I have a TOSHIBA Qosmio G25 PQG20U-10K00E System Serial Number: 85066832H Notebook computer. It currently has two RAID internal hard drives of 60gb each. One of the drives is rattling, so I need to replace it. I would like to replace both at once. My questions: 1) Can I replace with a higher capacity or is this machine somehow restricted to only what I now have? (I would like at least 120gb each, but Toshiba tech says to keep the existing size -- I don't know why.(?)) 2) The current drive speed is 5400 rpm -- is there anything compatible that is faster? (These are a SATA drives.) 3) How do I go about transferring all my existing data onto the new drives?
  • 2 more comments
  • mcdonagh_j Aug 28, 2010
    Thanks!
    Already upgraded RAM to its full capacity.
    By "copying" drive data, I meant making an exact duplicate -- a clone, if you will -- so that I won't have to reinstall everything (including OS and all applications). Is THAT possible, rather than simply transferring the data as you suggest?
    Also, why am I limited to 120 gb? (I assume you mean 120gb EACH, correct?
    Solution 1 posted 11 minutes ago
    walesarumi
    Rank: Wiz
    Rating: 83.38%, 724 votes
    you can replace the hard drive to 120GB. The tech was advising you not to upgrade the drives because the capacity of the system motherboard, processor and Ram might be to small of the drives.
    But I would advice that while you upgrade the drives, you will also have to upgrade the system ram so that the system won't be slow as a result of the larger drives.
    Lastly, to transfer your data, get an external drive and copy all the data into it, before you upgrade the drives.
    I hope this is clear to you now.
    Good luck.
    Comments and Clarifications:
    mcdonagh_j
    3 minutes ago
    Thanks! Already upgraded RAM to its full capacity. By "copying" drive data, I meant making an exact duplicate -- a clone, if you will -- so that I won't have to reinstall everything (including OS and all applications). Is THAT possible, rather than simply transferring the data as you suggest?
    mcdonagh_j
    18 seconds ago
    Thanks!
    Concerning the last (part #3 of my question), I want to transfer everything, i.e., the OS and all applications, not just the data. Can I clone the hard drives so that I can just plug the new ones in without having to reinstall all my programs and settings?
  • 4,924 Answers
They just go along in a conservatory mode all the time ...
as long as you will buy same speed and bus( sata) they will fit and work ..I think they will be working with different speed also ...but to be in the 2.5 Sata to fit in the place ..
and the size it is not important ..you can even insert 2 x 500G each ..if you want ..the power used will be the same ...maybe a little more...but the rest will not matter ..
How to transfer ??nothing more simpler..
To avoid double boot...(to have 2 operation system in the same time ...cause this is confusing ..) first insert the new Hdd..and install the operation system on it ....
than in the place that remain empty ..insert the Hdd that has no operation system on it ..(one of the old ones.D drive ...) and move all the files from it ..to the bigger one that you just installed..and after that format it to remove any other leftovers..
Now..remove the new one ...and insert the one that was in the first place ...Boot it up...and move any files you need from it ..into the one you just cleaned..
Remove it ,and insert the new one again ...now you can move the rest of the files in the new (bigger ) one ..
if you got a second new one ...install it in the place of the old one you used to transfer files..and you ended up with 2 new biiger hdd and with th efiles from the old on in it ..format the second one ..move the files as you please.
The other ones are useful in this moment to make external HDD from them ...Just buy a couple of rack cases from eBay ..and transform them into USB based hdd..to use for transferring data ..and such ..or store excessive ones..
Here is a link with some Hdd that will fit..and some rack adapters I was talking about ..
The idea if you will be able is to buy the stuff from a shop around your area..so you will have a healthy warranty policy ..I only link this to make you an idea about..
HDD'es
http://computers.shop.ebay.com/500-699-GB-/158855/i.html?LH_BIN=1&LH_FS=1&_nkw=HDD&_catref=1&_dmpt=PCC_Drives_Storage_Internal&_fln=1&_trksid=p3286.c0.m282
rack enclosure for 2.5 hdd
http://cgi.ebay.com/USB-2-0-SATA-2-5-HDD-Hard-Disk-Drive-External-Case-/280548681702?pt=PCC_Drives_Storage_Internal&hash=item41520127e6
For the Hdd the isdea is to be sure they are on 2.5 and on sata..not to buy another kind...and not fit in...cause toshiba works on 1.8 also ..
Posted on Aug 29, 2010
  • 857 Answers
The total capacity of the harddrive what you got with this machine was 120 GB since you are using RAID technology it is 60 gb + 60 gb, and the what your system supports is 5400 rpm for your computer.
But if you want you can increase it to 80gb of the two or too the max of 120 gb each
because i have checked your processor which is intel Pentium M 760 so there should be no problems upgrading your harddrive.
If you wish you can also see it refer to this link below
Processor info : http://ark.intel.com/Product.aspx?id=27595
you can see your system configration at :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1021511&rpn=PQG20U&modelFilter=G25-AV513&selCategory=2756709&selFamily=804517
ans 2 : you can also change the rpm uptill 7200
ans 3: if you want to back up your data use any external device.
Posted on Aug 28, 2010
  • Jayant Jha Aug 29, 2010
    yea you can place 120 gb each that makes it 240 gb in total.
    (120gb+120gb).
  • 6,993 Answers
Good luck.
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
I want to upgrade my Toshiba Qosmio G25-AV513 to windows 7, but I understand that some of the programs will not function properly due to the old hard drive. Is this true or is the company I called for...
Uhm. I am typing this from a Qosmio G25-AV513... Using Windows 7.. With the original Hard drive.. Someone is lying to you. Lemme guess.. Best Buy?? Anyway.. It wasn't a totally straightforward upgrade.. You will need a little computer knowledge (finding drivers, ETC.) And since this computer came with a RAID setup, you will need to download the windows 7 raid drivers, and put them on a thumb drive BEOFRE you start installing, because when you get to the install screen it won't find a hard drive, you have to put the thumb drive in and click "Load Drivers", then load the RAID driver and it will work.. Drivers are kind of a pain to find since Toshiba didn't update their website with Vista or 7 drivers.. Thanks Toshiba. If you need help, e-mail me. P2000Canaro@gmail.com. Good luck!
Dec 02, 2010 | Toshiba Qosmio G25 (G25-AV513) PC Notebook
Qosmio won't boot up Black screen with ATA #0 ERROR
Errr....pull the hard drive out and boot the computer.
What happens?
Sep 25, 2010 | Toshiba Qosmio G25-AV513 Notebook
I need Qosmio G25 AV513 Hard Drive replacement. Can you suggest source?
I would suggest getting your drive specs from t he company and then just ordering one from Egghead or Tigerdirect onlline.
If you want a local provider a Best Buy or a Microcenter would do.
Be sure to save all the mounting parts off the old drive! You will need them for the new one.
Jun 27, 2010 | Toshiba Qosmio G25-AV513 Notebook
I cant make the Raid for disks
RAID requires 2 or more individual hard disk drives. You cannot create a RAID using only 1 drive.
Jan 05, 2010 | Toshiba Qosmio G25-AV513 Notebook
Unable to boot from HDD1 position or recreate RAID1.
you need to go into your bios and tell it to boot from the other hard drive make sure you plugged in the right wire to power it it should be the same as one used for the hard drive that works and plug it in tightly.
Nov 20, 2009 | Toshiba Qosmio G25-AV513 Notebook
Hard drive not seen in windows xp
It is not showing up in XP yet because it has to be partitioned and formatted first. You can see it in disk management and partition it from there, then format it.
Apr 15, 2009 | Toshiba Qosmio G25-AV513 Notebook
Spilled Water on Toshiba Qosmio G25-AV513
If you are pretty good at computers then you can open up the computer and see just how bad the damage is. You may need to replace the keyboard, or a few parts of he mother board. If it was water I think you would have more of a chance, but the sugar will definitely cause problems if it hit any circuit boards. Your best bet is to take out your hard drive, make it an external hard drive and get a new computer.
Dec 26, 2008 | Toshiba Qosmio G25-AV513 Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
