Universal remote for Sylvania
To Show DvD's the tv has to say "Game" on the screen. What do I push on the remote to get there? Without doing this it is impossible. I have a RCA and Phillips. I lost original remote
    President:
  • 2,712 Answers
You could try to purchase an original remte from HERE.
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 08, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
I am trying to get a remote code for my slyvania 6719
I also can't find the remote for my Sylvania
TV/VCR/DVD combo...
Model number 6719DF. I don't normally use this tv
(it's an extra spare that I plug into our generator when
the power goes out... since our regular family TV is
quite big and set into the wall making it difficult to
track cords around, I drag this crappy Sylvania down
from our dining room to our family room) I did
happen to find an old Zenith universal remote that
does work with it in some ways (See directions
below). I can turn the TV on and off, set the channels,
language, clock.. etc through the Input select button
on the universal remote but can't set to "Game Mode"
after using connections with video/audio input cords
plugged into the front panel of the TV. So
Playstations, extra dvd players or vcr's, etc won't
work.
Switching from the VCR to DVD and vice versa does
require manually setting the tv itself (remote doesn't
work with that) but at least I can set sub titles, fast
forward through chapters on Dvd's and control the
volume, etc without having to constantly walk over to
the tv.
Programming the remote: I've noticed a lot of people
have tried using codes supplied by different universal
remote providers and couldn't find a code that
worked using their lists with this particular model...
there is a way that it can be done but it's a bit more
time consuming:
Many types of "universal" remotes give the option of
"scanning" the electronic device for a code if one is
not available or the one provided with lists does not
work... Every universal remote though needs certain
buttons pushed during the "scan" and they are all
different! Ha! So if you lost or misplaced the MANUAL
as well (like me!) you might need to do a search on a
manual for your particular universal remote, but I can
at least give you directions on programming a
"Zenith" Universal remote to "scan" for a Sylvania
TV/DVD/VCR combo model 6719DF:
Using the Zenith Universal Remote or any Universal Remote using it's "scan" method:
1: Shut off the TV
2. Press and hold "Code Search" on the remote until
the red LED
light lights up and stays lit.
3. Press the device button for the device (In my case,
for my crappy Sylvania combo, I pressed "TV".)
The LED light will blink once.
4. Scanning: Slowly press and release the "Power"
button on the remote, waiting a few seconds between
while watching the TV to turn on. It's very important
that you pause in between because if you do it too fast
and the TV turns on before you press the power
button again... you'll have to start all over. I've
learned that lesson.
It took 160 presses each time on that button to get the
correct code scanned! I had to do it over 3 times
before I stopped myself beforehand because I was
pressing it too quickly..
5. Right after the TV power turns on, press the "Mute"
button on the remote to set the code. It should work with few limitations (no "game" mode)
after that.
May 26, 2011 | Sylvania 6719DF 19" TV/VCR/DVD
Remote doesn't work
Sorry Sarge...this problem is not that simple...and for some reason these Sylvania tv's won't allow you to access game mode that easy. I think the best idea (assuming the universal remote doesn't work out)...just buy another ORIGIANL remote from the manufacturer! Hooowah!
Jan 02, 2010 | Sylvania 6427TE 27" TV
How can I input my sylvania 27" into video 1 or video 2 without the remote? The menu does not offer a game option nor a video 1 or video 2 option.
Here are the instructions for the TV.
http://www.sylvaniaconsumerelectronics.com/pdf/om/6427TE.pdf
They do not say how to select Video or Game mode without the remote. Try connecting a vcr or game to the input and do the Channel Pre-Select process to see if that will pick up the input as part of the Channel Scan. If it does you will be able to get to Game or Video using the channel up/down buttons. Another option is to get a replacement universal remote that has a code for your TV and will assign a button for Game or Video.
Jul 29, 2009 | Sylvania 6427TE 27" TV
Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Jun 13, 2009 | Sylvania 6420FB 20" TV
Game mode not working properly on sylvania tv
did you try to switch the tv modes Ex. my tv has av 1 av 2 comp 1 comp 2 does it have those modes
Apr 21, 2009 | Sylvania Electronics - Others
Universal remote code for a sylvania tv/dvd Model
I went to Radio Shack an purchased a 15 dollar Phillips universal remote and it worked after entering one code for sylvania combo tv's. I did the Happy dance and now I can watch my tv again.
ONE FOR ALL® URC6131n Universal Remote Control
JiggyChic
Apr 06, 2009 | Sylvania Televison & Video
Jensen Universal Remote
HOLA NECESITO SABER COMO SE PROGRAMA EL CONTROL REMOTO UNIVERSAL JER 422 Y SU CODIGOS PARA PROGRAMAR TV DEAWOOD, SONY Y SAMSUM
ATTE.
GERARDO
May 03, 2008 | Jensen JER-422 Universal Remote Control
Lost Remote
I got mine off of game mode by using a universal remote. I had to type in a channel, (03) and it got it out of game mode, but I now have the problem of not being able to get it back into game mode so that I can use my DVD player. Good luck
Feb 07, 2008 | ESA EF402E 20" TV
Need dvd code
Do you happen to know the model# of your Sylvania DVD/VCR player? That will help me access the correct codes for your set. Let me know, thanks!
Sep 24, 2007 | Philips PM3S Remote Control
Televison & Video Logo
1,594 people viewed this question
Top Televison & Video Experts
