Question about AudioTrak MAYA 44 USB External Sound System
I have a maya ex soundcard when i run pcdj via a mixer i get both A & B players on the PCDJ programme playing only out of one channel where as it should come out of both channels so as I can split the music and have control of volume on each channel on the mixer. It was working fine but I friend deleted the driver for the soundcard and when I reloaded I had this problem. Can you offer any assistance please?
4 Suggested Answers
  • 108 Answers
SOURCE: Maya44 poor sound quality
Check the maya graphics card audio settings. there may be some improper audio setup. the Maya 44 card audio codec and filters are not supported by your OS. Your system configuration is good. there may not be any problem with Pc compatibility. only because OS audio codecs. try dowloading codecss for this audio rendering device
Posted on Dec 20, 2007
SOURCE: maya 44 usb problem
you need to make sure that you are actually choosing maya on both cubase and virtual dj and config settings
Posted on Dec 20, 2008
  • 7 Answers
SOURCE: Problem with Maya44 USB Outputs
Posted on Feb 13, 2009
Bug in program.... either reset computer date to any month or year prior to 7/2013 ( and set check boxes to not to set clock over internet other automatic time adjust ). OR use a stand alone program to open PCDJ like " RUN AS DATE" ( keeps computer clock normal for other programs and restore,,, etc. ). But requires that you open it in that program each time.
If anyone hears of a better fix... please post.
Jul 24, 2013 | Audio Players & Recorders
Repair invalid floating point operation
how repair invalid floating point operation
Jul 23, 2013 | Visiosonic PCDJ Red Pro DJ Software
Pcdj wont play on vista!!
I had the same problem, try installing XP instead. Email me if you need more help.
May 09, 2010 | Visiosonic PCDJ Red Pro DJ Software
carry on the install and ignore the message that says your missing windows media update is required , this has happened to me before and i have spoken to pcdj and they said its a common problem, also don't forget to set the program as administrator once installed ! happy DJ'ing !
Mar 16, 2010 | Visiosonic PCDJ Red Pro DJ Software
How do I load play lists from iTunes in to PCDJ
OK problem here is that PCDJ only supports .mp3 and .wma format files. itunes files are NEITHER unless converted. so convert then monitor folder as normal.
Nov 16, 2009 | Visiosonic PCDJ Red Pro DJ Software
Loading error file
probably you need to install windows media player encoder .
try to download this one
if you still have problems, try to check if your software is compatible with windows media player formats.
Aug 13, 2009 | Visiosonic PCDJ Red Pro DJ Software
PCDJ Blue won't run
If you want to rip cd's use ashampoo music studio or xilisoft products as alternative as PCDJ is not compatible with all pc's and if you are using vista then on the UAC you need to permit the install or it wont work.
Feb 23, 2009 | Visiosonic PCDJ Blue Pro DJ Software...
All of a sudden my Echo Indigo DJ soundcard will play both virtual CD players on my PCDJ software on one channel. For a while, I had cd 1 on one channel and cd2 on the other. I am using a pig tail plug...
I can run audio on 3 separate channels/outputs of my laptop
I use Tricerasoft Swift Elite DJ software but the areas you need to look at for troubleshooting are probably similar:
1) check the (PCDJ) software settings for selecting the channel outputs of your Indigo DJ on each deck/ player. NOTE: 1/2 and 5/6 are the same physical port (headphone port), while 3/4 and 7/8 are also shared on the Line Out port. So make sure you use for eg. one player uses 1/2, and the other player uses 3/4 ONLY IF you want them running out to separate channels on the mixer
I personally run both my decks off the same channel, ie 3/4 so that my software can do the mixing for me. My mixer only acts as an master control device where everything else connects
2) Make sure you check your IndigoDJ Console (installed to the Windows Start menu under Echo Audio, Indigo DJ), if you have any conflicts or if for some reason one particular channel pair gets inadvertently muted, resulting in no sound coming from the port.
3) I also use my onboad sound card (typically for previewing music or for an auxillary output). This is obviously controlled by the Operating system... in Windows is is through the Sound properties, default sound device. I recommend NOT using Indigo DJ as a default sound card -- but that is a personal preference.
So in this way you actually have 3 outputs for sound
As far as cabling is concerned, it depends on what you are connecting to. I use a 1/8 (mini computer) jack to 1/4 whcih then plugs into a direct box (eleminates any static hum etc), then from the DI box using an XLR cable to the mixer. Your setup may be slightly different.
Hope this helps!
Dec 01, 2008 | Echo Indigo DJ Sound Card
  1. Reduce the number of files you have in each folder.
  2. Break them down to under about 500 tracks per folder and this should solve your problem
Apr 12, 2008 | Visiosonic PCDJ Red Pro DJ Software
AudioTrak MAYA 44 USB External Sound System Logo
Top AudioTrak Computers & Internet Experts
David Payne
David Payne
Are you an AudioTrak Computer and Internet Expert? Answer questions, earn points and help others
