Question about Fisher Price Power Wheels Barbie Jeep
Power wheels f150 truck. only goes in reverse no matter what gear you are in.
3 Suggested Answers
SOURCE: power wheel wont reverse
lightning mcqueen 12 volt power wheels will not go in reverse or turtle speed and the left driver tire does not move. is there a way to test the motor with a test light? Or is the problem in the switches? All connections have been cleaned and coated in dielectric grease.
Posted on Aug 18, 2010
SOURCE: Power wheel F150 only works
My son had the same problem. At first I was angry because we just bought this toy, but then I realized he didn't have it in gear all the way. I had him put it in reverse and drive it back a little. Then I told him to put it in drive, and (making sure it was properly in gear), told him to go and it did. I think it just takes the kids a little while to get used to it and make sure it's properly in gear. Good luck!
Posted on Jan 12, 2011
My ford F150 truck
auto transmission -check the reverse servo/ solenoid operation
manual transmission--check for loose selector fork for reverse , broken selector fork, stripped reverse gear, reverse gear key failure
Sep 15, 2016 | 2004 Ford F150
My gear shifter is loose and and will move from r to d but does not shift truck out of reverse. The shifter hangs loose. Is there a pin broke or is the shifting cable broke?
1997 F 150 Gear Shift Repair - YouTube
? 5:22
www.youtube.com/watch?v=MsHV09_3JWI
Oct 21, 2012 - Uploaded by DrBobaliscious
... and strengthen a broken gear shift lever on a 1997 Ford F-150.... Loose shift lever on Steering wheel Ford F150 F250 F350 E150 E250 E350
Sep 29, 2015 | 1997 Ford Expedition
Truck will not move forward when put in any gear,drive,first,or second.But it will move in reverse.This just stated yesterday out of nowere.What do you think could be the problem???
I assume it is an automatic..In a case like that it is TRANS Failure..Did you check the fluid level or is it leaking anywhere. ?..You can try replacing the fluid and filter ...or even a shift solenoid..You didn't state how many miles you have on the truck,If it has been serviced before,and is it a 4-wheel drive.,What year model is it ,.?..Is it flashing any fault codes..? This would help me answer your question..However 9 times out of ten it is Trans Failure...Reverse is at the back of the trans and it is the largest gear...Although sometimes reverse goes out instead of forward gears...
Feb 22, 2015 | Ford F-150 F150 Extended Cab
My 2006 ford f150 goes in revers my 2006 ford f150 goes in reverse but wont go into forward
could be the forward gear bands actuator , its part of the valve body in the lower part of trans , it has all sort of solinoids in there that make gears shift and select direction
of course if you dissasemble this that far it would only make sence to rebuild the entire thing
Feb 10, 2015 | Ford Cars & Trucks
Steering wheel is locked on my 95 ford f150 xl..it starts and goes into gear but the steering wheel won't move..it is locked
you can break the lock by pulling down on the steering whell very hard. or if your ignitons swith is bad you have to get a new one
Nov 13, 2011 | 1995 Ford F150 Styleside Regular Cab
Can you tell me the amps on fuse #16 on a 2004 Ford F150 FX4? My shifter has zero resistance when I try and put the truck in gear. So I cannot get it into reverse or drive at this time. Wondering if it...
Fuse 16 is a 10 amp fuse. It goes to the ABS module (run/start power). You also have fuse 33 (15 Amp) Shift solenoid. Both fuses are mini fuses.
Jul 29, 2011 | 2004 Ford F150
The Tinds will not engage and I have problem getting the tiller in forward/reverse gear.
you need grease on your power shaft that has the forward/reverse this is where the power goes to the wheels slids back and forth A round wheel one side forward the other side reverse
Mar 24, 2011 | Yard Machines Tiller 208cc 18in Tilling...
Power wheel F150 only works in reverse. (nothing happens in high or low gear). The problem started after he sprayed the truck with a hose. Is it fixable?
Jul 27, 2010 | Fisher Price Power Wheels Kawasaki KFX...
Power wheel wont reverse
I would call customer support and find out why the powerwheel does not go into reverse. You advised that it was the f150. I can give you the link as to where I tried to see if there might of been a safety feature of not letting the unit go into reverse. Here it goes http://www.fisher-price.com/us/powerwheels/product.aspx?pid=38040 I am not sure if it is the same one. You can also call this number Contact Consumer Relations toll-free at 888-892-6123.
We are available Monday through Friday 9 AM to 6 PM Eastern Time, 6 AM to 3 PM Pacific Time.
They might be able to tell you about your exact model.
May 01, 2010 | Fisher Price Power Wheels Barbie Jeep
F150 SUPERCREW 4X4 5.4L Got stuck in the snow and
sounds like transmission damaged. if forward gears are operational, suspect transmission failure. If nothing working ( either in 2 or 4 wheel drive) suspect transmission or transfer case.
Dec 25, 2009 | 2004 Ford F150
Fisher Price Power Wheels Barbie Jeep Logo
465 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Bruce Mommaerts
Bruce Mommaerts
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
