Question about Eureka 4700A Maxima Bagless Upright Vacuum
I think my maxima got too hot and shut down. Is there a fuse that I may of blown that I can check or is the motor probably fried ? Thanks, Teri
  • 33 Answers
The motor has a shut off when it gets too hot. Wait 30 minutes to an hour to turn it back on. The airway is blocked, causing motor to get hot. Check filter, clean it out, check hose for clog.
Posted on Aug 29, 2010
Vax stopped mid vacuuming,as though fuse in plug has blown.checked fuse,OK.no lights lit.vax not working.
Most vacuums have thermal protection on the motor that will shut it off if it gets too hot. If you can turn it off, wait 10-15 minutes, and it works when you turn it back on, that's what is going on. Now, the motor shouldn't normally get that hot, so your next challenge is finding out why. Check for any blockages in the air flow or cooling vents, and if the motor also powers something like a beater bar, make certain that it turns relatively freely.
Feb 02, 2016 | Vax Vacuums
I was using the Dyson, turned off to empty tank, will not turn on again, I have checked outlet it is ok. Does it have some kind of safety if it gets to hot.Thanks
hi.
there is a thermal fuse built into the motor of all dysons that will cut the power if the motor gets too hot.
when the motor cools down again, the fuse will normally reset itself.
try the hoover again after a few hours and see if it works again.
also change the fuse in the plug to check that that has not blown
Apr 03, 2011 | Dyson Vacuums
My iron model f1060 won't even get hot or the green light won't come on. I haven't had a year yet.
If you have a warranty I would suggest bringing it bak and exchanging it. Sounds like you could have a blown fuse, shorted wire, or a fried device.
Jan 06, 2011 | Black & Decker Vacuums
Machine wont turn on
Either the motor is fried or the belt is burnt. If you can't hear it turn on, then check for any fuses that could have blown. They will be glass tube type. If fuse is good, motor or power supply could be bad. You can test them with voltmeter.
Sep 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Vacuum shut off
The motor gets hot when airway is blocked. Check your filter for debris deep in the pleats, clean it out, also check the hose for blockage.
Apr 04, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
VX3000c Keeps shutting down after a few minutes of use
it has a thermal fuse in the motor compartment. it is indicating a over heated motor. check the exhaust for clogs or feel the motor it should be warm but not hot to the touch
if its just warm, the thermal is lying to you and needs to be replaced
Nov 26, 2008 | Broan-NuTone VX475 Bagged Central System...
Kenmore Progressive Canister w/Hepa Filter
May have a problem with the motor protector or the motor itself. The motor thermo protector will shut the motor off if it senses it getting hot. So it could be bad.
Apr 13, 2008 | Kenmore 22313 Bagged Canister Vacuum
Regina 12amp bagless vacuum cleaner
i don't know about this particular model, but if you did opperate a full vacuum cleaner until it got hot and went off on it's own, this means you might have overloaded the motor and blown the protection fuse. in this case, you might have to change it. refer to the owner's manual about overload protection.
Mar 30, 2008 | Vacuums
Motor gets hot in moments and shuts off
True, the motor has safety measures to stop it from overheating... that's why it shut down. You smelled something, so some kind of damage was done. It's possible that the over temp switch itself got fried. Doesn't sound too good from here.
Mar 08, 2008 | Filter Queen Majestic Canister Vacuum
Hoover wind tunnel vacuum cleaner shuts off during use
Check the inlet down by the brush roll to make sure it isn't clogged. If not and the hose isn't clogged, then probably the thermo protector (part #28382093) maybe bad. It is mounted near the motor. Could be motor Part #43576188. But I would suspect a clog in the inlet or hose, or the thermo protector has gone bad.
Dec 25, 2007 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Eureka 4700A Maxima Bagless Upright Vacuum Logo
219 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
