Question about Timex 40131 Wristwatch
Hi i need to put back the back plate of my timex watch but is is stubornly refusing to be back on. What can I do? Procedure please? Jack
I used a 13/16 12 pt socket on the crystal side, making sure that the socket didnt come into contact with the glass. then a piece of hardwood against the back, i then put it in my vise, making sure to apply the same pressure equally as i very slowly turn the handle of the vice and it popped right on..... simple as sin.....
Posted on Sep 10, 2012
I fixed a Timex Indiglo WR 30M and placed the plate in the freezer for 15 minutes since I was in a hurry and that worked great. Thanks mcdevito75 for this tip.
Posted on Oct 12, 2011
    Genius:
  • 1,970 Answers
Mcdevito75 here, This can be a problem, the tolerances between the back cover and case of the watch is in MM. Believe it or not here"s a trick you can try, place the cover only in the frig. for a 1/2 hour, the cold frig. may and should shrink the back cover just enough to fit back onto the caseing. Also make sure you have any cutouts or indentations on the back cover matching anything on the case of the watch, one thing is the cutout for the winding stem of the watch, there should be a cutout on the back cover for the stem of the watch.
Posted on Aug 28, 2010
I cannot replace the back of a timex 1854 watch. I replaced the battery but the back won't click on
I used a four inch "C" clamp and a large washer about diameter of back, to get my Timex back snapped back on. Place the watch face side down on a flat surface cushioning the crystal with soft rubbery material like shelf liner or anti skid material used under rugs (the kind used to also line tool chest drawers - black). Place the washer between the watch back plate and the "C" clamp screw plate. Align the back plate of the Timex as evenly on watch as possible while gradually tightening the "C" clamp. Keep turning down the "C" clamp ever so slowly until you hear the plate snap back on.
Jun 28, 2011 | Watches
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • Mar 02, 2011 | Timex Indiglo Analog Watch
    I have a timex ironman watch that I bought about 5 years ago and I need to change the battery and I need to know how to get the back off
    If there is a small indentation on the back plate, insert a very small screwdriver to pry the plate off. Then you'll find your battery.
    If your backplate has 3 indentations, then you'll need a special tool, which sets into all 3 indentations and unscrews the back.
    My suggestions to you is to bring it to any jewelers, even department staore jewelers and they have everything there, they'll even change the battery at no extra costs.
    Dec 16, 2010 | Timex Watches
    How do you unlatch the battery of a timex ironman watch. I have the back open now
    You will need to look for any screws holding down a plate over the battery. Sometimes these only need to be loosened and sometimes they have to be removed. Sometimes the plate can be lifter slightly and the battery slide out from underneath. I hope this helps you. Best luck
    Nov 19, 2009 | Timex 50-Lap Ironman Triathlon 59221 Wrist...
    Timex Men's Digital Expedition Chrono Alarm Timer Watch battery
    hi
    please follow the steps to change the battery
    1. Step 1 Make sure the little arrow on the back is aimed to the right. Then, insert a small flat head screwdriver into the notch on the edge, and lever the back open. Place the back to one side.
    2. Step 2 Unscrew the clip holding the battery (if your model has a clip), and remove the battery.
    3. Step 3 Use plastic tweezers to put in a new battery. Do not directly touch the new battery. Screw the clip (if it has one) back on.
    4. Step 4 Replace the gasket that seals the watch. Then lightly coat the gasket with a silicone-based grease.
    5. Step 5 Align the back with the little arrow aimed to the right again, then carefully press the watch between two pieces of wood that are being held by a small vise, until the back seats itself.
    thank you....
    Apr 08, 2009 | Timex T41091 Expedition Watch
    Timex Sleek stopped beeping when I replaced the battery
    This is a common problem when non watch educated people are changing battries themselves.
    The answer is simple: While changing battery and handling the watch you did lost the coil spring. It is so small, you will never notice that the something was dropped.
    Coilspring is the connector to the sound membrane of the watch, transfering microprocessor signals to audible membrane.
    If it's lost, there is no connection between watch movement and audio membrane.
    I suggest that you did change batteries yourself previously and had the same outcome (no sound). Next time you gonna change the battery - make sure you do not turn the watch upside down and if you do - check the movement with eyeglass and make sure all the loose fitted bits are in place.
    To get your both watches fixed visit your nearest watch repair shop and ask for coilspring to be fitted.
    Rate me, please.
    Mar 26, 2009 | Timex Ironman 30-lap, Blue And Silver From...
    How do i change the battery in a timex wr 30 m watch
    remove back cover plate- inside you will need a jewlers screw driver- install new batery in reverse. install screw- and snap cover back in place.Make sure battery is new.
    Dec 31, 2008 | Timex 27191 Wristwatch
    Cannot re-attach timex watch back cover
    good morning ! you need a pressing tools device to put back the case back of you timex watch! thanks ! god bless !.....
    Sep 03, 2008 | Timex Watches
    Timex Expedition alarm beep
    good after noon ! maybe the problem of your watch is wrong possition of case back because the speaker or buzzer of your watch is attached on the case back , so open the watch and fix the case back at the correct possition ,!thank you ! god bless !.....
    Aug 28, 2008 | Timex Digital Expedition watch
    How to change battery for Timex Indiglo WR 30M
    I second the vice advice...the only thing that worked was to put it in a vice and crank it one more crank then you think is possible. You will hear a little "pop" when it snaps into place. It was the only thing that worked!
    May 14, 2008 | Timex 27191 Wristwatch
    Timex 40131 Wristwatch Logo
    559 people viewed this question
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    Brett Duxbury
    Brett Duxbury
    Vladimir Frolov
    Are you a Timex Watch Expert? Answer questions, earn points and help others
