Question about GE WBSR3140DW Top Load Washer
I have a GE washer, top load. Model WCSR4170G0WW Ser: LM177788G It doesn't spin during spin cycle. What could be the problem?
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
JULIANFIX
  • 975 Answers
SOURCE: GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Posted on Apr 16, 2008
SOURCE: Washer Clicking/Ticking Noise
Washer is four years old. It makes a loud noise when agitating and now the drum is jammed. What can I do to fix it?
Thanks,
Posted on Sep 14, 2008
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Posted on Mar 02, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
GE wpdh8900jmg front load does not go to highest speed spin. It does go to the lower speed spins
call your G.E. authorized dealer because theres a recall on this unit,or call G.E. directly or go online to find out how to get warranty service at NO COST to you,as theres a problem with these machines and the problem your having is a recall issue by GE company,the unit needs to be re-programmed during spin or theres a chance the basket can breach the top cabinet during spin cycle call them SOON,all serial numbers for that model are covered under this warranty
Nov 19, 2012 | General Electric WPDH8900JMG Front Load...
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
My GE Model # WBB4500E1WW washer not spinning
the washer is on but not spining and the machine is about 6 month old
Dec 19, 2009 | GE WBB4500EWW Top Load Washer
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
GE Top load washer 15years old. noisy when spinning
washer making a load cluck noise when the spin cycle starts.
It only happens when the motor turns slow for the first minute during the spin cycle. Otherwise it works fine.
if the motor is proper then the bearings in the motor got rusted and that needs replacement.the beasrings are located on the back of the motor.
Apr 03, 2009 | GE WVSR1060A Top Load Washer
GE top load washer will drain but not spin
you both need to have the switch replaced or you can open top of washer and combine the lid switches wires together as a bypass and electrical tape
the lid switches are put in the washers to keep kids from opening the washer machine this is automatic shut down
for xenazoe
you require this part for your washer
Part Number: WH12X10065
SWITCH PRESSURE
Apr 01, 2008 | GE WBB4500EWW Top Load Washer
GE WBSR3140DW Top Load Washer Logo
233 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
