Question about SanDisk 2GB microSD Memory Card
Hello! My problem is as follow: When I put on my "SanDisk 2GB micro SD" Memory Card at the computer and I want to open its file on the explorer then an error message appears: "Der Datenträger in Laufwerk J: ist nicht formatiert. Soll er formatiert werden?" in English: "The data medium isn't formated. Shall it get formated?" Once I had the same problem with a hard disk. In this case I just installed the correct driver and the problem was solved. But for my Memory Card I couldn't find any drivers on the Internet. I hope you understand my English because I'm just a pupil who is learning it ;) Respectfully, Stefan Pauzenberger
    Genius:
  • 1,234 Answers
Hi Acm Stefan
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Posted on Aug 29, 2010
What is the default password of micro sd card?
Hello Saran,
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FE Explorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file to unlock memory card .
Also visit :
http://www.mobiclue.com/recover-memory-card-password-from.html
Jun 22, 2011 | SanDisk 2GB microSD Memory Card
My pc dont read micro sd scandisk 2gb, I need drivers
buy a cardreader.put the micro sd memory card in the cardreader's slot.connect cardreader to the to the computer and the computer can read your memory card.
May 31, 2011 | SanDisk 2GB microSD Memory Card
2GB Micro SD Card Memory Card locked
Hello Naryan,
Also visit :
May 28, 2011 | PNY 2GB microSD Memory Card
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
I scanned my micro sd 1gb and 2gb cards with wormblaster and now the 1 gb reads 59mb and the 2gb reads 13mb and will not format does these cards have a MBR that maybe got wiped from the scan because both...
Instructions
Things You'll Need:
* SD card slot or card reader
1. Download SanDisk Formatting Utility
2. Open an internet browser and enter the URL for the free SanDisk formatting utility into the address bar (see Resources).
3. Accept the terms of use by clicking the button labeled "I Accept" at the bottom of the page.
4. Save the executable installation file (sdfv2000.exe) to the computer hard drive.
5. Open Windows Explorer and navigate to the installation file.
6. Double-click the sdfv2000.exe file to begin the installation of the software.
7. Click "Yes" to accept the terms of use for the installation package.
8. Verify the installation location and click "Next."
9. Select a Program Folder for installation and click "Next." The progress bar will monitor the installation.
10. Click "Finish." A text file containing notes for formatting software will automatically open.
Format SanDisk
11. Click the Windows "Start" button.
12. Click "All Programs."
13. Locate and expand the Panasonic link.
14. Double-click the program entitled "SD Formatter."
15. Insert the SanDisk card into the SD slot or card reader.
16. Click the top drop-down box in the SD Formatter interface to view a list of available drives on the computer.
17. Locate the SanDisk drive and select from the drop-down options.
Click the button labeled "Format" to begin the formatting process. A notification will appear to indicate the process has finished.
Nov 04, 2010 | SanDisk 2GB microSD Memory Card
How do I use the SanDisk adaptor and the SanDisk 2GB microSD
The micro card (the smaller one) can be used alone in a port that accepts (microSD ports)such as those on a Sansa c240, c250, e250 etc.
If you have a regular SD slot (larger than microSD) then you plug the micro card in the adapter and plug the whole into a regular SD slot.
Plug the card in your computer and copy paste the files. Or plug the micro card in an MP3 player that accepts it and use you music transfert software.
You only have one card (the micro SD one), which you can use in two possible slots.
Hope it helps.
May 19, 2009 | SanDisk 2GB microSD Memory Card
Samsung micro sd memory card
THE CARD IS WRITE PROTECTED
OR THE FILES COPIED ARE WRITE PROTECTED.
SO REMOVE THE WRITE PROTECTION ITS LIKE A SMALL SWITCH WHICH SLIDES ON THE CARD .. ONLY CERTAIN CARDS HAVE IT .
NOW IF THIS DOESNT WORK
PUT THE CARD IN A PHONE AND SEE PROPERTIES OF THE DATA THERE , REMOVE WRITE PROTECTION .
Jun 08, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB microSD Memory Card Logo
107 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
