Question about Dryers
Ggw9200lq0 how to move door - Dryers
  • megaelectric Jan 23, 2009
    MI MAQUINA PRESENTA EN PANTALLA ERROR E1
Question unclear, but I assume you mean to make a left-hand door right-hand or vice versa.
Depending on make, mfg may have kit. I just did it on Whirlpool Duet & kit and instructions came with dryer. Not rocket science, but can be confusing if you're not real handy..
Posted on May 07, 2008
How do you move the door jam in a sunfire so i can close the door?
Have you tried moving the latch on the door jam?
Jan 13, 2018 | Cars & Trucks
Gas dryer model GGW9200LQ0 not heating. Thermal fuse, thermistor are okay. I changed Solenoids and it's still not heating. Is the igniter the next thing to check? The flame sensor is hard to reach.
The igniter should have been the first thing checked. If you can see the igniter and start a drying cycle, you will know whether it is working. It is quite common for the heating element to crack over time.
Jul 08, 2016 | Dryers
Garage Door: How to fix single car garage door that is in raised position, on tracks but will not move using the power opener or manually?
Gary released the lift could be the rails that the rollers ride on are bent or damaged what you can try is disconnect the 4 panels and try moving top panel inside the rails slots movement to the back and force and see how it works if ok then hook up the next and try it and next try it and next try it this way you can see if one of the panels or the rail is not correct lined up until you have all 4 panels connected again or check with your house insurance and see if they will cover you installing a new garage door system.
Feb 21, 2015 | Building Materials
Why wont my lock move/? I can hear the motor moving but lock doesn't move
Try with your door open. Also be sure that you can operate it by hand. If not, the motor can't move it either.
Facing the outside of the door, if the hinges are on the right, it's a right-hand door.
Sep 03, 2014 | Weiser Lock Powerbolt 1000 Lock
Trouble garage door
Disconnect the door so the belt and pulleys will run without a large weight to move. If they move ok, reattach the door and try again but help the door move with your hand. If it moves ok then, the door levers and joints may be too stiff and need lubicating and wiggling until they move freely.
Nov 16, 2013 | Ultra Max Home
How to adjust rear doors onhj75 troopy
the door hinges move in or out to adjust that side of the door and the door lock latch moves to adjust that side.. loosen the door hinges just enough to move the door then -tension them to see how you are going. With the door open and the bolts slightly loose it may be possible to move the hinges by placing a long bar on the hinge past the door edge and hitting with a hammer
Jun 26, 2013 | Cars & Trucks
1998 blazer heat works great but defrost doesnt, could there be a blocked hose and how do i check?the defrost at the front wont blow.
if you have heat and nothing blows on defrost then this is a mode door problem that is not changing from floor to vent to defrost mode.it could be the mode switch or the mode door not working.the mode door is on the air duct under the dash and you can manually move it when you disconnect the control with your hand it should move freely.some of these have a small motor that moves the door.and if you move the switch in different modes or better have someone move the switch while you see were the door is the one that is moving is the mode door.if it won`t move on defrost tap the motor and see if it starts to work.if it does then it will have to be replaced if not it could be a switch problem.
Oct 26, 2011 | 1998 Chevrolet Blazer
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
Ice/water tubing broken during move
If the tubing broke off evenly at the door , have to replace the door . G E's cant replace the tubing INSIDE the door . A used appliance store may have a door .
Aug 05, 2009 | Freezers
Dryers Logo
160 people viewed this question
Top Dryers Experts
