Question about Kenmore 74672 Gas Dryer
Kenmore gas dryer will not heat when i place clothe. runs fine without clothes
  • Kenmore Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Aug 29, 2010
Heat turns off while clothes still wet
change the gas coils on the gas valve by removing the 2 screws holding the bracket for the coils,remove the wire harnesses to each coil,dont worry one coil has 2 wires the other has 3 so quite hard to reverse
Jun 16, 2012 | Kenmore HE5
Kenmore Gas Clothes Dryer does not heat sufficiently
Ok, first and foremost, make sure your vent is clean and clear.
If the vent is clean and free of obstructions the most likely culprit is your gas valve coils. When they fail the typical symptom is heat at the beginning of the cycle and no heat about 20 minutes later.
If you can, post the complete model number from the dryer and I will give you step by step tear-down and replacement of parts instructions.
Jun 27, 2010 | Kenmore 63942 Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Dryer only heats when empty
Replace the 2 coils on the burner valve . Without model number , cant give you part number .
Jul 28, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Kenmore gas dryer, no heat
Your dryer lint vent pipe out the back of the machine or maybe out the side is partially plugged. You have to pull the machine out and clear that pipe or rebuild it out to a soffit vent or static vent if it is in the attic, or out through your crawl space. This will make a huge difference. If that hot air and moisture doesn't get out of the machine it just goes back into your clothes.
Good luck!!
Mar 25, 2009 | Kenmore Dryers
Location of the thermal fuse on the kenmore gas dryer 80
Feb 03, 2009 | Dryers
My kenmore gas dryer heats up but cools down too fast without completely drying my cloths
check you vent hose all the way to outside. make sure not blocked or kinked.
Nov 02, 2008 | Dryers
Kenmore 74672 Gas Dryer Logo
71 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
