Question about Emerson EWL3706 37 in. LCD Television
I have a Emerson TV the HDMI does not connect with the PlayStation or DVD Player When I connect my HDMI to the PlayStation appear on the screen writing says formate not supported
4 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Posted on Dec 14, 2010
  • 4 Answers
SOURCE: blue screen with HDMI
The HDMI port might be loose on your TV. I had the same problem. I went to radio shack bought a solder and soldering metal with some flux. I then opened my 37inch Sceptre Naga and aligned the hdmi connectors properly to the board, I then soldered the hdmi port firmly into place. This fixed my blue screen problem.
Posted on Jan 12, 2008
SOURCE: PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
Posted on Feb 17, 2009
I have a 39 inch Emerson hdmi led tv and it is hooked up to Directv. I'm trying to hook up my daughters DVD player it is a Sv 2000 DVD CD player e everything is hooked up we get sound no picture.
hi try using RCA cables to make sure youre connections r not the problem..plug the rca cables n the output of dvd then into tv input & set tv input to AV .good luck
Sep 02, 2015 | Emerson Televison & Video
Emerson LCD TV Model LD190EM1 Sony Blu-Ray Disc Player, Model BDP-S3100, The TV screen gives an error reading "Format not supported" when I connected it using either HDMI connection.
This HDTV is rated display signals up to and including 720P resolution according to the spec linked below. If you are outputting a 1080i or 1080P signal from your BD Player, this could be the cause for the error message. Many HDTVs will accept signals higher than they can display - and simply down-rez to the highest resolution that they can display.
Connect the BD Player to a device that can display the signal. Enter the player's setting and change the output to 720P. Shut it off / disconnect cables as needed and reconnect it to the Emerson HDTV and see if it will display properly.
If it does, you're all done! if it doesn't - there's something else going on that isn't readily apparent to me. Good luck!
Emerson LD190EM1 Specs CNET
Mar 03, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
Cannot connect DVD/CD player/Magnavox Model#DV200MW8 to Emerson Flat Screen TV Model#LC320EM2 (pdf)
This is true, there is no direct output from the player to that model. You can however get a converter. The easiest path would be A/V to HDMI using a converter box made to make that connection. If you prefer, use a different player to connect to that set.
References:http://www.emersonaudiovideo.com/products/product.php?id=27
http://www.walmart.com/ip/Magnavox-DVD-VCP-Player-DV200MW8/5585221
Mar 24, 2012 | Magnavox Televison & Video
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
DVD hooked up to sony bravia tv: have dvd power on, but can not get any set up menus (or anything) from dvd to show on tv screen.Unable to set up remote as menu does not appear on tv screen.
Hook up the player with RGB (Red-Green-Blue or component) cables and try the picture. If everything works OK, then go to the menu and turn on the HDMI output and set the resolution (if needed).
Not every HDMI unit works with every HDMI TV. You may also have a bad HDMI cable. On a DVD recorder, you may have your HDMI cable connected to HDMI IN. You must use HDMI out.
Mar 28, 2010 | Sony RDR-GX7 DVD Recorder
I need a firmware or software update to play a hddvd in my flatscreen/dvd combo. its an emerson 19inch flat screen model ld195em8
Sorry to say, but a firmware update will not reformat your DVD player into BluRay or HDDVD capabilities.
There is only one way to get your TV to display BluRay DVDs, that is to purchase a BluRay player and connect it to your TV with a HDMI cable, now this will also require your TV to have a HDMI port to connect to, and your TV must be able to display full
1080p resolution,with that said I don't know of a 19" TV that is full 1080p capable,especially not a combo unit.
Good luck !
Jan 11, 2010 | Televison & Video
Connecting hdmi and dvd player to 32" emerson
get a splitter switch if you can find one .it will allow 2 devices ,and you can select which one you want.
Jun 12, 2009 | Emerson EWF2703 27" TV
Hi, I'm experiencing a problem on my 32" Sumsung LCD TV Screen. There are colours appearing in patches in different areas which come and go. Why is this?
Please let me know what are the components that you have connected to this tv?
DVD player?cable box?
solutiondoct
Nov 06, 2008 | Televison & Video
Emerson EWL3706 37 in. LCD Television Logo
470 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
