Question about Dell Inspiron 6400 Notebook
Slow computer my coputer seems to have pleanty of memory but moves at a snails pace - what can i do to speed it up?
    Guru:
  • 79 Answers
ADD VIRTUAL MEMORY:-
1. Click Start, and then click Control Panel. 2. Click Performance and Maintenance, and then click System. 3. On the Advanced tab, under Performance, click Settings. 4. On the Advanced tab, under Virtual memory, click Change. 5. Under Drive [Volume Label], click the drive that contains the paging file that you want to change. 6. Under Paging file size for selected drive, click to select the System managed size check box, and then click Set. 7. Click OK three times.
When you are prompted to restart the computer, click Yes.
Deleting temporary files and directories This step increases hard disk space and reduces the time Windows takes to access the hard drive. It also resolves problems associated with spooling print jobs. Windows uses a TEMP directory to temporarily store files intended only for temporary use. Over time, these files can build up and cause problems. To delete these files, use the following set of steps depending upon the Windows version: Windows 98, Me, 2000, and XP
  1. Close all open software.
  2. Select Start , Programs , Accessories , System Tools , and then Disk Cleanup .
  3. Place a check next to the types of files you want the Disk Cleanup utility to delete. Temporary files are safe to delete.
  4. Select OK
Select Start , Programs , Accessories , Command
in the command prompt you ll see
C:\WINDOWS\
type cd\
You ll be on the root C: prompt like
C:\
type del *. temp/s
if it prompts for enter y to yes n to no
keep hitting y if it prompts ... it ll clean all the temp files from your computer .
Posted on May 26, 2008
    Scholar:
  • 70 Answers
You can try to free some space on your computer by doing a Disk Defrag or Disk Cleanup. Those tools are available on your computer.
You can also try to check for any possible viruses or spybots on your computer which can cause the computer to slow down.
Posted on May 07, 2008
  • 1,031 Answers
Amy b d disk is full try to free some space or try using any recent antivirus software like avira,macafaee to scan fro virus
My power chair is so slow, not sure what the speed is but, its slower then walking pace.
check with your operators manual and you may find a switch that has the markings of a hare on one side and a tortoise on the other
that will be you low and high speed settings
Aug 06, 2016 | Health & Beauty
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
Husqvarna too slow when mowing
Some self-propelled mowers include a speed control, but sometimes it may seem that no matter how you adjust it, the mower just creeps along at a snail's pace. Most likely this isn't a mechanical malfunction, but an adjustment is probably needed.
Very tall or thick grass can bog down a self-propelled mower, but adjusting the height of the blade may allow it to roll through and cut the grass at normal speeds. If the blade is low, the amount of cutting required may slow down the movement of the entire mower. The frame of the mower may also stick in the high grass. Raise the blade little by little until the mower rolls at the appropriate speed. Going up hills may cause a similar response.
It's possible the drive belt on the mower can slip. Inspect this part to see if it is loose or cracked, and replace the belt to restore power.
May 08, 2012 | Garden
Why is the motor of my sears kenmore sewing machine model 385.12714 running really slow? The machine has not been used for at least a year or two. We oiled it. It is sewing, but at a snail's pace.
it could be different things
have you checked to make sure the plug is correctly in the machine
one time I was sewing on my necchi electronic machine & it for some reason was going slow like you mentioned & so I started checking different thing & found the cord to the foot pedal was laying in side the foot pedal & it couldn't go any faster untill I moved the cord out of the way
it could also be the motor
& also the power cord & foot pedal
it's possible it needs to be serviced since it's been sitting up so long & since it's sewing at a snails pace
Sep 11, 2011 | Kenmore Sewing Machines
Very slow. It starts off fast then almost instantly slows down to a snails pace.
The highest the selected resolution, the slowest is the scanning. Lower the resolution to 200 or 150dpi.
Feb 28, 2011 | Xerox DocuMate 510 Document Scanner
Google chrome has slowed down to a snail's pace.
Uninstall and reinstall Google Chrome.
Run a full scan of your computer with this free software:
http://malwarebytes.org/
Sep 16, 2010 | Google Chrome
Notebook runs VERY SLOW after reassembly
maybe you have a virus on your computer try reinstalling the OS
Dec 24, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My computer is low
Improve your coputer by up grading.
What type of PC you have.Tell me i will then tell you the solution
Nov 20, 2008 | Ahead Software Nero 6.0 (60045) for PC
Dell Inspiron 6400 Notebook Logo
82 people viewed this question
Alun Cox
