Question about ION Audio TTUSB10 Turntable
Ion worked fine; got new computer, now there is a buzzing sound when plugged in to the turntable; what to do?
  • davidmcregge Aug 30, 2010
    thanks midwest-tek; it worked using the power strip on my dell inspiron; before i had the ion turntable plugged into the back of a gateway, but dell doesn't have that. thanks again.
    yes it was a grounding problem, thanks
  • 864 Answers
This is a 99% of the time a grounding issue. It is called a "Ground Loop" This means either the new computer is not properly grounded, either to if its a laptop which 8/10 the usb/soundcards are never grounded correctly. or if its a desktop, most of the time the power supply is not always grounded to the case correctly. This happens because Audio and video systems need a reference point for their voltages. Generally referred to as common or ground, although it may not be actually connected with the earth, this reference remains at "zero volts" while other signal voltages "swing" positive (above) and negative (below) it. Physically, the common may be a wire, a trace on a printed-circuit board, a metal chassis, virtually anything that conducts electricity. Ideally it should be a perfect conductor, but in any practical system it is not. As the complexity and size of the system is increased, the imperfect conductivity of the common (ground) conductor inevitably causes problems.
First thing i would try is if its not plugged into a grounded power strip, Get a surge protecting power strip and plug the computer and turntable in there. Now next one is a little more scary then anything else. On my dj setup i do not have a proper ground thus have the same problem you have which requires me to use a cheater plug. You know the 3 prong to 2 prong outlet. Thus removing the ground completely. This is not recommended to do all the time but i only do it when i want to use my turntables.
First try the power strip and have both the turntable and computer plugged in to see if this helps solve the problem. If it doesnt try the 3 to 2 prong outlet. If the cheater plug fixes the problem please let me know and we can go from there on how to properly ground the unit. Please also when you provide feedback let me know what model computer it is, so i can properly assist you. For more information to reference the problem here is a write up on ground loop isolation. Thanks, Midwest-tek
Posted on Aug 28, 2010
Why do I not get full stereo spectrum on Ion Profile Pro turntable when connected to Dell computer?
This toy player, can be used with a USB cable, but also with tulip plugs. When you have an amplifier, you at least can test if the sound coming from the element is in stereo. If that sounds good, you know there could be something wrong in the A/D convertor in the record player, or still your computer can't handle the digital signal coming from the USB connection.
Here I found a Video, where they use the analog output and connect it to a pair of computer speakers direct.
Ion Profile Pro USB Turntable Review
Jan 22, 2015 | Audio Players & Recorders
The sound is terribly distorted if turn up the volume on my ion profile pro
I am going to hazard a guess, I have lots of experience with traditional turntables, but not with USB turntables. Here is some theory that may also apply to the USB turnbable. Turntables of old and new that are not USB have a GROUND wire (a single flexible conductor not connected to the plug). The ground wire is supposed to go to the chassis of the amplifier or receiver. If it is not used. There will be a 60Hz hum added to the turntable's signal. It makes the sound garbled and unpleasant. Your turntable may have such a wire. If so, ground the wire to the chassis of the computer. If it doesn't have the wire. check to see if you have all three prongs on your terminal strip(the rounded large prong is the ground). If you don't the chassis of the computer will not be grounded so you may get the hum from that source as well. If the outlet that your outlet strip is plugged into does not have a proper ground, then that could be the source.
Check to make sure that there are no breaks of your ground between the turntable and the wall outlet.
Replace the offending cables or parts until you are sure.
If there is a grounding wire coming out of the turntable, connect it to the chassis of the computer.
Here are some other points that are important
Important: All of the power in your computer and sound system should be connected to the same phase of the breaker panel in your house If it goes into the same wall outlet. that is best.
This ground issue is important in turntables.
This may not be the problem, but it certainly is very possible.
I worked in professional sound system design for recording studios and large venue (concert) sound systems.
Whenever possible, these folks require the power to be from a unified phase and source point. on Otherwise they have serious hum issues.
Have a Happy New Year,
Best, mark
Dec 31, 2010 | ION Audio Vinyl Recording Turntable
I've just bought a used Ion Audio TTUSB05 turnatable, I ve plugged it into my amp and it sounds terrible. There is a lot of noise before the needle hits the vinyl, presumably it needs earthing, when...
It will need earthing if you are getting hum. As it is used I would replace the entire cartridge and stylus with the best you can afford. Make certain you wire it up right. A good test is with the cartridge removed and your amp on, is to touch each wire (one at a time) with your finger. You should hear a buzz on two wires (one left one right) and nothing on the other two wires (earths). This will help you get the new one connected right.
Dec 01, 2010 | ION Audio TTUSB05 Turntable
My ion USB turntable picks up sounds from the room and adds them to the file
Try reducing the audio imput to your computer and make certain the computer microphone isn't switched on during recording etc. IE the Sound Control on your computer (such as SoundMax).
Jun 26, 2010 | ION Audio Audio Players & Recorders
ION turntable volume is low when plugged into a receiver.
Either the cartridge has failed, or an internal amp in the record deck has, or despite what you say the receiver has. I will clarify this for you. Magnetic cartridges need a pre-amp before it gets amplified by the pre-amp and power amp of your reciever. If that pre-amp fails you will still hear the low sound from the deck, but all others cd/tape would be normal as they don't go into the deck pre-amp.
All you need to is trace the circuit. Find the magnetic cartridge pre-amp and find where it joins with the pre-amp of the amp! If you stick a screwdriver at that point, you will get a buzz at normal volume on each channel. The cartridge pre-amp has gone if you do get a buzz!
You probably find it's a single IC that's gone, some are prone to static problems.
Jan 01, 2010 | ION Audio iTTUSB Turntable
ION iTTUSB turntable has buzzing sound when I record
It sounds like you have a bad ground on the tone arm. It's probably time to replace the tone arm wiring, or the external connecting cables.
Nov 28, 2009 | ION Audio iTTUSB Turntable
Using mac with the ion turntable to record vinyl--it records fine and imports into itunes, but when I play songs back I cannot hear any sound. Computer is set to 'line in' for sound input and 'internal...
Funny thing about analog to digital recording without a preamp. You will record a signal, but that signal might be below the level of human audibility, if the line levels are left at the level that left the turntable, given the absence of a PREAMP.
Apr 28, 2009 | ION Audio iPTUSB Turntable
I'm not getting sound with my Ion Turntable
Ater spending several hours trying to correct the problem I replaced the USB cord and it worked.
Thank you for your reply.
Oct 06, 2008 | ION Audio iTTUSB Turntable
ION TTUSB05XL - Poor sound quality
the turntable has a built-in phono preamp so you don't want to run it through phono inputs in your receiver but just regular auxiliary inputs instead
Oct 03, 2008 | ION Audio iTTUSB Turntable
ION Audio TTUSB10 Turntable Logo
197 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Joseph Hoffmann
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
