Question about Navman Tracker 5500i GPS Receiver
I have NAVMAN 5505i Chart plotter (Internal Antenna). I use it in Cockpit of MOODY 422 Yacht. I also have GPS at Chart Table connected to external Antenna. I Only use Unit at Chart Table for plotting posn on paper charts. I use Navman in Cockpit for nav esp into Harbours etc. The signal fails on the 5505i on a regular basis. It is wirst if sailing where the boom or main sail is over the Unit thus clouding the signal. It is also poor in High Pressure whilst the other unit keeps showing the Lat/ Long. The problem seems to get worse when the unit has been switched on continuously for several hours (4 or 5). I think that it's performance would be greatly enhanced if I could retrofit the external Antenna option. Please advise me if this is an option. Can I do it myself if you supply connectors, instructions and Antenna or where may I send the unit to have the modification carried out. Apart from this problem, I like the unit as it is easy to use and the screen is a useful size without being too large. I would appreciate your advice in this matter. Yours faithfully, Seamus McAleese
SOURCE: navman F10 wont function shows sat nav connecting to computer on screen
Try holding down on/off button till screen clears,switch back on and it should be working normally,this worked on mine,it had picture of laptop ,navman usb cable and a red cross,hope this helps.Cheers.
Posted on Jun 19, 2008
  • 6 Answers
SOURCE: Navman icn 520 stuck on USB screen
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
Hope this helps.
Posted on Jul 09, 2008
SOURCE: Error message on Navman Navman F
I have a similar problem, where did you download the firmware?
Posted on Oct 22, 2008
SOURCE: f20 navman error
I have had the same problem and did what gossages recommended and it worked straight away thank you very much!!!!
Posted on Jan 13, 2009
  • 18 Answers
SOURCE: continual "waiting for gps " message
the message should also read no mnsa data first... if these units are not in continual use,they get corrupt for some reason. all you can do is hope the gps fix will work itself out,otherwisw buy a new unit.
Posted on Aug 31, 2009
I have problems with my plotter Raymarine Rc 435 chart plotter.This plotter can not location my ship to do.What is problems?
Be sure there isn't any aluminum in close proximity to your GPS antenna, or that your antenna is not to close to other powerful electronics. Aluminium reflects electromagnetic signals and other electronics emit EM fields as well causing disruption of your GPS signal reaching your antenna.
Sep 26, 2014 | Raymarine Rc435 Chartplotter
Is their a internal battery in sitex colormax 11
Yes. There is a battery backup to store memory. Read all about the Sitex Colormax chart plotters here:
http://www.si-tex.com/product_manuals/Chart-Plotters-3-08.pdf
Apr 28, 2014 | SI-TEX COLORMAX 11 GPS Receiver
Navman Tracker 5500
I am having same trouble. I contacted Navman NSW and went through all the settings without result. It was suggested that the problem could be the external antenna, if not a fault in the machine. I have seen an after market antenna for about $19 so I might try that. It does seem as though the antenna is not talking to the Tracker.
Dec 10, 2012 | Navman Tracker 5500i GPS Receiver
I have a navman 5500i tracker ,the zoom isnt coming up far enough to show water depths and hazards by pushing the + - button .is there an easy fix? Thankyou Muzza
Just got the same one and same problem, I also have a 5505i and is only zooms in close when i put in the c-map chip and it zooms close in the chip area only?? now i have a chip for the 5500i and it zoomed in but only on the Texas part of the map, that is the chip it came with, but i live in Canada. Be carefull the c-map max chip for the 5505i is not compatible with the 5500i it needs c-map nt+ chip. 5500 chip is black 5505 is orange
Jan 19, 2010 | Navman Tracker 5500i GPS Receiver
External Antenna Conection
Ref ICN330. The external antenna connection is on the top side of the flip up Antenna on the unit itself. There is a small rubber plug covering this, adjacent to the Navman logo.. Ricmac
Feb 12, 2009 | Navman iCN 330 GPS Receiver
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Gps fix
do you have anything interfering with that signal, like a solid mass of metal?
Jun 03, 2008 | Navman Tracker 5505i Color Chart Plotter...
Raytheon rl70
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
May 05, 2008 | Raymarine RL70CRC GPS Receiver
Communication to Offshore Navigator light
The internal memory battery is dieing. It will eventually stop completely unless you get a new battery installed.
Jul 08, 2007 | ICOM Informatique GP-270ML GPS Receiver
Navman Tracker 5500i GPS Receiver Logo
80 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
