Question about Electrolux Freezers
Stopped freezing, has power, compressor quiet
  • 382 Answers
Dear sir /madam
i think there is electrical trouble so please remove first electrical cord from main source then check any wire is remove or burn from it,s point ,if it,s then please contact to your maintenance personnel for repair it.
hope answer the question
thank you
please vote!
Posted on Sep 14, 2010
Freezer stopped after power outage
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Jul 10, 2016 | Frigidaire 14.1 cu. ft. Upright Freezer...
Chest Freezer Stopped Working 14 years old
The first thing you want to ensure is that power is actually getting into the unit. i suggest that you do that by plugging a night light into the outlet and verify the presence or power. If no power, check your breakers. If power is present note that A chest freezer has only two working parts; the start relay that help the compressor start and a compressor. If you are getting clicking sound, your start relay may be out (inexpensive if you can buy it and install it yourself) or a bad compressor. if you need to call a tech for the repair, you may be able to purchase a new chest freezer that now consume HALF the power and for less than cost of repair.
Mar 02, 2014 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Icepoint chest freezer ice101w is not freezing
Check power to compressor through thermostat. If compressor running but not freezing, suspect refrigerant leak. If sides are warm to touch, check to see if a fan is present in the compressor compartment on the side/rear and check it's working.
Jul 01, 2012 | Freezers
Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Jul 29, 2010 | Haier Freezers
My kelvinator upright freezer stopped freezing and it just kicks on and kicks right back of what could be wrong with it?
Start Relay/Overload or Compressor is bad. A bad compressor can make a Start Relay/Overload go bad but the only way to find out if compressor or Start Relay/Overload is bad is to replace the Start Relay/Overload if it starts and stays running you fixed it if Prob. returns in a week or so or if you have the same Prob. after replacing the relay the compressor is bad.
May 20, 2010 | GE 13.7 cu. ft. General Electric Upright...
I have a chest freezer model AFFC1526DW2 it stopped freezing. The power light is still on. What could be the problem
the thermostat may not be turning on the compressor.
Do you hear a buzz and or clicking every few minutes when plugged in? If so the compressor is trying to start indicating a problem with the compressor. you could check the windings for continuity or a short and then try a 3-in-1 start kit.
May 05, 2010 | Frigidaire Freezer FFU1724
Powers on, but doesn not freeze. There is no noise coming from the freezer.
Try this, unplug the unit for about 5 minutes. This will give the compressor time to cool. Plug it back in and listen to the compressor. See how long it takes for it kick on. When it does is there a click sound, shudder, or is it quiet. Touch the compressor, is it hot. Be careful when you do this as it might be very hot. There could be a chance that the freon has leaked out. Check to make sure there is no dust, lint, debris blocking the filter / vents. Vacuum as needed, it has to breathe. When the compressor kicks on and if it gets hot there is a chance it is bad. The repair for this is expensive and another solution might be to check out craigslist as you can find some great deals. Hope this helps.
JimmyC
Sep 27, 2009 | Magic Chef Chest Freezer MCCF5WBX
Hoshizaki ice machine KM500-MAE not sending water to harvest
I would not change the pump. If it runs for 3-5 minutes and stops, it has to be a control. The control board runs the freeze cycle for the first 5 minutes. This prevent "Short Cycling" of the freeze cycle. The board looks at the float after the first 5 minutes for the proper water level but should not effect the pump. If the pump does not run in the wash mode, check out the "Power/ Wash" switch. I would start there before I go spending hundreds on pump motor or control board. You may be able to get by on a $20 fix! Do this and get back to me. We will get it going.
Good Luck
May 06, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Frigidaire Upright not cooling
Not enough information but  if you are refering to the compressor as the black housing below, it seems that the compressor is either seized or burnt out.
Oct 25, 2007 | Frigidaire 11.6 cu. ft. / 328 liter...
Freezers Logo
100 people viewed this question
Top Electrolux Freezers Experts
Dennis Boxerman
Wayne Tolonen
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
