USB Pen Drive
I send files to my pendrive and the data is sent and visible until I remove the pen drive from the port. When I plug it back in again the folder is visible but empty. Any suggestions
  • slashedsnake May 09, 2008
    Thank You for your reply. Unfortunately I had thought of that but windows couldn't shut it down. However I have rectified it. I removed all the files I had stored on it and the formatted. That rectified the problen and it is fully functional again.
    Very much appreciated your assistance and I hope this helps others.
Some times if you don't use the "Safely Remove Hardware" option before removing the device, the system will not write the data over.
Posted on May 07, 2008
In win 98 eject pen drive before unpluging it.
In later windows use icon near clock ( bottom right of screen ) and stop mass storage device before unpluging it.
That should solve problem.
My mother board gigabit 61pme s2p series mother board.with amd althon 3ghz processor.the problem is when i connect the usb pendrive to back of the usb port...if i send data 1 or 2gb data to pen drive.the...
your problem is kind of complicated. Check if you have a defective usb flash drive or an usb connector by doing so:
  1. Try other usb flash drive. If it solves the problem you have a defective flash drive
  2. Try to plug in to other usb port. Observe each port. If you see that you have a problem with your usb ports, buy a new usb port card
Aug 01, 2011 | Intel Motherboard
Tip
How to recover data from Pen Drive
Pen Drive gives ussignificant convenience in today's business life. However, due to human errorsor other reasons, we often meet embarrassed phenomena of losing Pen Drive data. The following are sometypically cases in our daily business life.b>
Practical cases:
1. Pen drive still contain all data, and the space shows the same likebefore, but all files and folders in the pen drive are changed to shortcut.
Cause:
Your pen drive was attackedby virus
Resolution one:
If you oftenuse Pen Drive to transfer data from one computer to another, make sure thecomputer is well protected. If any computer is not protected against virusattacks, the files and folders in Pen Drive may be gone or just change intoshortcut. If that happens, don't panic, you can still get back lost data, Firstly, remove the virus, connect your Pen Drive to one PC that is protectedwith a good antivirus and then scan it, fix all the virus threats that aredetected by the antivirus, After completing scanning, some of the useful filesor folders may deleted. Secondly, use pen drive data recovery program torecover deleted infected files.
Resolution two:
If you can'tdelete virus in Pen Drive, just format Pen Drive and then use data recoveryprogram to retrieve data.b>
2. When transfer files from Pen Drive to PC, mistakenly removed the PenDrive from USB port and some data lost, or press "format" command during theprocess of using Pen Drive. Sometimes, delete data in Pen Drive in one day andfind it is useful in another day and want to recover them.
Cause:
Human error
Resolution:
The data youonce have saved in your pen drive is real hard to remove completely. Firstthing to do is stop using the Pen Drive as the chances of your data beingoverwritten increase as time goes on. Then choose a perfect data recoveryprogram. There are many Pen Drive data recoveryprogram in the internet. Although Ihaven't tested them one by one, Card Data Recovery is the most popular one inthese days.
Steps to recover data fromPen Drive using Card Data Recovery
1.
Plug the Pen Drive into yourcomputer using USB port;
2.
Download Card Data Recoveryand install it on your computer;
3.
Check whether your Pen Drivedisk display in your computer;
4.
Select your Pen Drive;5. Run Card Data Recovery andcontinue the operation under the interface instruction.b>
on Jul 20, 2011 | Computers & Internet
My Transcend v30 pendrive is not working i had checked it in other computers but it was not working
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 23, 2011 | Transcend (589307) Media
4 Gb pen drive can't poen
Your drive could be corrupt. The first thing I would do however is make sure you are plugging it into a good USB port. If you are using a desktop with USB ports in the front, and are plugging the drive in there, remove it and plug it in to one of the USB ports on the back of the computer. Many times the front ones will have issues with certain USB devices. If that doesn't work, you very well may have a bad usb drive. I would try it on another computer if switching the usb port doesn't help, to see if the drive is truly not working or just a driver problem on your computer.
Apr 20, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Transcend JetFlash V60 16GB pen drive is write protected
Flash drives by default use the FAT32 file system. FAT32 has a limit of 4gb per file. So you could have four 4gb files on your pen drive, but no files bigger than about 4gb. You could use the NTFS format, but it's not suggested for flash drives since it reads/writes much more often than FAT and will make the drive lifetime MUCH shorter.
Aug 26, 2009 | Electronics - Others
It shows this device can perform faster. the pen drive is slow
this is usb issue
your computer usb has a lower version than your pendrive
you cannot use better drivers because this is from mainboard chipset
Also you can put a pci usb card version 2.0 for your pendrive
Jul 24, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend 4gb pendrive gets detected bt says inserd disk
my pen drive Please insert a disk into drive problem
Jun 08, 2009 | Transcend (589307) Media
Ttanscaned pen drive problem
I Have Cruzer micro (8Gb) pen drive When i Insert pendrive And open Show message (Pls Insert Disk) When I try to format Pen drive Show message (There is no disk in drive G) G Drive Right click And go properties Show 0byets Pls solve the problem Regards, Prashant
Jan 13, 2009 | Electronics - Others
Pendrive write protection removing
Hey, the transcend pen drives usually have a small switch on the side of it, ie to turn the write protect on and off, usually a small lock symbol on it, the problem with unreadable files names etc, could be a corrupt partition, i would suggest formatting the drive as long as you aint got any important information on it,
All the best
John
Jul 27, 2008 | Computers & Internet
Pendrive is not working
ic, maybe the usb port of your friend's pc is defective which may cause your pen drive to malfunction, probably a shorted usb port. or just maybe your pendrive was dropped by your friend which damage the drive, it happened to me too before.
Sep 18, 2007 | Transcend (589307) Media
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
