Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
My frige is not regulating well, is freezing my fridge and is in 5 celcius
  • KitchenAid Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
How do I regulate the temp in the display fridge. It's too cold at 1 deg C
Ideal Temperature is between 34-38 degrees Farenheit. 1 degree celcius converts to 1.8 x 1 + 32 = 33.8. This is ABOVE freezing and should be Perfect...
Oct 21, 2014 | Refrigerators
Fridge freezing food
6 degrees Farenheit = -14.44 degrees Celcius
Water freezes at 32 degrees Farenheit or 0 degrees Celcius
Most food contains water, so what's the question?
Mar 09, 2014 | Refrigerators
Hotpoint ffa91 My frige is freezing everything I put inside it.
sounds like the door between the freezer and cooler is stuck open
Jan 23, 2014 | Refrigerators
I have an amana bottom freeze abb2227dew the freezer is working fine but the frige isn't cold?
check the regulator or thermostat for the fridge and set it well.
if it is well set then your compressor is losing compression.
May 11, 2011 | Amana ABB2227DE Bottom Freezer...
My Samsung model RB1855sl shows the temperatures for the fridge and freezer in celcius. Can you tell me what appropriate temps would be for them to be working? I loaded up with gorceries a few days ago,...
the freezer should be arond -20 degrees celcius and the fridge aroud 5 degrees celcius
There could be a problem with air flow
the fan in the freezer has probably stopped or the air flow into the fridge is probably blocked
You could have a defrost problem. this would allow ice to build up in the freezer blocking off ai flow.
A technician can help you with that
Mar 24, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
I have a Samsung Cooltech Plus fridge that seems not be able regulate the temperature correctly. At times the temparature is 22 celcius and food gets spoilt, I tried switching it off and on again but that...
Keep your hand on condenser coil if it's visible or left and or right side body of the fridge. If you feel hot the gas is o.k. Otherwise no gas or chock. You have to repair and refill the gas.
Dec 08, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Our freezer seems to be working fine, however, the fridge part doesn't seem to be cool at all
all you have to do is defrost the frige the freezer sometimes will freeze up with ice in the back of freezer where the air flows into frige
Mar 13, 2010 | Haier HTE18WAA Top Freezer Refrigerator
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Both firdge and freezer on level 5 and still not very cold
It may just need more freon. A service call won't cost the landlord too much, and then he will have a report from a qualified third party, if the fridge needs to be replaced.
Apr 22, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
54 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
