Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Looking for the remote code for my mitsubishi diamond series tv . trying to enter it in my u verse remote
  • 1525 Answers
SOURCE: convergence
hello theres a couple of codes you can try .1-2-7-0/2-4-5-7/0-3-5-3 /0-3-5-7 do not use the reset it may cause damage ti the tv good luck
shaun
Posted on Apr 10, 2009
  • 179 Answers
SOURCE: i need a tv code for a mitsubishi tv model-wd 62526 2006
use your remote and press QV and 9 together. the reset the code
Posted on Dec 29, 2008
  • 159 Answers
SOURCE: Mitsubishi Diamond Series T.V.
When a tv (Rear proyection) shows this coloration is the meanning that the red color is not there (the red color is generated by a red CRT). Now it can be really bad not having the tube working but before conclution make sure of this: (and if the red color gets back then the tube is ok)
  • is this condition the same in all inputs? or the picture looks ok with a different video source (VCR, DVD other)
  • are the menu letters same as the picture looks or are they fine?
If we cannot see any red color back with this testing, still chances that a technician find an electronic problem that make the tube to be off. so don't rush conclusions and get to the end to save the tv with out replacing the red tube, but if all was done and nothing then the tv needs the tube replacing.
Posted on Apr 14, 2009
  • 64 Answers
SOURCE: I HAVE A MITSUBISHI DIAMOND SERIES TV. I REPLACED
Sounds like your TV is overheating. How dirty is the filter on the side? Is the fan on the back turning ok:? Does it look real dirty? Is so, a good cleaning is in order. Also, there is a fan under the lamp. Can you determine if it is working...the air flow may be obstructed (from the clogged filter) and it takes some additional time to cool.
Posted on Aug 01, 2009
  • 65 Answers
SOURCE: Power Loss
You will find 4 swollen capacitors in the DM module of value 1000uF 16volt. Replace them.
Posted on Sep 02, 2009
I need a code for a blue diamond tv model number BD40DL fev10
Remote Code for Blue Diamond TV - Boards.ie
www.boards.ie > Talk to... > Sky Ireland
Aug 7, 2015 - After checking our database for remote codes we don't have a codeavailable for your particular make of TV, Blue Diamond. I will be sending ...
Horizon UPC Blue Diamond LED Remote Control - boards.ie
www.boards.ie > ... > Cable & Digital TV > Cable & MMDS & IPTV
Dec 11, 2013 - I have bought a BLue Diamond TV and upgraded to UPC Horizon HD. ... the code for Mitsubishi who from what I can see make Blue Diamond Sky Remote COde
May 29, 2015
Anyone code for programming sky remote bluediamond tv?
Dec 10, 2012
More results from www.boards.ie
Dec 10, 2015 | Televison & Video
Can't find a code for my ATT Uverse remote. Bought the set in China and brought it back to the US.
Hi! Welcome to FixYa!
You can program your AT&T U-Verse remote control using the Automatic Code Finder. This step cycles through all possible codes for the type of TV you are programming until the correct code has been found. Please follow the steps bellow.
  1. Make sure that the TV you want the AT&T U-verse remote control to control is ON.
  2. With your TV on, PRESS AND HOLD DOWN, the TV Mode Key on the remote control. The mode keys are located at the top of the U-verse remote control. While holding down the TV Mode Key, press and release the OK button. If done correctly the Mode Keys will blink twice. The remote is now ready to be programmed.
  • The next step is to enter the code for the automatic code finder feature. That code is 922. Enter the code 922 using the Remote Control's keypad. You have 10 seconds to enter this code before the remote times out. When 10 seconds have elapsed the Mode Keys will flash once. If this happens just start over.
  • Next steps is start the automatic code finder search. Make sure you aim your remote control at your TV. Then press and release the play button on the remote control. Now press the Fast Forward key multiple times until the TV turns off. Then press Enter to save the code. Your remote now has the correct code. If done successfully the Mode buttons will flash three times. Press the Power button again to turn on your TV.
  • When the code has been entered correctly, the appropriate Mode Key will flash three times. To check to see if this code works, press the Power button. If the TV or DVD does not turn off, then we need the correct 4-digit code of your TV.
Please refer to the image bellow.
Thank you for using FixYa! Keep me posted. :)
Mar 12, 2011 | Televison & Video
I have tried to program a At&t U-verse remote to my Apex LD3249. Have tried all codes from At&t U-verse list. None work.
On uverse i got my apex to program by doing the search of codes. There is a code you can enter then hit a button to sequence through all codes by hitting power i believe. when tv turns off you know you have the right one. I am having the same issue on directv now since it does not have this option.
Jan 18, 2011 | Apex Digital LD3249 LCD TV
Mitsubishi vs-50603 no remote.what is code
Good Day, ariley1604;
Please contact comcast, and look into U- VERSE.
Good Luck, big IRISH.
Aug 21, 2008 | Mitsubishi VS-50603 50" Rear Projection...
U-Verse remote for Digital Lifestyle
I use my Directv remote to change the channel. What you have to do is go the your direct tv remote go to setup then go to remote then look for tv brand Citizen then follow the direction the menu tells you to do. It works fine. You can use Tv Brand Citizen, Concerto, Luxman They work with any u-verse remote 4 digit code 0056 5 digit code 10056
Aug 13, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Mitsubishi HD Diamond series WS-55907
Good day k g;
I think the code is oooo.
If not let me know and I will double check.
Good Luck, Big Irish.
Jun 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Diamond Series CS-27609 problem...image looks "fisheye"
2 years later and I may have a solution for you
I has a similar problem and I didn't quite fix it but made it less noticeable.
Press menu and then the code 2-3-5-7, this enters a service menu. Press Audio/Video to go between the options to get to options 40-50 to adjust geometry. Be sure to write what setting there on before you change it (even if they're wrong) just in case.
Its just trial and error from there, and hope I can still help.
Oct 27, 2007 | Mitsubishi CS-27609 27" TV
Mitsubishi 1080 72in diamond seris
52" mitsubishi 1080p t.v. warning shows up on screen AIR FLOW IS BLOCKED. Check owners guide and they don't tell you how to clean it or where it si at.
Aug 29, 2007 | RCA F38310 38" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
105 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
