Question about RCA RT2390 System
With the volume at 40( and now even lower) and audio "spike" causes the system to shut off...What's happening?
  • proverbs3_5_ Aug 28, 2010
    Thanks for your advice. I found that I had one of the speakers wired incorrectly. I have since put the wires in there respective ports and waaalaa the system cranked out sound at full volume with on shut downs...
  • RCA Master
  • 17,130 Answers
It can be the input is bringing the HF noise to falsely trigger a high currrent output that incidentley cuts off the amp to protect.
If after removing the input the amp does not hum or cut off when the volume is turned then we must check on this unit.
However even after removing the fault appears, check the load of the speakers connected. Repair /replace if bad.
If not there is a power filter fault that is issuing the noise to the circuits. check for poorr value of filter capacitors in the main supply, the regulators to the pre amp or the filter capacitors to the preamp.
If the fault disappeared with the input source being removed , check the power supply of this unit.
Posted on Aug 29, 2010
    Guru:
  • 642 Answers
Shutdown will be caused by overvoltage on the input or shortcircuit/low resistance on the output. Remove the speakers one by one at the same volume level. If the problem persists with all the speakers removed the unit is faulty and needs to be sent in for repair.Did you change or reconfigure/rewire the outputs/speakers recently?
If the resistance(impedance) on the output is too low it will cause the unit to shut down. Wiring additional speakers incorrectly will cause this. If a speakers' voice coil is starting to fail you will get the same result. Remove one speaker at a time until the unit no longer shuts down in order to identify the channel that is causing the problem.
Posted on Aug 28, 2010
I set the volume to 40. After a little while the volume starts dropping down. If you do not turn the volume back up the volume will eventually go to zero all by it self and turn off the system.
HDMI Audio drop out? - ecoustics.com
www.ecoustics.com > Forum > Home Video Forum > HDTV Forum
Sep 21, 2005 - My Panasonic TH-37PX50U plasma has an audio drop out problemwhen .... The drop out occurs on both TV sound and receiver sound. ... very littlebass effects when playing DVD's through the HDMI cable when I compare it to ....Most noticeable when I turn down the volume control on the set top box (and ...
Dynamic volume problem : Ask Audyssey
https://audyssey.zendesk.com/.../20013893-Dynamic-volume-problem
Apr 8, 2011 - it appens only when dynamic volume is ON (day, evening or midnight) . the audio signal of the TV is on a optical Toslink cable and it ... and so it drops thevolume to make sure the sound will not be too loud. ... April 11, 2011, 12:40 AM .... Setthe audio setting on the receiver to Stereo vice Surround Sound.
How do I stop my surround sound system cutting out? - TV DVD HDMI ...
ask.metafilter.com/.../How-do-I-stop-my-surround-sound-system-cutting...
Jan 21, 2009 - When the volume is at higher levels, all but the center speaker cuts out..... That is why I just turn down the TV's speakers to 0 and listen to things from thereceiver. ... notice that the sound is coming 40ms later or earlier than the video). ...system), and adjust the A-V delay on the receiver until the audio lag is ...
Jan 06, 2016 | Audio Players & Recorders
Power indicator is flashing after volume spiked and unit shut off
You can try a hard reset: Unplug unit from AC mains and remove all cables from unit . Wait about 3 hrs and replug to AC power and redo the cabling. Switch on the unit and see if it works..
Sep 26, 2008 | Denon AVR-1082 Receiver
My Denon AVR3805 shuts down during sound spikes in music. I have to keep the volume at a lower level to keep this from happening. I keep the receiver on a rack in a closet system with fans to keep it cool...
Try a hard reset first unplug all the cords from the ck and allow the unit to reset for 30min and then plug in the cords back.
I will be posting more troubleshooting steps..
Goodluck..
Apr 05, 2008 | Audio Players & Recorders
My DB Drive pd 1200.1 amp shuts off when the volume is raised. What is happening and what should I do?
The vibration from the bass is cutting off the amp. it is a loose wire causing this issue. you can also get a stabilizer that will stop the vibrations from causing this issue.
Feb 27, 2013 | DB Drive Platinum PD1200 Car Audio...
My pioneer VSX-1016 shuts itself off during loud portions of a movie. I have checked the speaker wiring and have clean connections. Any other ideas?
Yes, evaluate the load presented to its amplifiers by the speakers. If you have any speakers running parallel on the amps instead of one per amp channel you could be experiencing temporary unacceptable drops in impedance.
and
From page 57 in the manual...
• Turn down the volume.
• Lower the 40 Hz and 125 Hz equalizer levels in the Manual MCACC setup on page 34.
• Try switching on the digital safety feature (put the receiver into standby, hold down the SYSTEM SETUP button on the front panel and press STANDBY/ON to switch between SAFETY ON and SAFETY OFF
. If the power switches off even with SAFETY ON selected, turn down the volume.
Dec 29, 2010 | Pioneer VSX-1016 Receiver
Got t7900`
I have had that problem with a T7700/T7900 speaker system.
Disconnect the remote control from the subwoofer. Then what you need to do is unscrew the remote volume/bass control unit (4 little screws). Swab the contacts on the volume dial with a cotton bud (q tip) denaturated alcohol or even perfume will work. Make sure you do it several times until all the slight dirt that is causing the volume fluctuation/spikes to happen. Also remove any remnants of cotton that might get stuck.Now you'll have it working as new as long do not cause any other damage to the unit.
Cheers,
Daniel
Jul 02, 2008 | Creative Labs Inspire T7900 Computer...
Denon receiver shutdown
Try turning down your tone controls. Like your bass, treble, or your equalizer. If you hear too much tinny or hissing sounds, the treble has to be turned down, or turn down the upper bands controls on your equalizer to the optimun level. If you hear too much bassy sounds, your bass control has to be turned down, or the lower band controls has to be turned down to the optimun level. If you are planning on turning the volume up, you may have to turn down some of the tone controls to the optimun levels, otherwise, your receiver may shutdown, or you may blow fuses in your speakers. Also make sure you speaker wire polarity is hooked up right. Red wire on the + red terminals, and the black wire on the - black terminals. Also don't have the volume turned up too high to the point where your receiver would have clipping or distortion, or else your receiver may shutdown, or you may blow fuses in your speakers.
If this don't help, then there may be something wrong with your receiver or your speaker.
Apr 05, 2008 | Sherwood RX-4105 Receiver
Turning volume up on my Denon AVR-485 AMP causes it to turn off
Speaker Impedance:
When speaker systems A and B are used separately, speakers with an impedance of 6 to 16 ohms can be connected for use as front speakers
Be careful when using two pairs of front speakers (A + B) at the same time if their impedance is less than 12 ohms.
The protector circuit may be activated of the set is played for long periods of time at high volumes with an impedance lower than specified are connected.
Oct 16, 2007 | Denon AVR-485 Receiver
Overload
No, one of your speakers is damaged (could be an amp channel went bad, but speaker is more likely). Unplug all spkrs, then plug one in and see if it acts normal when turned up. Repeat this until all speakers are hooked up or the culprit spkr is found.
Sep 25, 2007 | JVC RX-6018V Receiver
RCA RT2390 System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
