Question about E-Machines eMachines Desktop PC
EMachine won't start
Won't turn on, at all. It's a model M6810. I'm not sure how old it is, but it was working at least 5 months ago. Then all of a sudden it wouldn't start up. It's fully charged, and the charger light comes on. I've tried researching it but nothings turned up. Is there some keyboard combination I can hold while pressing the power button? Or do I need to replace something?
I don't think there was a virus or the like on it because the laptop was used for business and internet wasn't needed. I'm clueless as to whats wrong.
  • Siorghra May 07, 2008
    Oh sorry, I thought I was on the laptop forum and I don't know how to delete the question and fix it, sorry if it's an inconvenience,
  • Meatwell2003 Apr 04, 2009
    I have E-Machine t3624 windows xp. It will not start. I have put a new power supply. And the switch is good.Can you help with this?
    Thanks.
    Sergeant:
  • 324 Answers
You might try to bring it up after removing the battery. I've seen a bad battery cause problems like this.
Ron-
Posted on May 08, 2008
  • E-Machines Master
  • 1,183 Answers
With the problem that you have described it looks like the problem could be with the motherboard. As the charger light is coming on the system is getting power ,but there is a problem distributing it.
Try removing the parts like the DVD drive, harddrive and the memory from the system and then powering on the system .If it powers one of these components are causing the failure , otherwise its the motherboard.The follwing link gives you the user manual for your machine , go to the troubleshooting section for more details
http://downloads.emachines.com/userguides/M2xxx_M6xxx_notebook_UG_Online_030804_en.pdf
For more help you can send E-machines tecnical support your query on the following link
http://support.gateway.com/support/contact/contact_tech1_eMachines.shtml
Or you can call technical support at
Telephone Technical Support
Customer care representatives are available 5 AM to 12 midnight PT seven days a week.
United States 408-273-0888*
Thanks
Mandeep
To help me improve, donot forget to rate the solution
    Problem Solver:
  • 9 Answers
I agree with Proton77, try his advice and see the results
    Novelist:
    Champion:
  • 231 Answers
Another possible cause is your RAM has failed.
At start up try pressing the delete or F1 buttons to access the laptops setup
Regards mistyman
If you can't hear the usual whirring sound when you try to press the power button, it is probable that your processor has died on you. It may also be that the battery cells are due for replacing. The LED lights may turn on just fine when in fact your batteries are in trouble.
But more information on your problem may help.
2004 Honda Odyssey won't start or try to turn
You tried it in neutral but did you take it out of park and force it back into park? Just a suggestion since sometimes the switch that tells it that it is in park needs a bit of a nudge sometimes.
Sep 09, 2013 | Cars & Trucks
I have a 5 year old Emachines computer, a few weeks ago I bumped my foot on the desk that was holding the computer and the screen turned off and the tower started beeping. It was long continuous beeps. I...
Usually when you hear long beeps coming from your computer it telling you that there is hardware loose . You may have knocked something loose. Check cd roms , ports and cards , memory to make sure they are fitted in correctly . good luck
Aug 03, 2017 | Computers & Internet
Model 917.370410 won't start
Sounds to me like this model is a POS. I also have this same model, purchased last August have used only 5 or 6 times , has the same symptoms: hard pull, puff of smoke, won't run , etc. Even brought this to an authorized dealer to get it to run, but then it only ran a couple more times, dead again. Does anyone know of any recalls fro this lemon? I can appreciate everyone troubleshooting , but you shouldn't have to tear apart a 5 month old lawnmower which will only result in your warranty being voided.
Oct 04, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
Replaced timing belt and car won't run
You had better check the timing belt again, you may have done something wrong and it skipped teeth.
Sep 04, 2012 | 2001 Volkswagen Beetle
Emachine T5234 beeps 5 times and won't turn on
5 Short BeepsYour motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
Aug 15, 2012 | E-Machines eMachines Desktop PC
Dish washer won't turn on when start button is pressed
Check your door switch. My dish washer would not work a couple of months ago, tore apart and messed with door switch and it has worked every since.
Dec 22, 2011 | Washing Machines
CD-ROM IN EMACHINE M6810
you can check the drives and make sure all settings are correct
if it plays burned cd it should play factory cd
right click drive in my computer then properties make sure all settings are correct maybe you need to update driver
when did it start to do this
Jan 24, 2009 | E-Machines M6810 Notebook
E-Machines eMachines Desktop PC Logo
614 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
