Question about Emerson (025806027051) Radio/CD Boombox
I have an Emerson ES8 micro audio system. he radio works, however the disc player does not read any CD's. Any suggestions on how I can fix this?
techman
  • 3130 Answers
SOURCE: EMERSON AV510 BAD DISC
The only thing you can do I'm afraid is to disassemble the unit, find the lens and clean it off with a cotton swab abd a little alcohol. if this does not work, the spindle motor, or the laser assembly is most likely bad, and this will need to be repaired by a pro. The only problem with that is most of the time, the labor and the parts exceed what a new unit cost most of the time. Good Luck
Posted on Jul 05, 2007
SOURCE: won't play a cd
put a mp3 cd it will work worked for mine has truoble reading regualr cds
Posted on Feb 08, 2008
SOURCE: I have an es8 emerson
I just fixed this not to long ago. Take off the left side panel and replace the black belt with a rubber band of about the same size.
Over time, these small belts become stretched and lose their grip on the pully.
Posted on Nov 24, 2010
  • 21 Answers
SOURCE: Emerson 3 Compact Disc Player
Hi
If the machine cant read the table of contents of a disc this would suggest either the lens of the optical pick up is dirty or the optical pick up has failed completely or something directly relating to the optical pick up i.e the spindle or stepper motor, if you can easily acess the optical lens you maybe able to clean it using a cotton bud and re-test, just try this with a dry contton bud to begin with if this gives an improvement you may wish to use a cotton bud with a alchol cleaner like I.P.A,
make light circular movements over the lens. If this makes no difference the machine requires repairing, so consult a local service engineer.
regards
TechSupp12
Posted on Dec 11, 2010
  • 6771 Answers
SOURCE: emerson dvd player won't read disc. makes spinning noise but nothing happens. disc display sometimes show spinning. only get blank screen . used cleaner disc. work at first now cleaner won't
The DVD laser pickup is at the end of life, replacement of assembly the only option, cheaper to replace the combo unit.
Posted on Jun 24, 2012
Radio works fine. cd player wont read discs in either of four slots. Message - Disc error.
This can often be solved by opening the cover and blowing on the optical head to displace dust and any debris that is fouling between the optics and the actuator that controls the head position. It isn't fool proof but will fix perhaps 40% of units. Take a can of air duster (aerosol blower) and blow the little pick-up form the distance of about 1 inch. It will bounce around in the wind but don't blow to hard. Give it a gentle blast and then try the player. If it doesn't work then try again this time but blow harder.
Feb 27, 2012 | Bose Wave Music System CD Shelf System
Everything works on my emerson MS9700 except the cd player. the display keeps saying no rdy. how can i fix this?
If the indication says" not ready " it means that the disc is not reading the data present on it . It is possible that the disc is not scanned by the optical head to be ready to play.
So it is possible that the optical head is defective or weak, please try to clean the optical eye with ear bud very softly or use a disc cleaner.
If there is no result the head can be faulty.
If the set was not used for long time please keep it powered ON.
Also the processing section/main board can be a suspect.
Nov 19, 2010 | Emerson EM-MS9700 6 CD-Changer stereo...
I have an es8 emerson and the door on top to the cd player wont open
Oct 02, 2010 | Emerson Audio Players & Recorders
2002 Kia Sedona - Cd Player reads ''error''
It the player won't run the cleaning disc or doesn't turn any disc, then the cd player motor or capacitor that controls power to the motor is faulty
Jul 03, 2009 | Car Audio & Video
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
Won't play a cd
We have the same problem and are searching all over the web for a solution but no luck. If we find a solution we will come back and post what we found. :)
Oct 15, 2007 | Emerson MS3111M Shelf System
CD player stops, won't open
you have to unscrew the case. then you can get the cds out
Jul 16, 2007 | Emerson MS9700 CD Shelf System
CD's won't play
I know that Panasonic provides chips, optics (laser),etc. to Emerson. I am familiar with the problem you've experienced because I've had a Panasonic CD Player. If the disc doesn't spin (as you said), the problem must be that your shelf system probably has an optical problem (laser problem/pickup problem) and will need to be serviced.
Apr 22, 2007 | Emerson MS3103 Shelf System
Emerson (025806027051) Radio/CD Boombox Logo
113 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
