Question about GE DSXH43EAWW Electric Dryer
Steps to change rear drum bearing. I have the parts kit but would like a step by step instruction to get to the part, change it and get back.
  • 744 Answers
Click on the link below to be taken to a page that should help you see the blow-up diagram for your model and how the parts go together:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=DSXH43EAWW
Posted on Aug 28, 2010
Rear bearing
Remove the rear wheel, if the vehicle has rear disc brakes remove the brake caliper and brake rotor, If the vehicle has drum brakes , slide the drum off. Remove the 4 hub mounting bolts located on the back side of the backing plate.Using a hammer tap on the hub assembly (near the wheel studs) Reverse the steps to install the new hub assembly.
Jun 11, 2013 | Cars & Trucks
1999 plymouth breeze. step on brakes and the front brakes have a bad pulsing to them. previous owner hab brakes done rotars turned and pads replaced. any suggestions on how to address this problem
Symptom: Brake Pedal Pulsates Change When: Braking Change Where: Passenger Compartment Change -->lg-bl.jpg lg-br.jpg
Priority Action Part Type Cause 1 Inspect Brake Drum Specs Brake Drum Out of Adjustment, Out of Round, or Cracked. 2 Inspect Brake Drum Unevenly Worn or Out of Round Brake Drum(s). 3 Inspect Brake Rotor Incorrectly Machined Brake Rotor. 4 Inspect Wheel Bearing-Front Incorrectly Tightened or Installed Wheel Bearing. 5 Inspect Wheel Bearing-Rear Incorrectly Tightened or Installed Wheel Bearing. 6 Inspect Wheel Nut Loose, Worn, or Damaged Wheel Nut(s). 7 Inspect Rear Axle Bent Rear Axle.
Apr 13, 2013 | Plymouth Breeze Cars & Trucks
Replacing rear hub/bearing assembly on 2003 taurus with drum brakes/abs
The wheel bearings in a Ford Taurus are located in the hub/bearing assembly. Replacing the hub/bearing assembly is a straightforward process -- remove the brakes, then the bearing, and reassemble.
Not enough space available for step by step instructions. Try this link:
http://www.ehow.com/how_5488471_change-wheel-bearing-ford-taurus.html
Cheers,
TF
Jun 02, 2011 | 2003 Ford Taurus
Red line on screen
Install the JVC repair kit called AV48wp74 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and step by step instructions.
Jun 29, 2010 | JVC AV-48WP74 48" Rear Projection...
Noisy Washing machine drum
To replace bearings is quite a job. iyf your good at diy i rate this as a 9/10 ....A bearing kit is available from makers and instructions.
Apr 03, 2010 | Ariston Technologies AWD120WH Ariston
Tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Jan 31, 2010 | Hotpoint Dryers
Drum Kit For DCP-7020
Please refer the below link for step by step instructions on Drum replacement.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000098/faq000698_000.html?reg=us&c=us&lang=en&prod=dcp7020_us&Cat=7
Please rate the solution as Fixya if its solving your problem
Thanks
Feb 03, 2009 | Brother DCP-7020 All-In-One Laser Printer
1997 rear drums
Actually, if you want, your local Autozone can print you out instructions with pictures, and they don't charge. (At least, they didn't when I worked there)
Dec 04, 2008 | 1997 Ford Club Super
1997 rear drums
My suggestion is to go to an auto parts store and buy yourself a copy of the Haynes 1997 F150 half ton pickup manual. Short of that it would be very difficult to explain the step by step procedure. that is why, those of us who have been where you are always do one wheel at a time with the other original wheel our reference.
Good luck davisintexas Loringh
Dec 04, 2008 | 1997 Ford Econoline
Bearing noise
rear bearing is pressed into outer drum never changed bearing only usually requires entire drum replacement instead..also shaft on rear of inner basket is probably scored bad and needs replacement too
Mar 20, 2008 | Maytag Neptune Washer
GE DSXH43EAWW Electric Dryer Logo
110 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
