Question about Car Audio & Video
Marine electric power supply
My power for the sparkplug is supplied bya magneto setup similar to a mower. What baffles me is that it has a start and stop switch one end of which is connected to the condenser then other end follows the sparkplug lead for a short distance and was then cut off? where should that have gone?Earth? so engine would stop if switched to that side?.My engine is an early Valmet single cylinder 2 stroke engine if that helps any?
  • 631 Answers
This was posted in car audio amplifiers for some reason. You should try posting it in a more suitable forum to get more reliable answers.
If I had to guess, the wire was used to ground the spark plug to stop the engine.
Posted on May 07, 2008
Have power going through whole tractor and the block can't get spark proper
I am not sure what you mean by "Have power going through the whole block." You will have to supply more information on your engine, as there are many different kinds of magnetos, and they work different ways.
Dec 28, 2014 | Garden
Goes to magneto down by pull string, remove pull string housing and dare it b
Jul 06, 2014 | Garden
Kohler courage 6.5hp wont start?
Could be a short in the coil for the sparkplug. Check the magneto- pull the plug wire off the spark plug and hold it close to the frame of the while someone tries to start it. Keep all parts of your body clear of the mower- only hold the sparkplug wire. When the motor turns over, verify spark from the wire to the frame. If no spark, you likely have a bad magneto coil. If you have a good spark, try taking the air filter off and use some engine starter fluid (not much) and then try and start again. If it starts and runs for a second with the starter fluid, you probably have a problem with your fuel not getting in, which leads to troubleshooting the carb and intake.
Apr 26, 2014 | Cars & Trucks
Change a lawnmower sparkplug wire
Don:
You will need to buy a replacement magneto as the secondary (spark plug wires) are hard wired into the magneto.
Aug 29, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
MY MOWER WILL TURN OVER BUT IT WILL NOT START
if you spark a little starting fluid to it does it fire?if so then fuel is the problem then is the gas older than 30 days dump it out and try fresh gas if new gas then open the carb and clean it if it does not fire on starting fluid check for spark if no spark pull the top cover from the engine and look for wiring damage unplug the coil from the engine side of the coil and check for spark if no spark then the coil is bad and if its a riding mower the carb might have a anti back fire valve that could stick closed
Apr 27, 2012 | Garden
Dell xps 420 computer will no start blinking amber light no diagnostics lights working
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location, if applicable.
Ensure that the processor power cable is securely connected to the system board.
This can be caused bya defective power supply or a defective motherboard. Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged.
Jul 25, 2011 | Dell XPS 420 PC Desktop
Electric Lawn Mower Doesn't start - Pwr supply ok - No burnt Moto
this mower has a dc motor and the brush on the black wire to the motor usally wears down
Mar 03, 2010 | Black & Decker 19" Electric Lawnhog...
Won't start, have cleaned filter, has gas in it, new spark plug still will not start.
You might try a new contact-points set, and making
sure the magneto that supply current to the spark-plug is clean and not obstructed. Also feel the compression: to do this remove the spark-plug and place a finger in the spark-plug hole. Then crank the engine. If the compression is good, you will feel it, and smell the gas/air mixture.
Oct 28, 2009 | Toro Lawn Mower With Toro Power Tools
My gs 400 is not getin spark to the points or plugs is ther something els outher than points and battery that can be a coz
yes buddy the cdi ,coil,magneto use a electrical metre to check these out the magneto on the side off engine inside the casing the magneto will be a box with out fins and the coil will be coming from your sparkplug also replace plug this could be the cause if not check power to the coil if not check power to the coil if not the magneto is you problem
Aug 31, 2009 | 1978 Suzuki GS 400 E
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
