Question about Zonet ZSR4134WE Wireless Router
I'm not able to connect my Tivo using the router. I've spoken to Tivo techs many times but have not been able to resolve the problem. There are only two green blinking lights on my router. The numbers 1.2.3.4. are not blinking. Is this normal?
    Master:
  • 515 Answers
It is not nomal to have only two blinking lights on your router. The power should be solid and the sys light should be flashing. The WAN light should be on or flashing and the WLAN should be flashing or at least one of the numbers 1.2.3.4 should be on or flashing. You can see the LED indicators specification on the following link on page 6.
http://www.zonetusa.com/file/product/d/D00000210_88.pdf
There must have been something wrong with the Internet connection at your house either the modem needs to be restarted and the wireless router needs to be restarted or the cable needs to be replaced.
You may also need to open some ports for tivo on your router too but not a must. You can see the instructions of connecting your Tivo on the following link. Remember to install the software of Tivo if not yet and required by your model of Tivo.
http://support.tivo.com/app/answers/detail/a_id/107/session/L3NpZC9mLTRmWUM4aw%3D%3D
Posted on Aug 28, 2010
D-Link router settings for connecting to a TIVO - wired
It is all about managing the IP's. The router and TiVo should be set to DHCP. This will allow auto IP addressing. It could also be set to static, but this requires more managing on your part.
Jan 02, 2013 | D-Link Computers & Internet
Tip
Do you have a Tivo Premier and are you experiencing wireless communication...
Recenty, I discovered that devices were dropping off of my wireless network (Netgear N300 wireless N with DSL modem). After trial and error, the solution to the wireless communication problems was to create a wireless N bridge using the Tivo Wireless N adapters.
To use this feature, you will need two Tivo wireless N adapters. One wireless N adapter should be set to bridge and plugged into an available ethernet port into your router. The second adapter should be set to client and plugged into the ethernet port in the back of the Tivo Premier. Once the power has been applied to both wireless adapters and the Wireless adapter (connected to the router) has connected to an available address on your router, press and hold the button (on top of each adapter) to establish a secure wireless connection between both adapters.
Once each adapter has established communication, you will have a separate 5Ghz Wi Fi signal (as well as a channel )dedicated to you Tivo devices throughout the house. Each Tivo Premier added to the house should have the wireless N adapter and connected using the secure connection to the wireless bridge by pressing the button on each adapter (the one on the router as well as the one on the Tivo to install).
If sucessfully installed, you should be able to connect to all Tivos on the network for management as well as streaming. If communication between the Tivos isn't successful, you will have to restart each Tivo and establish a new connection to the Tivo service.
Another suggestion when using the wireless N adapters is to setup a static IP address on each Tivo that is higher than the IP address assigned to the wireless adapter. Each Tivo utilized two IP addresses for each device (one for the adapter and one for the Tivo). You may have to check the router administration screen to determine the IP addresses used for the wireless adapters before establishing a static IP address for the Tivos. If you assign static IP addresses to each Tivo, you will have to restart each Tivo and reconnect them to the Tivo service to establish proper network mapping.
With this wireless network configuration, you will ensure that your Tivos are connected to the service using high speed, dedicated wireless N communication for streaming purposes between the services offered while not impacting other computers, servers, video game machines, and tablets that are connected into your house.
Since the Roamio uses a built in wireless adapter, you may not have success in adding a Roamio to the wireless bridge created on your router unless you disable the built in wireless adapter and purchase the external wireless N model from Tivo.
Instructions on setting up wireless bridge can be found at this location:
http://support.tivo.com/app/answers/detail/a_id/1590/kw/wireless%20n%20adapter
on Oct 02, 2013 | Tivo Premiere 4
I want to get the TIVO AG0100 wireless adapter. I do not have wifi in my house so will it still work? I'm not planning on getting wireless for my computer.
Dear,
Since it's an adapter and not a router, it will not work if you don't have a previously installed wireless network.
You might buy a wireless router and connect it to your computer and use Tivo at the same time.
Jul 22, 2011 | Tivo AG0100 Wireless G USB Network Adapter
I changed from bellsouth to comcast as my internet provider - the comcast tech disconnected my router, saying I didn't need one. Now my tivo can't connect to my computer - I need to reinstall and...
actually, he did so because they don't "support" anyone else's equipment. once he verified your connection with them that way, he left. an easy solution would be to reconnect your router back into your system just like it was before. reboot everything, and everything should work just like before, including tivo.
Sep 08, 2010 | Dell TrueMobile 1184 Wireless Broadband...
Need my network name to connect to TIVO. Thanks,
Your network name is the name (SSID) the router broadcasts continually so your PC and other devices can detect it when you power them on. So if your computer has a wireless connection to your router, the SSID will appear among the networks available when you first turn on your PC. Use this name to connect your Tivo. You will also need your WEP (entry key) to logon it on. If this doesn't work for you, get back for more help...Geoff
Apr 12, 2010 | D-Link DI 514 Wireless Router (DI-514)
How to connect Tivo to WRT160N router wirelessly
you need to go to tivos website and see what "wireless usb adapters" are available for your unit.They range between 40 to 80 dollars each if your tivo is wireless compatible
Nov 06, 2009 | Linksys WRT160N Wireless Router
Tivo says that a list of ports have to be open on
Easy done man, use these steps.
Start>Run>Cmd
Type: ipconfig
a list of numbers should come up. After that, open up your web browser. Look for the number that comes after "Default Gateway"
Enter that into your web browser. It will take you to a page that might ask for a password. Try "admin"
From there you go to basic settings and there should be spots for you to add ports acceptations.
Add them then "apply" or "save" the settings.
After that it will ask you to reboot for the changes to be saved. Do that and you should be good to go man. Good luck.
Jul 10, 2009 | Blitzz Technology (BWA611) Router
Wireless network
Do you remember your wireless network name and the wireless security password for your router, check if you are able view the wireless network, try connecting to it..if it asks for passworg type in your password and check if nor revert back..
Jul 17, 2008 | Linksys Wireless-G Broadband Router
TiVo/Linksys Compatability
The router should be fine.
Use a Compatible Wired or Wireless adapter.
Jun 19, 2008 | Tivo Series 2 80-Hours Video Recorder
TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Mar 01, 2008 | Tivo Series2 TCD649080 Video Recorder
Zonet ZSR4134WE Wireless Router Logo
65 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
