2005 phillips crt 27 inch tv
Top pf picture is black about 2 inch in diameter
    President:
  • 894 Answers
Okay we have this phillips tv from 1986 and when I turned on the tv this morning the tv screen was all black and it made a loud noise so my dad cleaned it out and no luck. Is the picture tube gone then? Where can you get an old tv fixed like that then its about 15 yearsold too.
Posted on Aug 16, 2011
  • 71 Answers
Need electrolytic capacitor replaced in vertical circuit
Posted on May 10, 2008
I have a 2007 Recon ZX 36V Toyhauler. I am trying to figure out which of the 3 dump valves are which, black-grey1-grey2. I haven't been able to find any schematics or pictures to help me. HELP
You'll probably have to crawl under and trace where they go. You could possibly put some dye in one of the grey water tanks (ie: the kitchen sink drain or bathroom sink or shower drain) to figure out where it comes from. The black tank is your toilet drain. It always has the larger diameter pipe going to the valve (usually 2 or 3 inch diameter) The grey water tubing is usually 1 1/2 inch tubing.
Dec 27, 2016 | Jayco 2008 Recon ZX F36V
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
Where are the heater hoses under the hood?
I don't have one like yours sitting in front of my house, but here goes.
On most cars, the hoses to the air cleaner are the largest, about 3 inches to 6 inches in diameter.
Next smaller are the radiator hoses, usually there are two, one at the top of the radiator and one at the bottom,
These hoses are usually about 2 inches to 3 inches in diameter. Next smaller are the heater hoses.
There are usually 2.
These are normally from 1 inch to 1& 1/2 inch in diameter, and traditionally are from the engine to the firewall, which is the metal wall in front to the car's interior.
In today's modern cars, it is not unusual that you would have a really hard time finding and seeing the heater hoses, because of their location.
Next smaller are vacuum lines or water hoses for the engine, from 1/2 inch to 3/4 inch diameter.
Most all hoses are black.
If someone can show you all of the parts under the hood and what they do, you can tell the heater hoses by where they go, to and from.
Be blessed.
Feb 14, 2013 | 2000 Kia Sportage
What is the clearance for rod bearings on the crank of a 98 ford f 150 4.6
General Specifications Item Specification
Displacement L (CID) 4.6 (281)
Number of Cylinders 8
Bore and Stroke mm 90.2 x 90.0
Firing Order 1-3-7-2-6-5-4-8
Oil Pressure (HOT @ 1500 rpm) kPa 138-310
Drive Belt Tension a
Cylinder Head and Valve Train
Combustion Chamber Volume cm 52?±.5
Valve Seats Width?€"Intake mm 1.9-2.1
Valve Seats Width?€"Exhaust mm 1.9-2.1
Valve Seats Angle 44.51-45.01 degrees
Valve Seats Runout (T.I.R.) Max mm 0.025
Valve Arrangement (Front-to-Rear) (Left Hand) E-I-E-I-E-I-E-I
(Right Hand)
I-E-I-E-I-E-I-E
Valve Stem to Guide Clearance?€"Intake mm (Inch) 0.020-0.069
(0.00078-0.00272)
Valve Stem to Guide Clearance?€"Exhaust mm (Inch) 0.045-0.095 (0.0018-0.0037)
Valve Head Diameter?€"Intake mm (Inch) 44.5- (1.75)
Valve Head Diameter?€"Exhaust mm (Inch) 34.0 (1.34)
Valve Head Diameter?€"Gauge Diameters mm (Inch) 42.5- and 32.0
(1.67 and 1.26)
Valve Face Runout Limit mm (Inch) 0.05 (0.002)
Valve Face Angle 45.25-45.75 degrees
Valve Stem Diameter (STD)
?€"Intake mm (Inch) 6.995-6.975 (0.275-0.2746)
Valve Stem Diameter (Std)
?€"Exhaust mm (Inch) 6.970-6.949 (0.274-0.2736)
Valve Springs?€"
Compression Pressure N @
Spec. Length?€"Intake 587.14 N @ 28.02 mm
Valve Springs?€"
Spec. Length?€"Exhaust 587.14 N @
28.02 mm
Valve Springs?€"Free
Length ( Approximate)?€"
Intake mm (Inch) 49.55 (1.951)
Length (Approximate)?€"
Exhaust mm (Inch) 49.55 (1.951)
Valve Springs?€"Installed
Pressure N @ Spec. Length
?€"Intake 244.64 N @ 40.0 mm
Valve Spring?€"Installed
?€"Exhaust 244.64 N @ 40.0 mm
?€"Service Limit 10 % Pressure Less @ 28.02 mm
?€"Out of Square Limit 2 degrees
Valve Guide Inner
Diameter mm (Inch) 7.015-7.044 (0.2761-0.2773)
Rocker Arm?€"Ratio 1.75:1
Valve Tappet?€"Diameter
(STD) mm (Inch) 16.000-15.988 (0.66-0.629)
Valve Tappet?€"Clearance
to Bore mm (Inch) 0.018-0.069
(0.00071-0.00272)
Valve Tappet?€"Service
Limit mm (Inch) 0.016 (0.00063)
Valve Tappet?€"Hydraulic
Leakdown Rate b 5-25 seconds
Valve Tappet?€"Collapsed
Valve Tappet Gap?€"
Desired mm (Inch) 0.085-0.45 (0.0033-0.0177)
Camshaft
Lobe Lift?€"Intake
mm (Inch) 6.58939 (0.2594)
Lobe Lift?€"Exhaust
Lobe Lift?€"Allowable
Lobe Lift Loss mm (Inch) 0 (0)
Theoretical Valve Lift @
Zero Lash?€"Intake
mm (Inch) 12.0 (0.472)
Zero Lash?€"Exhaust
End Play mm (Inch) 0.025-0.165
(0.00098-0.0065)
Journal to Bearing
Clearance mm (Inch) 0.025-0.076
(0.00098-0.003
Journal to Bearing
Clearance?€"Service Limit
mm (Inch) 0.021 (0.0048)
Journal Diameter (All)
mm (Inch) 26.962-26.936
(1.061-1.060)
Journal Diameter (All)?€"
Bearing Inside Diameter
(All) mm (Inch) 27.012-26.987
(1.063-1.0625)
Camshaft Runout
Cylinder Bore
Diameter?€"Surface Finish
(RMS) 0.2-0.6 Microns
Diameter?€"Out-of-Round
Limit mm (Inch) 0.015 (0.0006)
Service Limit mm (Inch) 0.020 (0.00079)
Diameter?€"Taper Service
Limit mm (Inch) 0.006 (0.00023)
Piston
Piston?€"Diameter?€"
Coded Red 1 mm (Inch) 90.177-90.197
(3.550-3.551)
Coded Blue 2 mm (Inch) 90.190-90.210
(3.5507-3.5515)
Coded Yellow 3 mm (Inch) 90.203-90.223
(3.513-3.5521)
Piston-to-Bore-Clearance
mm (Inch) -0.015 + 0.031 (0.0005-0.0012)
Pin Bore Diameter
mm (Inch) 22.0015-22.004
(0.866-0.8663)
Ring Groove Width?€"
Compression (Top)
mm (Inch) 1.520-1.550 (0.06-0.610)
Compression (Bottom)
mm (Inch) 1.520-1.530 (0.060-0.0602)
Ring Groove Width?€"Oil
Ring mm (Inch) 6.996-7.224 (0.275-0.2844)
Piston Pin?€"Length
mm (Inch) 61.93-62.05 (2.44-2.443)
Diameter mm (Inch) 21.994-21.999
(0.866-0.8661)
Pin to Piston Clearance
mm (Inch) 0.005-0.010
(0.0002-0.0004)
Pin to Rod Clearance
mm (Inch) 0.015-0.040
(0.0006-0.00157)
Piston Rings?€"Ring Gap
?€"Compression (Top)
mm (Inch) 1.0 MAX (0.0394)
Oil Ring?€"Side Clearance
mm (Inch) 1.25 MAX (0.05)
Oil Ring?€"Compression
(Top) mm (Inch) 0.040-0.090
(0.0016-0.0031)
(Top) mm (Inch) 0.030-0.080
(0.0012-0.00031)
Oil Ring Snug Fit
Oil Ring?€"Service Limit
mm (Inch) 0.015 MAX (0.0006)
Ring Gap?€"Compression
(Top) mm (Inch) 0.23-0.49
(0.01-0.02)
(Bottom) mm (Inch) 0.23-0.49
(0.01-0.02)
Ring Gap?€"Oil Ring (Steel
Rail) mm (Inch) 0.05-0.66 (0.006-0.026)
Lubrication System
Oil Capacity?€"Automatic
Transmission (Quarts U.S.) 6.675?±0.125
Oil Capacity?€"Manual
Transmission (Quarts U.S.) 6.425?±0.125
Cylinder Block
Main Bearing Bore
Diameter mm (Inch) 72.401-72.422 (2.85-2.851)
Crankshaft and Flywheel
Main Bearing Journal
Diameter mm (Inch) 67.483-67-503 (2.65-2.657)
Connecting Rod Journal?€"
Diameter mm (Inch) 52.988-53.003
(2.0861-2.0867)
Crankshaft Free End Play
mm (Inch) 0.130-0.301 (0.0051-0.012)
Crankshaft Runout to Rear
Face of Block mm (Inch) 0.050 MAX (0.002)
Connecting Rod Bearings
Clearance to Crankshaft?€"
Desired mm (Inch) 0.027-0.069 (0.001-0.0027)
Allowable mm (Inch) 0.027-0/069 (0.001-0.0027)
Bearing Wall Thickness
(STD) mm (Inch) 2.44-2.452 (0.096-0.0965)
Main Bearings
Desired mm (Inch) 0027-0.065
(0.0011-0.0026)
Allowable mm (Inch) 0.027-0.065
(0.0011-0.0026)
(STD) mm (Inch) 1.920-1.928 (0.075-0.076)
Connecting Rod, Piston and Rings
Connecting Rod?€"Piston
Pin Bore Diameter
mm (Inch) 21.959-21.979
(0.864-0.865)
Connecting Rod?€"
Crankshaft Bearing Bore
Diameter mm (Inch) 56.756-56.876 (2.234-2.24)
Connecting Rod?€"Length
(Center-to-Center)
mm (Inch) 150.7 (5.93)
Alignment (Bore-to-Bore
Max. Diff.) c ?€"Twist
mm (Inch) 0.050 per 25 (0.0015-0.984)
Max. Diff.)?€"Bend
mm (Inch) 0.038 per 25 (0.0015-0.984)
Side Clearance (Assembled
to Crank)?€"Standard
mm (Inch) 0.015-0.45 (0.0006-0.0177)
to Crank)?€"Service Limit
mm (Inch) 0.05 MAX (0.02)
Crankshaft Main Bearing
Journal Taper mm (Inch) 0.020 (0.0007)
Journal Runout mm (Inch) 0.05 (0.002)
Crankshaft Connecting Rod
Journal Taper mm (Inch) 0.015 (0.0006)
Feb 15, 2011 | 1998 Ford F150 Regular Cab
What cu. ft washer in a model 110-82870120 top load kenmore washer.
you can find out by measuring the depth of the tub in inches. Measure the diameter of the tub at the opening where you put the clothes in. Multiply those 2 numbers. Then divide the figure by 144 which is a cubic foot in inches. That will Give you the cubic feet.
Example Depth of 23 inches and diameter of 21 inches. 23X21= 483/144 = 3.35 cu. ft.
Jan 16, 2011 | Kenmore 24032\24036 Top Load Washer
Im looking for the thread size, off the drive shaft of a power build 10.5 hp
i'm assuming your looking for the nut that holds on the flywheel? if so, measure the diameter of the thread in the crankshaft. you need the diameter and pitch(oor threads per inch) to "know" the thread size. Measure the diameter accurately. then, measure the length of the thread. example, if there is 1/2 inch of thread length and you have 4 threads in that length it is a "8" thread. so if the diameter (overall diameter measured on top of the tips of the thread) is 1/2 inch, then your thread is 1/2-8.
Jan 14, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
Fuel filter where is it?
Hi, there SHOULD be a C-shaped steel band attached to the left front firewell low and towards the rear under the hood. There SHOULD be a plastic filter with a black 1/4" hose coming into and another going out of the top of the filter. The filter SHOULD be cyllindrical with a flat round top and a curved round bottom - about 2-4 inches tall and about 2 inches in diameter.
Take care
Aug 04, 2010 | 1985 Toyota Tercel
Projection tv has 2 pictures split with 8 inches of black
IN THE MENU GO TO COLOR CONVERSION OPTIONS AND TRY THAT ,,ALSO TRY NEW CONNECTERS
Apr 24, 2009 | Panasonic PT-52LCX65 44" HDTV
Televison & Video Logo
157 people viewed this question
Top Televison & Video Experts
