Question about Sport & Outdoor - Others
My jet ski runs but only at half power and bogs when throttle is applied. starts fine. is this a good time to do a rebuild as well?
SOURCE: kawasaki 750sts jet ski won't start - electrical
Have you replaced the starter relay.
Posted on Jul 08, 2009
  • 139 Answers
SOURCE: peugeot jet force 50 engine cuts out on overrun
when the engine dies pull out the spark plug and earth the plug on the metal part and turn it over dont hold the spark plug as you will get a shock if the plug sparks you know the ignition system is working.if you have no spark do a compresion test to see if there is a problem with the engine.if that ok you will have a fuel problem make sure the breather on the fuel tank isn blocked or trapped.
Posted on Oct 08, 2009
nova2nv
  • 197 Answers
SOURCE: My Polaris freedom(jet ski) starts and runs good
Replace exhuast temp sensor.
Posted on Nov 14, 2009
nova2nv
  • 197 Answers
SOURCE: jet ski will not run at full throttle
Jet skis have a problem with the fuel pickup tube in the tank getting plugged up,also check to see if your exhaust is getting to hot,you should be able to keep your hand on it without getting burned if your water jackets are not plugged
  • 677 Answers
SOURCE: Sea doo jet ski won't get full throttle. It idles
I am not sure of the model that you have,so its a bit hard to help.If you have a seadoo and you want great help,I would go to seadooforum.Its the best site with really good,and also total knowledge of all things Seadoo.I have one also.The help is unsurpassed.I have a seadoo also.Hope this helps you
Posted on Feb 03, 2010
Starts and idles fine runs half throttle when fuel is applied
Harry, dirty carb or injectors.
Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Jan 06, 2016 | ATVs
Jet ski is "hard stopping"
Any motor that runs and then develops sudden stopping symptoms gives me suspicions of fuel delivery problems.
I'm not familiar with your machine, but I would be looking at the fuel filter as probably plugged up.
Wild guess, but sometimes I luck out.
Cheerfuls.
Sep 06, 2015 | Cars & Trucks
Help!! '97 Seadoo GTI, just had the carburetor rebuild, replaced the Rectifier Regulator, replaced the spark plugs and recharged the battery. But the jet ski would only reach 40mph and it would bog down to...
Sounds like you might have the rotary valve in the wrong position. Also you are going to need to replace your fuel lines and check the fuel petcock for any blockage. Lastly, when u rebuilt this carb did you check the tiny fuel filter behind the pump body?
Sep 23, 2013 | Sea-Doo US Boating
Half speed at full throttle
what kind of jet ski we talking about year make model
Jul 06, 2012 | Sport & Outdoor - Others
2003 yz 250 starts and idles but runs rich and bogs as soon as the throttle is applied
Hi, Anonymous and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent or overflow.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
11. The enrichner valve not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2002 yz250 idles fine but bogs and tries to die when twisting the throttle...
Bike dies when you give it throttle
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 19, 2012 | 2003 Yamaha YZ 250
My 1994 kawasaki 750 ss jet ski will only go half speed when I have the throttle wide open?
Is it bogging down, or just stops revving at the point...first check the throttle cable, twist it wide open and make sure it's opening all the way...after awhile they tend to stretch and that won't allow you full power....i hope this helps.
Aug 29, 2011 | 1989 kawasaki GTR 1000
Xr400r's been stood a while, had trouble starting it, changed the plug, now starts easier but bogs on use of the throttle and only runs with the choke on half, changed the fuel cleaned the main jet but...
Make sure the carb is thoroughly cleaned, all jets not just main. The half choke is compensating for the slow circuit jet. Check your air/fuel mixture. Also, check the air and fuel filter. If all checks out fine and you still encounter the problem, could be : bad gas, wrong spark plug heat range, or most likely the diaphragm for the top of the carb.
Aug 12, 2011 | Honda XR 400R Motorcycles
Sport & Outdoor - Others Logo
70 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
