Question about HP LaserJet 3330 All-In-One Printer
Not working properly
Scanner bulb warming up ( long time )red light flashing then scanner error and power off ,
  • 5 Answers
Here's how to clean the mirrors (You Tube video which worked for me) if it's a scanner problem ie if the scanner seems to be 'stuck' & doesn't respond to being reset
https://www.youtube.com/watch?v=lqG_nmi3vC4
Posted on Jan 24, 2015
I'm having a similar problem. So far my solution has been to disconnect the 3330 from power for a longer period (> 30min.) and then switch it back on again. After the self-test everything appears to be ok again. I've got no idea why, but this seems to work (for now)
Posted on May 09, 2008
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
Fail to initializing
The fail to initialize is typically a problem with the document scanner...but not always. here is a quick test you can try. Turn the unit off then power it on again. Slightly lift the copy lid as the unit goes through warm up mode...pay attention to the light color emitting form the scammer. it starts to blink red, then changes to a bright white IF the scanner is working properly. IF the scanner is NOT working properly the scanner stays RED during the warm up.
Nov 26, 2013 | HP LaserJet Pro M1212nf MFP -...
Red light blinks 5 times and wont power on. Is not the bulb
error code is model specific---some it means lamp door issue and others something else.
Oct 31, 2012 | Sony Televison & Video
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Fax and cancel lights are flashing
I found this solution at HP website. It worked for me. Good luck!
A Scanner Bulb Error message is received as a result of the HP LaserJet 3300mfp series product scanner’s inability to find the home reference point.
SOLUTION:
Perform the following steps to walk the scan assembly from the home base and resolve the issue.
1. Remove and replace the power cord from the unit.
2. Wait approximately 35 seconds for the scanning assembly to “walk out" and then quickly remove the plug again.
3. Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
4. Replace the plug and let the product fully finish the boot cycle.
Oct 08, 2008 | HP LaserJet 3330 All-In-One Printer
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
TV turned off by itself and now blinks red led 6 times
6 blinks means a low B error. Which is no DD 6volt output on G1 board . This will cause no picture and no sound. To fix this yourself you would need the manual to get the correct sequence to test and proper part to order. You can get a service manual for 10.99 at the following link and they will ask if you'd like it emailed to you after purchase. Here is the link,
http://servicemanuals.vstore.ca/
Feb 01, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Bulb never lights up,
Hi The option you have is to check and make sure the connection between the formatter and scanner formatter are properly seated. The 79 error you are getting means you should try and do a firmware upgrade it could be giving you a problem and more than likely fix the issue.
Dec 03, 2007 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
179 people viewed this question
Seeker5211
Seeker5211
