 | Philips 19PFL5522D/05 widescreen HD ready...
Philips 28PW6006/05 locked after setting "NR" to Yes...
NR=Noise Reduction.
If set is locked you must use the parental code to unlock.
Aug 29, 2009 | Philips 28PW6006 28" TV
50p8341 on-screen menu
05/09/08
I called the Philips help number (1-888-PHILIPS) and the tech had me turn off the tv and then unplug it from the outlet, wait 1 minute, then plug it back into the outlet, then turn the tv back on. It reset the menu memory and it is now back in the middle of the screen where it belongs.
Feb 23, 2008 | Philips 50P8341 50" Rear Projection...
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
How do I remove on screen tutorial
first question... can you go through the tutorial?
Aug 01, 2006 | Philips Magnavox MT1931B 19" TV
Philips 19PFL5522D/05 widescreen HD ready LCD TV Logo
446 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
