Question about Samsung Televison & Video
How do you remove the stand from LCD tv model LE40A656A1fXXU
  • 15 Answers
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Posted on Sep 06, 2008
SOURCE: Removing Insignia 37' TV from Stand
There are 7 screws on the back of the tv - should be a phillips, once you have taken all out pull the tv up. If you figure this out I would be willing to buy the stand off you. I removed mine since moving and thought I did not need and threw it away, now need a stand. Email me at co45lt@gmail.com if you are interested.
Thanks
Posted on Nov 02, 2008
SOURCE: Removing the stand from a Proscan TV
Remove 4 screws on the bottom.
Posted on Apr 03, 2009
  • 105 Answers
SOURCE: How do I remove the stand from my JVC LCD TV model LT-52GZ79?
stands are always attached by four screws located at the middle of the lower rear portion of the TV cabinet
Posted on Jul 08, 2009
SOURCE: how to remove stand on vivo 32 inch lcd tv
if you send picture to semirengeee@yahoo.com , i can try to help you
Posted on Sep 12, 2009
Cant remove stand from LC46SB54U - dont see 2 prongs going into back of TV...this is what my model looks like. http://lcdtvsale.devhub.com/blog/167586-sharp-lc46sb54u-46-inch-1080p-lcd-hdtv/
Look at page 7 Quick reference section
for similar model here:
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/LCDTVs/Manuals/tel_man_LC46_52SB57UN.pdf
If the mounting mechanism is similar you will need a hex key and loosen 2 pairs of screws on the back near the bottom. The stand should then slide out from the bottom edge.
Oct 18, 2012 | Sharp LC46SB54U 46 in. LCD TV
I can't remove the stand from my 42" Panasonic plasma TV (model: th42px80a) - can it actually be removed?
Yes you can remove the stand ,But you will have to take the back off in order to do it.
Jun 29, 2011 | Proscan 32LB30QD 32 in. LCD TV
How do I remove the stand from the tv?
unfortunately you do not include the brand and model of the tv. Anyway, lcd tv usually has 2 screws on its stand. Unscrew them all the way. Hold yuor stand and slide your tv up or horizontally to release it from stand.
Apr 30, 2011 | LG 42LC2D 42 in. LCD HDTV
How to remove stand from Panasonic TX6LMD70A LCD TV
Didn't find this model on the web. I take it it's a LCD flat panel monitor/TV?
Usually the user's manual will have instructions of how to remove the stand.
Usually there are 4 to 6 bolts in the back of the set that you remove and the stand slides out.
Feb 02, 2010 | Televison & Video
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
How to remove tv stand from toshiba 42 inch lcd model 42hl167
Remove 5 screws as shown in below image to remove stand of TV.
It is also mentioned in user manual of TV page-5, click Toshiba Support to download a copy, if required.
Thanks.
Aug 30, 2009 | Televison & Video
Jul 07, 2009 | Televison & Video
Apr 01, 2009 | Televison & Video
How do I remove the stand from a panasonic tv. model TX - 32LXD70
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
Jan 31, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
Question on toshiba tv - fixya post
Found this on the www.Toshiba.com website. Q. How do you remove the stand?
Models: 26HL37, 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL167, 42HL67,
47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00078
1. Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface. NOTE: Extreme care should always be used when removing the pedestal
2. Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can
3. Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4. Once you have removed the five screws holding the pedestal stand in place, remove the stand from the TV by
sliding the stand away from the TV. The Toshiba customer service number is 1-800-631-3811. Hope this helps you with your problem.
Dec 22, 2008 | Toshiba 42HL167 42 in. LCD Television
Televison & Video Logo
62 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
