Question about Speed Queen Washing Machines
Oil is getting into wash water - Speed Queen Washing Machines
  • Speed Queen Master
  • 713 Answers
Hi Bob just read your posting.I am afraid your gearbox is leaking oil into the water .This means to repair the machine your gearbox needs reconditioning or replacement and also the main shaft seal will need replacing.I am putting this posting as a clarification request because my brand of expertise is FISHER@PAYKEL but I have some experience with SPEED QUEEN and KLEENMAID,which are the same machine only different names.Posting this reply as a clarification request will still leave your posting up in the washing machine area for other experts to hopefully help you further.But I am 100% sure that your gearbox needs repairing.Please reply if you need further help or information from me.Good luck.<br />
Posted on Aug 28, 2010
  • 1 more comment
  • aussiecarguy Sep 12, 2010
    I have the same problem, oid streaks are evident in the bottom of the bowl in the final spins. How do you remove the gearbox and does the agitator need to be removed? I have noticed the that agitator has movement when in place (having difficult working out how to remove this as there is no 7/16" nut thru the top) and moves off centre a good deal, does this also mean the hub and bearings need repairs?
    I have the same problem, oid streaks are evident in the bottom of the bowl in the final spins. How do you remove the gearbox and does the agitator need to be removed? I have noticed the that agitator has movement when in place (having difficult working out how to remove this as there is no 7/16" nut in the top of agitator) and moves off centre a good deal, does this also mean the hub and bearings need repairs?
  • luisa_sgro Sep 14, 2010
    Hi just read your posting.Now, I need to know the make and model of your machine.As I mentioned in the posting you read I have some experience in the speed queens and kleenmaids.Please reply with make and model number and I will help you as much as I can.Looking forward to your reply.
How do I fix my hover 730 washing machine that's spraying out little drops of oil.
oil out is water in
after 35 years the seals and shafts will be very difficult to get if not impossible
consider a new machine
Feb 26, 2016 | Washing Machines
Oil in radiator , but there is no oil and water mixing in sump
I am assuming its motor oil and not transmission fluid, right ?
You can have a leaking intake gasket or head gasket and get oil in the coolant without getting coolant in the crankcase.
Same thing opposite. The bigger the leak, the better the chance of getting both at the same time.
Mar 29, 2015 | Cars & Trucks
Worth fixing dryer that is getting oil spots on clothes model mah5500bwq
This machine has no oil in the tub assembly. Over a period of time and using cold water washes body oil, dirt and undissolved detergents and fabric softener will accumulate at the water line on the inner wall of the outer tub. After the gunk builds up thick enough parts of it will break loose at times when using hot water and then get on the clothes.
Nov 03, 2012 | Maytag Washing Machines
Oil leaking in washing machine
its a common problem and if your clothes are getting oil spots on them its a term known as "wash-back",the cause is the top transmission seal is bad and letting its oil out and into the wash water,it needs replacing,very labor intensive as you need to remove both inner and outer tube and remove transmission top to replace it,its cheaper to replace the whole ****** or the machine depending on how old and its use and shape
Apr 29, 2012 | Frigidaire Gallery GLWS1339EC Top Load...
Washed clothes with gasoline on them. Put into dryer now washer and dryer smell like gasoline. How do I get it out?
To remove gas (petrol) smell from clothing, soak overnight in baby oil (use like you would downy), then wash in baking soda, then wash with normal detergent. It will rid "gas smell" from an entire basket of clothes. Air Dry ONLY
From ehow website:
Step1
Buy a bottle of baby oil. Since gas is an oil based product it is going to take an oil based product to clean the gas out of your clothing. Baby oil is a great product to use as it shouldn't, in most cases, cause further damage to your clothing.
Step2
Soak your clothes with a bit of laundry detergent, water, and a generous portion of baby oil. Also dab some right on the stain before soaking.
Step3
Swash your clothes in the water for a while and let them sit for about five minutes. Transfer the clothes into your washer, once again remembering not to mix them with any other clothing, and let the cycle finish.
Step4
Wash the clothes. If you have a top load washer, let it partially fill up about 1/4 of the way with water. Put some of the baby oil in the wash with the clothes and swash it around a bit. Once the washer cycle begins, add the detergent and let the cycle finish. Make sure that your gas coated clothes are the only clothes you put in the wash.
Step5
Dry your clothing. Make sure you only AIR DRY on a clothes line these clothes. It could take more than one wash to get all the oil out of your clothing. If you use the dryer after the first, or even the second time, you could risk starting a fire in your dryer.
Step6
Check and see if any smell remains in your clothing. If the smell of gas remains on the clothing repeat the wash with baby oil again until the smell is gone.
Sep 04, 2011 | Frigidaire Electric Dryer
Milky oil leaking from left side caseing?
If water gets inside the gearbox, it will emulsify due to the "blending" caused by the gears and crankshaft. It turns the oil a milky color. The water can come from a bad oil seal on the water pump (if the bike is water cooled), or from condensation inside the gearbox. Sitting out in the rain, pressure washing or riding in creek beds can also be the water source. Find the water source and fix the seal or otherwise remedy the exposure. You will need to do an oil change. Please rate my answer. Thanks.
Sep 13, 2010 | Honda NSR 125 R Motorcycles
Oil is spewing into the wash tub during the spin
This may be a busted tub seal, but is usually caused by the outer plastic tub retaining grease and debris from previous loads. I would try running a hot water only wash cycle at full water capacity and adding a strong degreaser. This should emulsify any left over grease while also washing out the outer tub. If the problem persists, you may need to repeat the procedure. Remember that your washing machine transmission is located below the drum and tub assembly and is full of oil, but that oil simply cannot travel uphill.
Mar 13, 2010 | KitchenAid Superba Architect KSCS25INSS...
Engine oil light on after i washed the engine.
Three things to try. You would think the motor would run hot enough to dry out. Sneak your wifes hairdryer out to the boat and use it for drying all the connections. Then check your oil for water, point being oil is an insulator and water conducts so a slight amount of water in the oil could ground the sensor. Last, disconnect battery and see if computer reboots.
Jul 05, 2009 | Light Outboard Motor Boat Bass Fishing...
Washing Machines Logo
364 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
