Question about Polaroid i1035 Digital Camera
The camera does not turn on when i turn on the power button and the batteries are fine
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 29, 2010
I get no power when using fresh AA batteries or charged (Ni-MH batteries). Camera works fine when using AC power adapter.
Please make sure that you're using the LR6 AA sized batteries and also the terminals of the batteries are correctly inserted. Also make sure that the terminals of the battery compartment is clean without any obstacles or dirt. Also, try power reset and check if it helps.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
If the issue persists, try the factory resetting. SETUP MENU-->RESET ALL--> OK
This should resolve the issue.
Thanks for using FixYa.
Jun 06, 2011 | Fuji FinePix 3800 Digital Camera
Canon PowerShot A480 won't take photo. Pressing on button camera on then pressing silver button to take photo when pressed down screen turns black no picture taken. Batteries new. This is the story; camera...
its just a matter of batteries...some are not powerful enough to operate the camera ....Try to change them and buy some real good ones..like Duracell or Tatra...do not make any compromises when buy the batteries...get the best cause these kinda cameras really require powerful ones...or ...try to get a set of rechargeable ...
Jun 20, 2010 | Canon Powershot A480 - Silver Digital...
Access turn the power off and on again
I'm sorry that the camera is not working fine. Please check if the battery is fully charged and check if there are no dust particles near the lens. Else, please try to power reset the camera by removing the battery and pressing the power button for a minute. Then, reinsert the battery. If the issue persists, the camera requires service.
Oct 18, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Wont turn on
My camera worked fine last night while I was taking pictures, however, I couldn't get it to power up today so that I could upload my pictures. I spent half the day recharging batteries, buying new batteries, and searching the Internet for solutions.
It turns out that I just needed to switch the batteries around. The positive and negative battery chambers are mislabeled in my camera. Duh! Works fine now.
Hope this helps someone.
Mar 30, 2009 | Kodak EasyShare C613 Digital Camera
Power button will not work - it did not pop up when depressed. I removed battery and card and re-inserted but button is still stuck. Any suggestions?
Found out that if battery needs charging, camera will not turn on at all. I guess I had a senior moment. Button was not stuck just no power to turn on camera. After charging battery everything is fine.
Feb 28, 2009 | Casio Exilim EX-Z750 Digital Camera
I have a samsung L100 digital camera. the battery had to be recharged but the lens cover only partially closed at the time that it shut down. I tried to recharge the battery, when I turn on the power...
The battery was tested and showed to be fine. The camera just malfunctioned during the shutdown. The used battery was put into a new camera and it's been fine.
Dec 25, 2008 | Samsung L100 Digital Camera
How do you reset the camera
under the battery there should be a little button here u might have to use a needle or somethign fine and sharp to reach it, press that. that should help. if it is not there, then it might be under or on top of the camera im not to shore, try to find it, if u cant, please et back to me.
Jul 17, 2008 | Sony Cybershot DSC-T200 Digital Camera
Off and On
The power button must be stuck. Try to clean it.
Jul 02, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Won't stay turned on
Since mine was only a day or two old, I took it back to the store and got it replaced. Since then, it's been fine. Hope you have the same option.
Jul 01, 2007 | Fuji FinePix S7000 Digital Camera
Polaroid i1035 Digital Camera Logo
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
