Question about Sony KP-65WS500 65" Rear Projection Television
How do i find the 2 ic chip in my kp 65ws500 to repair my convergence problem?
  • 201 Answers
The 2 chips are on a large metal heat sink near the back of the tv. They will be on the opposite side and will have stamped on them (example) STK392-560. You may also have a blown pico fuse (look like a solid colored resistor part number on board will be like (example) ps8001, you'll need a meter to check if any are open or not most times they are. RepairKits This website will take you to a place to buy the parts you need to fix it. good luck.
Posted on Aug 28, 2010
My sony kp 65ws500 has a all red picture. It looks fine otherwise. nothing i have tried has changed the color of the screen at all. Please help.
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it dead.The tv convergence board must be replacing the 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Sony KP-65WS500 65" Rear Projection...
The bulbs are all working. The picture has shrunk into a saddle shape. The focus is off.
Symptom shows tv got convergence output chips failure problem, this tv has two big convergence output ICs/ chips on D board that will be replaced to get back correct picture.
If you are handy with electronics stuff repair and can replace/ solder parts in circuit board then let me know to provide you more technical info OR local tv repairman will do this job for you.
Thanks.
Dec 27, 2010 | Sony KP-65WS500 65" Rear Projection...
THE PICTURE SHOWS TSO IMAGES SIDE BY SIDE AND THE
If it looks 3d you have a convergence problem.
This model should use two of the STK-392-560 convergence chips for this circuit.
Both will have to be replaced and a few other easy to check parts tested also.
If you have some expertise or have a friend who does I can step you thru the repair.
Parts cost will be if purchased on EBAY (I have seller I can recommend there) under 30 dollars total.
Let me know if you have questions and thank you for using FIXYA.
SD TECH
May 21, 2010 | Sony KP-65WS500 65" Rear Projection...
Sony KP-65WS500 Rear Projection TV About a week ago the left side of the screen started to a slight blue halo over faces, hands, and some of the white letters were light yellow. I adjusted the convergence...
Thats a convergence failure issue. The Sony Type 1 convergence repair kit available from www.tvrepairworld.com is the kit your model uses. The kit contains the parts and the CD with instructions.
Dec 20, 2009 | Sony KP-65WS500 65" Rear Projection...
Double image ( Ghost image )on Sony KP-65WS500
Replacing the Convergence ICs should fix the problem. They are located on the Deflection board. Sony has used a couple of different ones over the years I think they are STK-392-120's but please do not hold me to it.
Hope this helps,
Skyassoc
Jun 25, 2009 | Sony KP-65WS500 65" Rear Projection...
The convergance is out on ny sony kp65ws500 how do ifix this problem
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
May 19, 2009 | Sony KP-65WS500 65" Rear Projection...
Massive Convergence problems even after replacing IC's.
See a pico fuse HERE and find PS8001 to PS8006 on D board of TV
Mar 18, 2009 | Sony KP-65WS500 65" Rear Projection...
Horrible Convergence Problem on Start
I doubt it. In a problem like this it could be a power supply that feeds the convergence ic(s). The longer you wait to have this problem taken care of the more of a risk your taking of blowing out the ICs, if there already not bad. Its highly unlikly all three ics went bad at once, unless of a power supply problem. Now this set is not serviceable by the end user as its solid state and all parts are soldered in. Also theres alot of HI Voltage inside this set!! Have the set checked out by a technician ASAP for a bad filter capacitor in the b+ line that feeds the convergence ics Good Luck
Jul 03, 2006 | Sony KP-65WS500 65" Rear Projection...
Sony KP-65WS500 65" Rear Projection Television Logo
75 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
