Question about Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum
My shop vac does not seem to have as much pick up power as it once did. It will not even pick up small debris and paper.
  • 377 Answers
Turning the unit on with the motor NOT inserted into the "can" do you see the impeller moving? Should be connected to the drive of the motor one way or another. Check for debris on both ends of the motor shaft to be sure the motor is moving freely. If possible, hit both ends with some WD 40 to reduce friction. Be sure the hose is clear. I push a broom handle through mine from time to time to see if there is anything clogging it. Tear in the hose or in the couplings? Tape or replace. When was the last time you replaced or cleaned the filter?
Posted on Aug 29, 2010
Model # 14rt350 shop vac won't turn on. Reset? Fuse?
Is it new? You know if you don't keep your filter clean and hose cleared of debris they don't last long never run without a bag and or filter unless sucking liquids and liquid only
Jan 08, 2017 | Shop Vac Vacuums
Kobalt 10 saw blows dust everywhere ,even with a 2 shop vac connected to the dust chute .
It is possible that the dust chute on the Kobalt saw is plugged, not allowing the vacuum to pick up the dust. Run a rod through the dust tube and see if that clears it.
Jun 19, 2015 | Shop Vac Vacuums
Shop-Vac 6.0 hp Peak 12 Gallon 'Exploding' after 10 seconds of use. Happened twice on two different brand new Shop-Vacs.
Since you said you were sucking water out of a "trench" I would bet there was some debris in the trench that impacted the impeller on the vacuum and caused the metal impeller to fragment, taking the plastic pieces with it. It is highly unusual for this to occur on vacuums if some type of debris, such as a small stone or piece of metal does not reach the high speed impeller/fan. I suggest using either a foam sleeve over the filter cage, or an old nylon stocking if you can get one, to screen out the debris that will cause this condition.
Nov 20, 2013 | Shop Vac Vacuums
We inherited the shopvac 16 gallon. I bought the required filter (foam) but the dust blows back from the blow hole. Am I missing a part?
The foam filter is for use when using the vac. to pick up water. Now you should have a paper filter for picking up dry material.If possible you may want to look inside of one at the store. Hope this helps.
Jun 23, 2011 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
There are no known vacum bags for a model wd06350 vac
This type of vacuum does not use a bag. If you are worried about clogging the filter cartridge try using a paper filter for a shop-vac. They are relatively cheap and are available at most hardware and department stores. These are made to simply wrap around the big cartridge. A rubber band will hold it in place.
Feb 09, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Vac wont pull/**** anything while we try to vac floor,
Hello RonD30,
If you are getting suction thru the hose and not from the bottom section.. you have a clog somewhere inline with the base area... If you have access to a shop vac ... unplug the Hoover, open up the base and remove the beater bar /belt assembly.. then hold the shop vac nozzle on the point of entry to where the Hoover pulls the debris into the dirt compartment. I am fairly certain you have a clog somewhere in that ducting.. Stubborn ones may need a little motivation.. so you may be able to get an electricians snake or metal coat hanger bent to release the jam..
Hope that helps..
Regards,
Rick..
And you are right , regarding Lowes..but don't exclude Home Depot from the same rating..LOL Once the sale is done.. so are they...
Dec 13, 2008 | Hoover Vacuums
Set up the shop vac to pick up water
I figured I had nothing to lose so I just started vacuuming. I thought I had to turn the end of the hose that connects to the shop-vac around (which I did so that it brought the water down to the 'bucket'. Other than that, I even went to Yahoo Answers and asked for input. The answers were - just vacuum, they didnt think there was anything to do with the vacuum to set it up for wet vac. I had removed the cloth filter used for dry vacuuming so I was ok with that. I also saw a YouTube video that said basically to remove the cloth filter. Ok .... that was not so difficult. Thank goodness too.
Jul 26, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum Logo
168 people viewed this question
Top Ridgid Vacuums Experts
ken skalski
Thomas Perkins
Thomas Perkins
Tim Hunt
Tim Hunt
Level 1 Expert
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
