Question about Xerox Office Equipment & Supplies
Hi i have a zerox docutech 6135 and sudenly got a error code p01-221 and p01-220 interlock problems but have checked and changed all interlocks in that areas
lostboylad
SOURCE: Hotpoint Door Interlock Switch
If it's anything like the WM65 then I did it myself this evening. Be aware that I'm no professional. POWER SAFE? Three screws on the back of the top cover. Top off Remove the soap/fabric softener tray. Four screws off around the gap that's left. Three knobs to pull off (it helps if you remember which way they are set when you do this!) Take the rectangular control panel off, which should now be loose - it has interlocks on the right hand side, so be careful not to break them. You may need to tie or tape the panel safely out of your way to te top of the machine. Three screws off the top off the door section. Open the door unscrew the two short screws holding the lock plate. The interlock switch will fall off the back of the door, held on by it's power supply. Stick your hand round the back and pull it clear. Swap the mechanism (mine cost £14) Reverse procedure. Good luck. This wasn't the fault on my machine in the end. boo hoo!
Posted on Jan 05, 2007
SOURCE: Zanussi FS1155W won't start
found out its the printed circuit board has burnt out behind the front panel two tracks on the panel leading to a green capacitor on the circuit board overheated so i resolded the tracks put the washing machine back together and so far its done several washes [touch wood its a sucess] the circuit board brand new from zanussi 135.00 pounds [so new washing machine if it fails] so hopefully theres a solution
Posted on Feb 14, 2008
leetamara
  • 702 Answers
SOURCE: shift interlock switch
below lower side of the brake pedal.
Posted on Jul 27, 2008
SOURCE: Machine won't turn on
Display error E40 is normally associated with interlock problems and this covered in your manual.
The interlock light should be on when the power switch is pressed and stay on till end of program?
It is not difficult to replace the door interlock.Remove machine top cover.Look inside and locate the door interlock and wiring. Remove as many plastic ties as necessary from the wiring to assist removal, also trace and make note of plugs you will need to pull of. Once you have unplugged the wiring harness open the door and remove two screws and bracket that secures the door interlock. Now carefully reach down and remove door interlock taking care not to pull other wiring in the process.
Posted on Sep 04, 2008
SOURCE: mfc-7220 Back Cover Open
This one made me crazy, but I finally figured it out. Turn the machine around so that you are facing the back. Open the back cover. Pull down the second smaller roller cover inside the machine. If you look closely at the second smaller cover, on the right hand side (closer the the inside of the machine), is a very thin round piece of plastic that is only half the length of the smaller cover. There are 2 thin plastic tabs attached to either end of this round piece of plastic. Gently shift this over so that the 2 plastic tabs can now go into the space provided for them. I had to move mine over only 1/4 inch.
Posted on Nov 13, 2008
Electrolux w455h washing machine is comming error 45 moter not floow..what is the reason comming like this????thanks...
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Apr 05, 2016 | Electrolux Washing Machines
EWF 1704 erro 41
programme):
Press and hold down START/PAUSE and the nearest option button simultaneously for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
E41 - Door open
Possible causes:
Dado
Sep 14, 2015 | Electrolux Washing Machines
How to do with E40 code of Electrolux EWF 1074?
programme):
E41 - Door open
Possible causes:
Dado
Aug 24, 2015 | Electrolux Washing Machines
Jet stsem no water comming in and flahing erreor 40
programme):
E41 - Door open
Possible causes:
Dado
Jun 14, 2015 | Zanussi Washing Machines
Turn on my jet system 1200 fj 1254w xc just makes clicking sound
Obviously appeared family error code E40 (visible to the customer) what means a problem with door interlock. Could be: door open (mechanical failure), door interlock malfunction, the problem with main PCB (triac) or wiring. In service mode you can see exactly error code: E41,E42,E43,E44 or E45.
Dado
Jun 07, 2015 | Zanussi Washing Machines
Error code E40 on a Electrolux Front Loader Washing Machine EWF1090 What does it mean and how can I fix it?
programme):
E41 - Door open
Possible causes:
Dado
Feb 24, 2015 | Electrolux Washing Machines
Zanussi washing machine ZWF 14581 error code 43 is showing up. How can I reset the machine so that it works normally?
Zanussi code 43 states 'problem with the door interlock triac', sorry- likely service call ;-0(
Good luck
John C.
Oct 08, 2011 | Zanussi ZWF1430W Front Load Washer
Christie error message "Lamp Interlock Fault"
the switch itself may be broken. check continuity.
May 14, 2009 | Christie Roadster X9 Multimedia Projector
Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
Nov 14, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Washer stopped midcyle-error code do, then FL
The door interlock could be faulty. The only way to open the door if the door interlock is faulty is to remove the top of the machine, after turning it off at the wall and pulling the plug out of the socket, and locate the door interlock from the inside. There should be a metal "slide" which can moved back to release the door catch. The interlock could be warped from getting hot, which will make the slide almost impossible to move. Remove screws holding the interlock from the front panel and from the inside pry the interlock from the catch. Replace interlock.
Oct 21, 2007 | Maytag Neptune MAH5500B Front Load Washer
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
