Question about Garmin Minn Kota MK 440 On-Board Charger CHARGERS
My problem is that I'm not exactly sure that I am charging correctly.Even if it is plugged in all night the yellow charge lights never go off unless I unplug and replug the 110v input plug quickly.It acts as if something gets reset inside the unit. As soon as i do that- the green charged lights come on.What gives.I have a Minn Kota 2 bank MK 25 charger (around '95 model)
  • 13 more comments
  • warrenh3859 Aug 28, 2010
    What does that really mean? Is it not putting out voltage or not putting out current? What am I supposed to watch for at the end? Why does quickly unplugging the 110v reset something or allow the charged indicators to go to green from yellow? Help?
  • warrenh3859 Aug 29, 2010
    I really think that if I leave it plugged in too long that would be overcharging for sure. I mainly want to know if these chargers have replaceable relays or not.Surely it must be some charged relay thats not kicking in to tell it to stop charging or not. Maybe its some sort of loose solder connection inside? What does anybody know about this.
    Thanks tbreeze 47. Thats kind of what I already expected to here.Now I'm looking for someone to tell me if these chargers have replaceable or servicable relays or not. If they dont ,then I'll know what I need to do. 'Preciate you anyway.
    C'mon any electronic techs out there. Surely someone might know about this symptom and a remedy.I really want to try to salvage this charger-I'm not from the throwaway generation. Help please.
  • warrenh3859 Aug 30, 2010
    What about the fact that after sufficient charging time whenever I quickly unplug and replug the 110v plug-- that the green charged lights both come on? Why would you blame the batteries when this happens? I would think this would point to the charger and not the batteries.
    The problem is still there.I suspect the batteries are ok because the fact of unplugging the replugging the charger will instantly show green lights for charged.Its like the relay inside gets a surge of some kind then switches from charging to fully charged. Any Minn-Kota techs out there-or anybody else had this exact problem with theirs and what did you do to remedy the situation.help
    Whenever the charger doesnt go from yellow to green then we can assume that its constantly pouring current into it-which would technically overcharge overnight-wouldnt it? Like boiling the batterys the last few hours or maybe more.Maybe it would be a battery problem- as if never getting up to full potential, then the lights never switch to charged mode.Whenever I change the leads to my starting battery I have found that it changes over to charged correctly as normal.Found this out just today.What u think?
    Ok-I just found out today that whenever I switched over one set of leads to the starting battery then the charged lights switched over seemingly like normal-after just a 1/2 hr or so.Thats because that battery was almost fully charged when I started the process.Anybody leaning toward the batteries now?
    Ok-new info from today.I switched one set of leads to the starting battery which was 98% full when I started and left the other set of leads onto a trolling motor battery. Of course the starting battery lights switched over to green charged withing a 1/2 hr or so like normal. Now maybe I'm leaning with your theory of poor batterys not accepting a full charge. I just bought the boat last year used and dont really know exactly how old the batterys are anyway.Let ya know.
  • warrenh3859 Sep 01, 2010
    How about this problem-any techs out there that have seen this EXACT situation and what did you do to EXACTLY correct it? Any takers out there? For starters-I'm gonna take one of my batteries tomorrow to get load tested to see what that will show.If it doesnt load test out ok then I'm gonna start with 2 new ones then see what that does to the charger.If they have a lightly shorted cell then I suppose it would act like a slight resistance while trying to charge.Thats the theory for now.Can anyone confirm this at all?
  • warrenh3859 Sep 02, 2010
    Ok-anybody want to weigh-in on this symptom? almost ready to trash the batteries- but I'm not 100% yet.They dont seem to take a charge but yet check out ok at Autozone!
    Rockmeister-sorry but I didnt understand anything you just said. Do you have anybody that can translate what you mean in some other terms? What is the device-why do you believe that the charger is not the orginal to the boat-My goodness I have too many questions to this post-thanks anyway though. Its obvious that you are either a Mensa scholar that is trying to come down to layman terms It looks like I'm going with 2 new batterys after all this.
    Ok-thanks I think. Can anyone translate what this guy is talking about.I am talking about a boat onboard (built in-came with the boat originally)battery charger that charges 2 batteries at one time-this is called a 2 bank charger. Its sort of pointing to the batteries themselves might end up being slightly shorted-not taking the charge.Thats what its pointing to. I still dont know what the heck rockmeister is talking about but thanks anyway for trying.
  • warrenh3859 Sep 05, 2010
    Well after much trial and error-I decided to remove the batteries one at a time and test THEM. Working on a theory of the indicators on the charger might be related to slightly shorted batteries not able to take a full charge. I swapped leads one at a time to the starting battery and the charger seemed to be working correctly. Swapped out for 2 new trolling batteries and seem to be good to go with the charging system again. Thanks for your help.Warren
    After much trial and error -I decided to test the batteries individually.They had a slighly opened circuit indicated by not able to take a full charge.When I swapped out for 2 new trolling batteries-I was good to go.All along I was hoping for an actual MARINE TECHNICIAN to answer to tell me what my first thing to do was.I already knew ALL the other theories that everybody threw at me.I wanted an actual real life experience to come out and tell me what they had-so that I could go straight to my problem and not dance around with other work not necessary.No marine techs here I suppose. This website did not really help at all.Thanks anyway.I MIGHT still come back to this website later just to view what "experts" are telling people about their problems.lol
    Top Expert:
  • Garmin Master
  • 76,109 Answers
This light indicates you need to have the battery replaced.
Posted on Sep 02, 2010
  • 4,924 Answers
I don't think that the relay on the charger can be changed..but the thing is mainly that the voltage is not allow it to fully 100% charge it ..probably it charge it about 99 % ..and after you replug it ..it indicates the green light cause it sees it charged..
It might have nothing wrong but it is not able to switch from yellow to green when it reaches the voltage ...but it is able to recognize it charged when you first plug it and it is charged....It make sense isnt it ??
it might be just that ..If the devise indicator shows it charged after the operation ..I dont see any reason to change it ..cause it basically works ..
Posted on Aug 30, 2010
    President:
  • 2,047 Answers
When such a problem occurs couple of things you should first check are:
- The battery life of the device
- The recommended output of the charger and also what is needed by the device
If you are not charging correctly the charge light will not come on at all. Also if the green charged light comes on after unpluging and repluging does the device maintain a normal battery life? If you the charger you are using is not the actual charger that came with the device then such problems can be expected. Although it would be advicable to get the recommended charger for the device as this could damage the device battery.
Hope this solution has been helpful?
  • 2,272 Answers
Get load tested the battery and check out.But in most cases the battery needs to be replaced in this types of problems.Also if still the same problem with new problem then the further troubleshooting should be continued.But first the unit needs to be checked with new batteries and confirmed.
Check out.Keep updated.Thanks.
Posted on Sep 01, 2010
    Sergeant:
  • 252 Answers
Your batter is defective please replace you can order these batteries from garmin. Your yellow light stays on because your battery never receives a full charge.
Posted on Aug 29, 2010
    President:
  • 563 Answers
Hi.
These chargers are not replaceable or even have servicable relays
  • 3,083 Answers
There is a possibility that by unplugging and plugging the ac back in, that a relay changes state or resets, changing the status light. Would have to see a schematic of the unit to know, however. The main thing to worry about here, of course, is that the battery doesn't get overcharged, decreasing it's useful life.
There's nobody who knows this stuff like marine enthusiasts. I would talk to someone at a boat repair facility and see what they think. They could maybe let you know if this was ok or not. However, it would take a service manual and technician to correct the problem.
Good luck, and wish I had a better answer for you.
  • 10,865 Answers
Hello Warren. Your charger is on it's last legs. Replace it and you will be up and running again.
Posted on Aug 28, 2010
  • 905 Answers
Check your craft for a steady current draw. Use a multimeter with the ammeter portion connected in series with the negative. Start pulling fuses until the display indicates a zero amp draw.
Something is drawing power, and the charger thinks that it is still charging the batteries based on current draw. When you unplug, and replug, it does a quick check for battery voltage, sees that it is acceptable, and terminates charge (green light).
Posted on Aug 31, 2010
  • Sheldon Dedek Aug 31, 2010
    Also, if your batteries are severely depleted, it may take more than just a night's worth of charging to get them up to a full charge again.
How do we charge this chair?
off board chargers plug into the front of the joystick. after 10-12 hrs the chair should be charged, Unless the batteries are bad, or the charger is bad. Plug into joystick before power cord into wall outlet. also charge every night!
Mar 15, 2016 | Health & Beauty
Tip
Charging your power chair or scooter the correct way can make them last
Whenever you need to charge your power chair or scooter get into the habit of charging overnight. The battery level indicator lights will tell you if your chair or scooter needs charging. Whenever the lights are down into the yellow and especially if they are in the red. If you have the off-board charger, plug the charger into the charger port in the front of your joystick and then plug the charger into the wall socket or turn the on/off switch on and let it charge overnight. When you get up in the morning the charger should have a red light(power) and a green light illuminated (indicating fully charged) Always turn the charger off or unplug it from the wall socket before you unplug it from the chair or scooter. Never have the power on to the charger when you plug or unplug it from your chair or scooter. Whenever you get new batteries always give your batteries a full charge before use and then if you use the chair daily charge it every night. If you do not use your chair or scooter daily charge it at least once a week. Never leave the charger plugged in and on for more than 24 hours. Your batteries should last you 3-4 years if you charge them correctly.
on Sep 20, 2010 | Health & Beauty
Start using a new kindle
Leave the kindle charging over night. The yellow light will turn green when fully charged. Or watch the lights and time when the green light comes on.Make sure you have the kindle wifi off when not in use as the battery uses memory when it is on.
Nov 02, 2014 | Amazon Kindle Paperwhite
Kindle not working. It will not turn on blank screen
Make sure that the kindle is fully charged. When charging the kindle 3 will have a yellow light indicating that it is charging. When this turns green, your kindle is fully charged. Make sure your kindle is fully charged and then try turning it back on.
Feb 21, 2011 | Amazon Kindle DX 3rd Generation
Invacare m51 scooter. I just replaced the batteries in my dads chair. We charged it all night the first night and it ran great the next day. recharged it for several days after using it and now the battery...
Sweet you do not need to leave the charger plugged in for several days. Sounds like there is a charger problem When you first plug the charger in with batteries depleted you should be getting a red and yellow light with the yellow turning green when fully charged. now the charger (built in) could have become unplugged from the power module located in the rear of the chair behind the black cover. To get to it you have to remove the seat, shroud and batteries then using a phillips screwdriver and adjustable wrench remove the black cover. The charger cord will be the last one on the left with a small 4 pin white plastic plug make sure it is well seated in the power module. If it isn't loose then you have a problem with the charger or the circuit. Now if you know of a friend that has an off board charger for a chair or scooter that you can borrow you can charge the batteries using the charger port located under the front of the joystick Plug the charger into the port then into the wall socket and let er rip Charge until the light turns green overnite is a good habit to get into If the onboard charger is bad I would suggest you by an offboard charger (cheaper) Now if Medicare paid for your Dads Chair then they will pay for any repairs even batteries and you can contact the provider that your dad got the chair from to see if they will repair it Hope this helps
Feb 17, 2011 | Health & Beauty
Do not know if chair is taking a charge lights just keep moving across armrest .how do u tell when fully charged?
hi let me see if i can help ,
When the lights go back and forth on your joystick that means the chair knows its pluged in .Now the chair itself has a built in charger that is mounted on the back of your chair .The back of the chair ,there is a opening a cutout in the frame .when you plug in your chair there will be a red light and a yellow ,yellow means the chair is charging, wait till it turns green,this means fully charged.When you plug in the chair youll see the lights through that hole.Look for the lights.
I recommend my customers to leave there chair charging over night look at the light it will be green when you turn the chair on the joystick should show fully charge.
Good luck hope i was of some help.
Jan 20, 2011 | Invacare Supply Group Invacare Pronto M51...
What is the proper way to charge the Pronto M51
Eduardo After using your chair and the battery level lights are down with yellow or red lights showing just plug the chair into the wall socket and let er rip. Now really after using your chair during the day and you are ready for bed just plug in the charger and let it charge over night. In the morning unplug the charger and you should be set for the day. If you don't use the chair everyday always put it up with a full charge and about once a week plug it in and let it charge overnight. Never leave the chair plugged in all the time and never leave it for more that 24 hours. The charger has two lights on it one red and one yellow or green that are hard to see because they are under the rear cover. When the chair is fully charged the yellow light turns green and you can unplug the charger and you should have a full charge. Hope this helps you
Sep 08, 2010 | Invacare Pronto M51 Power Wheelchair
When I plug in the ac adaptor to charge unit,the instructions state the chg light will go off when charged. Is it possible that it is charged and the light stays on. I charged it (in the off position)...
The unit still,work?The battery when it low,the battery light turn yellow or red?Than when it fully charge it turn green?Just unplug the unit and use it dosen't matter,if the light don't turn off the light,that find.Or the battery is old and not taking full charged anymore that another resoan the charging light still on.
Jun 14, 2010 | Mintek MDP-1770 Portable DVD Player
USB plug to charge, yellow light not green
t_cosh you must try charging it with the wall-charger, if that doesn't works, try entering BL mode by pressing # and *, and then pull the trigger to turn it on.
It will tell you that battery is low, you can connect then the charger, pull the trigger again, it should start normally.
Jun 21, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Help ASAP my MDA wont turn on
it might take a while tfor the light to come on . leaving it on all night should not hurt it. try charging it again
Nov 06, 2007 | T-Mobile MDA
Garmin Minn Kota MK 440 On-Board Charger CHARGERS Logo
560 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
